Question about 4runner relay assy, circuit opening for efi;
Where is the circuit opening relay on a 97 Toyota 4runner
  • 2,072 Answers
This is a computer fan section, try posting your questions under automobiles.
Posted on Dec 03, 2012
Kindly help me with the wiring dirgram for 2003 toyota 4Runner with engine 4.7 V8.
Start by checking the ETCS fuse in the engine room fuse box. If it's good, you may have an open circuit between the fuse box and ECM.
Jun 11, 2015 | 2003 Toyota 4Runner
Circuit opening relay
More then likely you have a bad ground wire. You will have to start tracing this problem back to find the issue. Other issue is a intermittent power wire shorting
May 19, 2014 | Toyota 4Runner Cars & Trucks
What could cause me to have no power to my ignition and my dash on my 97 toyota 4 runner
Do any of your lights work? Battery/? Ground Cable? Engine Ground wire? Fuse? ignition Relay?
Nov 23, 2013 | 1997 Toyota 4Runner
Could my car just die at 60 mph from a relay going bad? or.?
sure can. if the pump relay quits working while your driving it will shut the engine down
idle air CONTROLLER,bad or TPS sensor not adjusted right or bad,throttle cable in bind or gas pedal
http://www.xcardiag.com/wholesale/mangoose-toyota-obd2-diagnostics-and-reprogramming-interface-49.html
May 22, 2012 | Cars & Trucks
Location of a toyota 4runner 2000 fuel pump relay
Right at the hood release are there are fuses on the bottom are the relays the fuel pump relay should be called circuit opening relay
Mar 10, 2012 | 2000 Toyota 4Runner
97 toyota 4runner factory alarm not allowing to start
lock your doors and close it wait till alarm resets and then unlock door with key and this should take care of you problem
Jan 05, 2010 | 1997 Toyota 4Runner
1992 4Runner circuit opener relay causing rich Idle
It may be that the O2 sensor is faulty or contaminated. Another possibility is that after running rich for some time, the catalytic converter is slagged and no longer working properly. Have you been able to get any diagnostic codes from the car's computer? Is the check engine light on?
Jul 19, 2009 | 1992 Toyota 4Runner
97 Toyota 4Runner starting problem
Could be the engine management system or the immobiliser?
Sian
Oct 19, 2008 | 1997 Toyota 4Runner
4runner relay assy, circuit opening for efi; Logo
83 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
ashburton
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
