Question about HP Sheet Stackers C8085A Sheet Stapler/Stacker for LJ 9000, 3000
Stapler/stacker option will not power up
2 Suggested Answers
  • 43 Answers
SOURCE: I had to reinstall my print driver for my HP 4200
you will have to enable the stacker/stapler option in the driver. On windows based systems this can be done under properties then the device settings tab.
Posted on Mar 19, 2010
Hp 9050 laser jet stacker error
Probably just a bad sensor or dirty sensor causing the issue.
Stacker or stacker/stapler output bins
For the 3,000-sheet stacker or 3,000-sheet stacker/stapler, the output bins are the upper bin (face-up) and the lower bin (face-down).
The upper bin (face-up) is the top bin on the stacker or stacker/stapler. This bin holds up to 100 sheets of paper in face-up order as they exit the printer. A sensor causes the product to stop when the bin is full. Product operation continues when you empty or reduce the amount of paper in the bin.
Lower bin (face-down) is the lower bin on the stacker or stacker/stapler. This bin holds up to 500 sheets of paper and can stack or staple jobs. This bin is the default output bin.
Aug 19, 2014 | HP Stacker For LaserJet 9040/9050/9500...
Tip
ERROR codes Canon 4540
Canon 4540 E00 Low fuser temperature E001 High fuser temperature E010 Main motor clock pulse E011 Bind or load on main motor E020 No TF for 3 minutes E030 Copy counter E050 Duplex unit E201 Scan motor E203 Scan motor E210 Lens home E240 DC controller E241 DC controller E320 CCD E400 DC controller, 24V E500 DC controller, 24V E510 Finisher feed motor E520 Stacker motor E530 Guide plate shift motor E531 Stapler motor E620 DC controller, edit board
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 4035
Canon 4035 E000 Low fuser temperature E001 High fuser temperature E010 Main motor clock pulse E011 Bind or load on main motor E020 No TF for 3 minutes E030 Copy counter E050 Duplex unit E201 Scan motor E203 Scan motor E210 Lens home E240 DC controller E241 DC controller E320 CCD E400 DC controller, 24V E500 DC controller, 24V E510 Finisher feed motor E520 Stacker motor E530 Guide plate shift motor E531 Stapler motor E620 DC controller, edit board
on Jan 18, 2010 | Office Equipment & Supplies
How do i clear the output stacker
If the display is not going back to Zero when you remove bills from the stacker, either there is dust on the stacker sensors or you told the machine to Add bills. De-select that option.
May 26, 2014 | Shinwoo SB-1000 Mixed Money Counter
How to staple a laserjet p4014
You need to have the LaserJet 500-sheet stapler/stacker accessory installed.
You would then need to select the stapler/stacker as the output device in your print driver. See the printer driver online Help for details.
Apr 07, 2014 | HP LaserJet P4014n Printer
51.23 error
How is it plugged in? Directly to the wall, no strip! No UPS!
Are they genuine HP toners? Remans can cause this issue, as well as toners that are nearing EOL. Check the toner levels and replace if needed.
In Case You Still Having Problem Then Follow Us For On : HP Printer Support
Nov 12, 2013 | HEWLETT-PACKARD Products - HP - 3000-Sheet...
Need to perfrom nvram init on HP 4250
To initialize NVRAM, turn the printer power off. Remove any installed accessories (for example, a stapler/stacker). Turn the printer power on, and then hold down (SELECT button) when the memory count begins. Continue holding down until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds. Press (UP ARROW button). Press the PAUSE/RESUME button (LJ 4200/4300) or the MENU button (LJ 4250/4350). The display should show SKIP DISK LOAD. Press (UP ARROW button) until NVRAM INIT is highlighted. Press (SELECT button) the printer initializes NVRAM and then continues its power-on sequence.
Nov 07, 2012 | HP Laserjet 4250dn Network Laser Printer...
I had to reinstall my print driver for my HP 4200 with a duplexer and Stacker/Stapler. The driver does not recognize that the stacker/stapler is installed on the printer yet the printer system info does?...
Mar 18, 2010 | HP LaserJet 4200n Printer
I have a KM-1820 and the problem is CF223 error.
Meaning Motor error in the option bulk paper stacker HS-8E. Suggested causes Defective harness (S02400) between engine board and option unit interface connector. ? Defective option bulk paper stacker HS Corrective action Replace engine board Replace harness
Oct 21, 2009 | Kyocera Mita FS-1920 Laser Printer
Printer is displaying 65.12 error
There is no 65.xx error code
the following code should help you.
66.00.15 EXTERNAL DEVICE FAILURE
Description
The stacker or stapler/stacker was removed and then replaced with the printer power was on.
Action
1. Turn the printer power off.
2. Make sure that the accessory is properly seated on and connected to the printer, without any gaps between the printer and the accessory. If the accessory uses cables, disconnect and reconnect them.
3. Turn the printer power on.
4. If the error reappears, record the message, and contact HP Customer Support.
Oct 29, 2008 | HP LaserJet 4350 Printer
HP Sheet Stackers C8085A Sheet Stapler/Stacker for LJ 9000, 3000 Logo
27 people viewed this question
Ben Johnson
