Question about Samsung WA5451ANW 4.7 cu. ft. top load washer with vibration reduction
Samsung top load wa5451 he washing machine not draining
SOURCE: Our samsung j845 front load washing machine won't
SAME THING HAPPEND TO ME, SORRY BUT YOU NEED A NEW WATERPUMP, THEY GO ON THEM WASHERS ALL TIME. I REPLACED 2 AND HAD MY WASHER JUST OVER A YEAR. NOW ITS THE DOOR
Posted on Sep 29, 2009
  • 1531 Answers
SOURCE: Samsung SW65ASP2 top load washing machine only
there may be an obstuction at the wateer inlet valve turn off your water and remove the hoses and check for anything that would be restricting the water flow if this does not work you may need to replace the inlet valves.
Posted on Jan 31, 2010
rickead1
  • 1998 Answers
SOURCE: I HAVE BOUGHT SAMSUNGWA80V3 TOP
this error comes if waste water pipe jammed or blocked
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
check the drain pipe that comes out the back of your machine
please message me back if this does not solve your appliance situation and please remember to rank how this opinion has helped Thanks again
Rick
Posted on Nov 09, 2010
  • 17 Answers
SOURCE: Hi my washing machine samsung
because the function of filter is to block the small particles or dirty things including grease or oil etc., before disposing the water, and to avoid the clogging of floor drain and even sewage line. And after you used it you should check the filter if theres a some dirt, and grease or oil to clean up to avoid clogging and unclean water from your washing machine
Posted on Feb 06, 2011
SOURCE: My top loading machine always stops on Rinse
Did you find a solution? Mine is doing the exact same thing : ( Thanks.
Posted on Feb 09, 2011
Washing machine stop draining and not spin drying
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 21, 2011 | Samsung Washing Machines
Samsung energy star silver care will wash wont spin
heatman101
Apr 01, 2011 | Samsung Washing Machines
While moving my samsung top washing machine, I think my drain hose pipe has moved down the water level. Now machine is not able to retain the water while washing/soaking. I need to pull the drain hose pipe...
Although a few modern washing machines can operate with the drain pipe at any height, most machines will drain the water as soon as the drain pipe is placed below the machine water level.
The simplest solution for your problem would be to ask somebody with some handy man skills or hire a plumber to add a 2 inch PVC pipe to your drainage pipe which extends to a point behind your washing machine & then points upwards, making sure it is long enough to be at a higher point than your machines fullest water level.
This should be a relatively inexpensive alteration & will ensure that water does not drain unless the machine is on its drain cycle.
Please let me know if you need any further assistance.
Best wishes,
Graeme
Mar 10, 2011 | Samsung SW62ASP Top Load Washer
My washing machine isn't draining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 22, 2011 | Samsung WF203ANW Front Load Washer
Will not drain or spin
heatman101
Dec 24, 2010 | Samsung WF328AA Front Load Washer
Wont drain water
heatman101
Oct 16, 2010 | Samsung WF218AN Front Load Washer
My samsung vrt front loader will not drain or spin and showing nd code
heatman101
Aug 28, 2010 | Samsung Washing Machines
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 14, 2010 | Samsung SW62ASP Top Load Washer
Samsung WA5451ANW 4.7 cu. ft. top load washer with vibration reduction Logo
223 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
