Question about Drills
Craftsman12 volt fast charger not working part # 974412-001 is there a replacement?
2 Suggested Answers
bmrdude
  • 52 Answers
SOURCE: I have an 18 volt
No. It will probably charge but you will significantly reduce the life of your battery.
Posted on Mar 23, 2011
Dewalt dc9310 charger flashing
On some chargers, when the light blinks rapidly, it means that the battery is bad. Try looking up charger information on-line.
Feb 28, 2015 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
DC9310 charger was pluged into a 220v by mistake. What fried and can I replace it?
Most likely all of the power control circuitry, charging circuitry, and voltage regulating circuitry. At this point, your best bet would be to look for a used one on line.
Sep 04, 2014 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
How do i convert a makita charger model DC18RC at 110 volt to 240 volts?
The DC18RC are most likely to charged the BL1830 battery, which is the most popular of 18V Makita power tools. It is a Li-ion battery.
And the DC18RC battery charger has two volt 110 Volt and 240 Volt.
The 240 Volt DC18RC charger can replace model DC18RA & DC18SD because of its improved performance and full compatibility with Makita's NEW 'Star' labelled batteries that communicate between the tool, battery & charger. And, it is a fast charger.
It can charge a Makita BL1830 Battery in approx 22 minutes.
But, I do not recommend to convert a makita charger model DC18RC at 110 volt to 240 volts.
The reason is as below:
1. This will void product warranty ! If you follow this mod, you do it on your own risk !
2. There are several comments that described
same model # but with different design and components.
Please beware that this mod might not work on your charger
or worst, will damage it.
Only perform this mod if you know your way around with electronics !
Sep 20, 2013 | Makita Drills
18 volt dewalt lithium ion battery charger stopped working for no reason....
This can happen if the battery is too dead for too long. Keep trying to make it work like you have maybe 20-30 times. Or you can leave the battery in for a few days and let the logic chip do it's job. It should start working in a day or two.
Apr 25, 2012 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
Hi i have a colman hot water on demand but have lost the 240 volt charger.i was wondering what milliamps or amps it needs to puchase another one from a elec store.
Coleman Charger mine is a 240~volt ~50Hz 12V~600mA
my other is a 240v ~5oHz 12V~1mA battery should only be( 6V4.5Ah)
with a 1mA hour change should only be 4 hours to charge as its a fast charger.
Jan 27, 2012 | Coleman Hot Water On Demand
I can,t charger my dewalt batteries , so is the fault with my charger
It is likely the fault is the battery and not the charger. To confirm this take the charger to any Radio Shack and ask them to test the charger or if you have a small meter do it yourself, the charging voltage will be up to 5 volts more than the rated battery voltage of the drill, so if you get a high reading don't worry about it. Fast charger will be way over the battery rating, also fast chargers have a cost, they shorten battery life due to heat. I have had many battery powered tools, I have found that the batteries last about 2 years on average. I have this same Dewalt drill driver.
Nov 02, 2011 | Dewalt 7.2-18.0 Volt One Hour Charger
Batterys dont keep there charge i think the batterys need to be replaced
before you dump those batteries, check the charger. If the battery when charged runs the tool but dies out quickly then you are probably right. If the battery never seems to be charged at all, then it may be the charger.
Dec 10, 2009 | Hitachi DS14DVF3 14.4 Volt Ni Cad 3/8 Inch...
I bought a new highter current ni cad for my makita; however, the
As long as the charger voltage and the battery voltage match (7 volts) there should be no problem. A fast charger just runs more current thru the battery (per unit time) than a not-so-fast charger. If you notice the battery getting really hot when it's charging (like too hot to touch), stop using it.
Apr 28, 2009 | Makita 6019DWE 3/8 Cordless Drill Keyless...
Drills Logo
51 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
