Question about Canon Pixma iP2700 InkJet Photo Printer
I am not able to connect my printer ip2700 to my laotop
Printer status is showing offline.
    Guru:
  • 571 Answers
Have you tried changing the status to online by right clicking on the printer sign and pressing on online?
Is this your first time using your canon printer in your laptop? If it is your first time, then you need to install the printer's driver first.
Posted on Nov 27, 2012
Ip2700 cannon printer shows offline but its online
it basically disconnected from network you need to connect it again with network just look for wireless network wizard and the follow the option
skype id :Johnwalker800969
Sep 01, 2016 | Canon iP2700 Inkjet Photo Printer
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Idle printer status
If your computer is USB connected make sure that the cable is connected and that the printer is powered up. If you are connected to the printer over your network through wifi or ethernet, make sure that each device (computer and printer) is connected.
If all of these are in order and the printer still shows offline, try re-installing the software that came with the printer. Sometimes the software needs to be re-installed due to corrupted files.
Nov 24, 2013 | HP Computers & Internet
Status offline
offline means its not connected to your pc, check the cables.
Nov 21, 2013 | Canon Office Equipment & Supplies
Offline status
The most likely cause for this OFFLINE status on the PC is which interface is selected on the printer.
I think the printer defaults to Serial interface, so if you are using USB ensure you select the USB interface via the control panel on the printer, similarly if the connection is parallel ensure the parallel interface is selected.
If the connection is serial, ensure the cable is of the correct pin configuration and ensure the serial interface is set up correctly.
May 25, 2012 | TallyGenicom Tally 5040 Passbook Matrix...
Hp deskje d2360 printer showing offline error
On Printer and faxes, right click on your printer and unselect "Use printer Offline". If "Use printer Offline" is not select, then verify you USB cable.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 08, 2011 | HP Deskjet D2360 InkJet Printer
I checked everything, the printer is connected, there's ink, everything is good, but it says it's offline. I clicked "Use printer online", but it's still offline. I tried Refresh, and it's still...
The first thing I would check is the cable. If you're using a USB connection, try a different (and known to be good) USB cable. If that doesn't do it, you may have a damaged USB connection socket at the printer, which is not cost effective to repair.
Hope that's helpful.
Dec 31, 2010 | HP Deskjet F335 All-In-One InkJet Printer
Hp deskjet 6980 will not change to online. Working wirelessly. It says Offline and can't be changed to Online. I have to reinstall everytime.
Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
Aug 29, 2009 | HP Deskjet 6980 InkJet Photo Printer
Printer status always offline
go to your programs and select printer and faxes..rigth click your printer icon and select use this printer online..and if you want make this printer to be a default printer select also use this printer as default..
May 18, 2009 | HP DeskJet 3940 InkJet Photo Printer
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
Canon Pixma iP2700 InkJet Photo Printer Logo
61 people viewed this question
old marine
old marine
