Question about Remington Health & Beauty
How to remove head r851
How do i remove the shaving head for cleaning remington r851
SOURCE: Remington MS2-250 shaver disassembly?
This shaver was pretty clearly not designed for battery replacement. To open, first remove the screen and blades, and unhook the metal collar from the tab on the back of the case. Then carefully pry off the black inset on the front of the shaver. Underneath it, near the bottom are two screws. Remove these. The case is now only held together by several plastic latches, which can be carefully pried apart with a small screwdriver. The two 2/3A size batteries are soldered to the printed circuit board, which can be pulled out (don't break the wires to the motor) by a little wiggling. The original batteries in mine are 1100mAh, and I have just ordered 1600mAh replacements. The new ones don't have tabs - so soldering them in place is probably going to be a challenge.
Good luck.
Posted on Dec 28, 2008
SOURCE: After two weeks use of my new Remington R5130, now
My R5130 kept falling apart when I shaved. I really like Remington Shavers (Spectrum Brands) and have had good luck with them until the R5130 model.
Two points.
1.) -THEY SHIPPED ME A NEW HEAD ASSEMBLY (BUT)- The original one I got had poorly formed plastics tabs on the blade retainer (head) I Googled Remington Shavers and used their Consumer Service tab to request a fix. They sent me a new head assembly free of charge and yes it worked much better. However, it eventually the heads started falling off again.
2.) RUBBER BAND FIXED IT - I looked it over again and thought that the range of movement and forces on the assembly pieces was just more than the design could handle so I looked for a way to contain some of the movement. I slipped a single thin (1/16"x1/8") - 2" diameter rubber band around the three head assembly and the problem has been completely eliminated. I can shave normally now. The rubber band nearly disappears under the black head flanges so it doesn't even look bad. The shave is a little firmer now but it still has most of the flexibility of the original design.
This simple fix will be a hard one for Remington (Spectrum Brands) to adopt but you might help spread the word. I am sure they will avoid this problem in the next models.
Posted on Sep 01, 2009
brector3
  • 1624 Answers
SOURCE: The shaving unit symbol continues to flash on my
The symbol should go away after 7 days of use. See link to user manual below
http://www.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
Posted on Nov 22, 2010
brector3
  • 1624 Answers
SOURCE: How do you remove the
The Arcitec series shavers have a very poor design and shaver heads can not be disassembled like the older model that you had. The blades can not be removed from the assembly that contains them. The only way to clean them is to run thm under hot water or ren them in an alcohol solution. Unfortunately, this method still leaves much to be desired.
Many users of the Arcitec models report having to change the heads twice as often because of this.
Complains can be made to Norelco customer service at 1-800-243-3050
If replacements are needed, you will find then at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Posted on May 09, 2011
brector3
  • 1624 Answers
SOURCE: how to replace shaving heads
You will find a helpful video demo at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-sp94-ms3-series-foil-and-cutter-set-p-238.html
Posted on Jun 22, 2011
Where do I get spare part for the Remington MS2 390 shaving foil in Perth ?
remington SP69 replacement foil screen and cutter blades for electric shaver remington ms2 390 heads replacement parts.
Jan 26, 2011 | Remington MS2-390 Electric Shaver
Are the heads suppose to turn. I cleaned the razor and the heads. It seems to shave, but the heads do not turn.
The round discs that touch you face are not supposed to turn. Only the blades on the inside turn
Dec 27, 2010 | Remington R5130
The shaving screen pops up when I turn on the shaver .
If the shaver heads pops up, this is because you have not cleaned it properly. This is common on this model type. You will need to thoroughly clean the top of the shaver body. Remove the cutters so that you can access it properly. You may need to use a toothpick or similar object to loosen and remove the build-up in the crevices. Then brush it all out with an old toothbrush or similar.
Clean it thoroughly and it will fix your problem
If you require a new screen for your shaver, you will find at shaveroutlet.com. See link below http://shaveroutlet.com/shaver-replacement-parts/remington-sp-390-foil-and-cutter-set.html
Nov 24, 2010 | Remington F5790
My F-5790 doesn't shave any longer. The shaving head pops up and doesn't stay in its proper place. I believe that the shaver is still under warranty. Please check my registration. Peter Bien
Nov 15, 2010 | Remington F5790
I have a Remington Titanium Smart system R - 9500 that I have had for about 4 or 5 Years. I just recently change the 3 shaving blades. I assembled the razor from this and started to shave again and had not...
It is probably just a coincidence that you are having a problem with the cleaning system after you changed the heads. Based on your description of the problem, it sounds like there is a clog in the system. Look for any blockages in the openings where the fluid goes into and out of the cleaning cup.
May 16, 2017 | Remington Titanium SmartSystem R-9500...
Pop up trimmer stopped working Remington R830
Make sure you are using the trimmer with the shaving heads on the shaver. With heads removed, the trimmer on the back will not work properly. If thats not the problem, the trimmer is broken or jammed. clen the blades really well with a toothbrush and rubbing alcohol. If they're jammed, this will probably free them up. If that doesnt do it, the trimmer is probably broken and that part is no longer available from Remington. If you really like this model, you can find a replacement at shaveroutlet.com
Jan 10, 2010 | Remington Health & Beauty
After two weeks use of my new Remington R5130, now one of the three heads keeps popping off during almost during every shave. Any suggestions?
Two points.
Jul 08, 2009 | Remington R510 Electric Shaver
Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Dec 05, 2007 | Remington ES-1000 Electric Shaver
Health & Beauty Logo
50 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
