Question about Lenovo Computers & Internet
I have a ThinkCentre Lenovo EDGE 71. To use the f1-f12 functions require me to first hit the FN button. How do I reverse this so that i can use f1-f12 by hitting them directly and have the current commands require me to hit FN first.
map9966
  • 2351 Answers
SOURCE: boot up and time/date/year issues
You are correct. There is a 3 volt battery on the motherboard. It may have come loos. This little battery holds all bios setting including the date & time. With the power cord unpluged from the Pc. Remove the side panel exposing the motherboard. Use your manual to help locate the battery. With the help of a flat tip screw driver remove the battery if not already removed & check it's voltage with a volt meter. Replace the battery, it snapes in.
With the side case off double check all power cables & data cables are connected tightly. Restart the Pc & enter the bios. Reset the time & date. As for the power strip & Pc starting. Try this. As soon as you turn on the power strip, switch the power supply's toggle switch to off. Loacated on the back of the power supply. Leave the power strip on. Give the Pc a minute. Now flip the toggle switch on the power supply to on. If the Pc begains to turn on press & hold the Pc's start button till the Pc shuts off.
Now turn off the power strip. Turn it back on. Pc should still be off. This is a reset for the PSU. Post back if you have more questions.
Posted on Feb 03, 2008
  • 202 Answers
SOURCE: Keyboard F1 to F12
F1 - F12 Function Key Usage
Printer Friendly Version
F1:Help. Click F1 Key can load the help file of the program.
F2:Rename. Select a folder or file, click F2 to rename it.
F3:Search. On desktop, click F3 to load the search form.
F4:In Internet Explorer, click F4 will list the URL Address field.
F5:Refresh. Use it to refresh the web page in Internet Explorer.
F6:In Internet Explorer, click F6 will jump to address bar.
F7:It can be used to insert ^C in command prompt.
F8:When windows startup, it can load the startup menu.
F9:In Windows Media Player, it can increase the volumn.
F10:In Windows Media Player, it can decrease the volumn.
F11:In Internet Explorer, click F11 will switch to Full Screen mode.
F12:In MS-Word, it will show out the "Save-As" dialog.
Take this link u will get all the Function Keys description
http://www.computerhope.com/issues/ch000306.htm
Posted on Sep 01, 2008
DickCanFixIt
  • 948 Answers
SOURCE: How do I find the functions for F1 -F12 buttons
Those functions are not set by the operating system or the keyboard, they are set by individual software programs and could have a different function for each program. Typically F1 is help and F5 is refresh.
Posted on Jul 21, 2009
  • 3278 Answers
SOURCE: lenovo thinkcentre a51 reboots with several beeps
Your problem is hardware-related. Either memory or power supply.
Remove the memory and add back one at-a-time and boot to see which one (if any / either) is bad.
If not, the second culprit is the power supply, which would need to be replaced.
Hope this helps.
Posted on Aug 04, 2009
  • 63 Answers
SOURCE: when i power on the hp 530s pc it goes straight to
Hello!
You have jumper at the motherboard, or at some comp. more switch, or you can take batery from motherboard about 1 - 5 min. When you cler cmos, password can´t be a problem.
Posted on Oct 30, 2009
How to enter bios Lenovo ThinkCentre M82 3302B2U
Press F1 or F2 after powering on the computer.
Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Goto this link for more information:
http://support.lenovo.com/en_US/detail.page?LegacyDocID=YAST-3JWKJX
GuruAid
May 01, 2014 | Lenovo Group Limited 3302B2U - Lenovo...
C772tu s-video tv out no output
I assume you are going from the laptop to the TV using a s-video connection. Take the tv remote and click Select Input. Change the input source to S-Video. Reboot the laptop.
Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 22, 2012 | Computers & Internet
Can,t connect to tv with hdmi cables
Why not? Did you take the remote to the TV and click Select Input, then select HDMI?
Did you reboot the computer after you connected the cables and selected hdmi on the tv?
. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 17, 2012 | Computers & Internet
Hp g60-214em screen wont come on hdmi still works when windows running but screen isnt
Try toggling the screen. Normally when you toggle the screen it has 3 stages for the display. 1. Laptop only 2. TV only 3. Both Laptop and TV
May 16, 2012 | Computers & Internet
Can't display with my laptop using VGA to 3RCA cable
Can't display where on another monitor or tv? Did you reboot the computer after plugging in the VGA Cable. Sometimes you have to hit the FN Function Key + F1 thru F12 to get the image to display. The correct F1 thru F12 key will have CRT/LCD on it or it might have the icon of a display. Press and hold the FN function key then hit the correct F1 thru F12 Key.
Mar 29, 2012 | HEWLETT-PACKARD ProBook Computers &...
How do I turn wireless capability on my acer aspire 5560. I can't find it anywhere
somehow my my acer aspire 5560 decided to turn off wireless capability by itself ... thank goodness i jumped onto the desktop computer and typed into Google " How do I turn on my wireless capability on my acer aspire 5560 ' your directions were spot on ... I dont know anything about fixing computers , so i just want to thank you for your simple instructions that helped me to get my laptop functioning again perfectly ... on my laptop the keys were FN (funtion Key) & F3 ....... much appreciated !!!!
Mar 21, 2012 | Acer Computers & Internet
(Fn) key function
Fn or Function key is used for your F1 up to F12 keys. Ex. Fn+F5 is to turn on the wireless capability. Fn key is like a shortcut for the functionality of the machine. You can also adjust brightness by pressing Fn+Up or Down arrow and for the Volume Fn+Left and Right arrow.
Apr 29, 2011 | Lenovo IdeaPad Z360 Notebook
I have a dell inspiron 1564. To use the f1-f12 functions require me to first hit the FN button. How do I reverse this so that i can use f1-f12 by hitting them directly and have the current commands...
You can change it so you don't have to use the FN key by going into the settings while you computer is booting.
Reboot your computer
Keep hitting F2 until a greay and blue settings screen comes up
Choose the Advanced menu
Use your arrow keys to go down and select 'Function Key Behavior'
Hit enter
Select 'Function Key First'
Hit enter
Choose to Save and Exit (usually F10)
Should fix it up.
Shaun Thomson
Billy Goat Karaoke
Aug 30, 2010 | Dell 0Y3740 Keyboard
How to set boot priority in bios is thinkcentre lenovo it has no option in bios
when i am enter in the lenovo bios in bios option have four option for first boot device. which i am select.
Oct 21, 2009 | Lenovo ThinkCentreĀ® M55-8810 PC Desktop
Computers & Internet Logo
49 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
