Question about Hotpoint Washing Machines
Hotpoint washer Model VVSR1070DAWW won't drain
  • 5 Answers
SOURCE: hotpoint aquarius wf320 1200 spin
its blocked...try the waste pipe
Posted on Nov 14, 2009
  • 3 Answers
SOURCE: whirlpool washer model lsr8444lq0 fills with water
I had the same problem with mine . The problem was the timer.
Posted on Aug 01, 2011
heatman101
  • 43501 Answers
SOURCE: whirlpool washer model LSR5232LQ0 won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 22, 2011
oldTech2332
  • 2341 Answers
SOURCE: All cycles on my washing
The most probable thing causing it to not agitate is going to be stripped/broken agaitator coupler.
The video will show you to take out the agitator and check for a defective agaitator coupler
http://www.youtube.com/watch?v=N26MCQKuXn0
GENE
Posted on Sep 05, 2011
ginko
  • 19396 Answers
SOURCE: Won't drain. Blinking pause. Won't
Hi.
You need to check the drain filter, which is directly connected to the pump. That is the place where you usually find blockage. The filter or coin trap is located inside the drum. See the schematic below:
If that is not enough, then the drain pump access is located in the front side of the machine, hidden behind the trim at the base. The kick panel is held to the washer's frame by screws:
After removing the panel you will Be able to access the pump. Have a container ready to collect water that will come out through the hose.
DISCONNECT POWER before starting the job.
Here parts diagrams:
GLTF2940FS1 - parts catalog
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Posted on Sep 10, 2011
Htwp1---mww top load won't drain or spin
Lidswitch is what I would say Based on your model number posted.
The liswitch has 2 wires. a green safety wire and two live wires. Bypass the lid switch by jumping the 2 live wires as seen in this video:
http://www.youtube.com/watch?feature=player_embedded&v=XAnQ6Ovvnuc
Nov 12, 2012 | Hotpoint Hot Point HTWP1000MWW Top Load...
WASHER WON'T FILL WATER
Check to be sure the drain line is higher that the tub of the washer. You have a siphon going on the drain.
Nov 05, 2012 | Hotpoint Washing Machines
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
The washer broke filled with water and won't drain
see this causes and fix it. God bless you
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Sep 28, 2012 | Kenmore Washing Machines
All cycles on my washing machine work, but machine will not agitate. What are possible solutions to fix the issue? It is a Hotpoint, top load, model # is vvsr1070daww
GENE
Sep 05, 2011 | Hotpoint VVSR1070D Top Load Washer
My hotpoint 430 washing machine won't drain and very noisy when it spins.
first u check the water pump at the bottom side of the washer open it u will see a nub open it and u can also drain the water 4rm there but it will mess the floor up then if it continues contact ur engineer about the spin mayb the load in it is much or u set the washer balancing
Jul 26, 2011 | Tecnik TKL9260 Front Load Washer
Washing Machines Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
