Question about Exercise & Fitness
IMAGE 19.0 R treadmill wont turn on.
I just got the treadmill from a friend. It wont turn on. The console lights up. The fan and the heart rate monitor work fine. The incline works, but only goes up a quarter of what it should. This treadmill only has 35 miles on it. My friend is puzzled. Any ideas would be very much appreciated.
SOURCE: I have a proform j8li treadmill, all 4 led lights
I have the exact same problem with the very same treadmill that i bouth 10 years ago and it has been sitting for 5 years unused. The last time it was turned on it worked but now that I plug it in and try to start it, everything works but the belt drive motor. Any ideas?
Posted on Feb 09, 2010
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
  • 11 Answers
SOURCE: heart rate monitor chest band not working with Life Fitness 9500H
Enter the diagnostic menu and ensure the "telemetry" option is enabled in the managers config menu.
Posted on Apr 27, 2010
SOURCE: When I turn on the
First of all you need a Surge protector, you can get one from Nordictrack.com, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Posted on Jan 03, 2011
SOURCE: The belt does not move
You have a bad motor control board. It will have to be replaced.
Posted on Jan 23, 2011
You turn it on, and the display lights, but the belt won't move at all.
Does the console count down ?
If so and belt wont move then you have a problem with the LCB.
Oct 07, 2013 | Icon Image 17.5 S Treadmill
My heart rate monitor does not work when gripping the hand bars.
please follow the steps and fix it. God bless you
1) Make sure the heart rate monitor is under your clothing, against your skin, and as high under the pectoral muscles as is comfortable. Note: If the heart rate monitor does not function when positioned as described, try moving it slightly lower or higher on your chest.
2) Make sure the logo on the sensor is facing forward and is right side up.
3) Use saline solution (saliva or contact lens solution) to wet the two electrode areas on the sensor unit. If the heart rate readings do not appear until you begin perspiring, re-wet the electrode areas.
4) As you walk or run on the treadmill, position yourself near the center of the walking belt. For the console to display heart rate readings
5) The heart rate monitor is designed to work with people who have normal heart rhythms. Heart rate detection problems may be caused by medical conditions such as premature ventricular contractions (pvcs), tachycardia bursts, and arrhythmia.
6) The operation of the heart rate monitor can be affected by magnetic interference caused by high power lines or other sources. If you suspect that magnetic interference may be causing a problem, try relocating the treadmill.
7) If the heart rate monitor still does not function properly, test it by having another person try it.
Jan 22, 2013 | Ironman Exercise & Fitness
1) Adjust the REED switch, clean it, and tight the plugs or connector very well, see the diagram
2) LUBE the deck belt, this could be happen to due the lack of maintenance, you must do it every weeks of use, use 100% silicone LUBE, and do it.
3) LUBE the rollers bearing with DW-40 with small quantity.
3) Tight a little drive belt motor, and replace if necessary, the tension must be 1/4" of flexibilit.
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for troubleshooting motor.
5) Test the output voltage board, for input voltage motor, if there are NOT voltage, the board is faulty.
see the block diagrams
God bless you
Nov 26, 2012 | RTO Image 15.0R Treadmill Walking Belt
Minutes go to 19 then go back to 0
go to www.polar.fi and download the instruction manual, for to fix the monitor.
sincerely. God bless you
Apr 24, 2012 | Polar RS200sd Running Computer Heart...
When I turn on the treadmill, the top console lights up, but the bottom half of the console won't work except for 2 buttons. The START button will start the treadmill at 1 mph (stop will not...
Jan 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
Does the odor treadmill measure heart rate without holding on to the grips
Are you sure you have the correct brand of Treadmill. Never heard of this one.
Double check your brand and model. IFIT is availalable on several brands and models of treadmills, it is possible that your treadmill only has heart rate grips and also possible it will do both.
Generally a treadmill that will work with a heart rate strap will say so right on the face.
Dec 05, 2010 | Heart Interface Ifit Treadmill My Progress...
No heartrate
Heart rate hand grips wiring bad or the Heart Rate board attached to the console board is bad.
Jul 03, 2009 | Life Fitness 91Ti Treadmill
Seeing heart rate displayed on my polar compatible treadmill
i didnt knwo my treadmill was compatible i just hooked up like i wanted to read from my watch and then both started to read...although the treadmill had a bit of a different reading
Jan 02, 2009 | Polar S410 Heart Rate Monitor
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
