Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Installation of windows xp on vista
I have purchased a compaq presario CQ60-104TU, with windows vistalled and now I want to install windows XP Professional SP2 in it but when I am booting from bootable XP CD it is not working. Please let me know the procedure how to convert vista to XP
    Scholar:
  • 61 Answers
Try booting from cd and delete the partitions on all drives because your harddrive is factory formated and reformat hardrive partition to nfts then it should work if not try to find someone with a windows me boot up disc or a program that does delete the partition and then delete the partitions then goto the xp disc to format to ntfs and that should do it for you.
Posted on Jan 10, 2009
    President:
  • 2,692 Answers
Reformat the hard drive first using. Take VISTA off.
2 Suggested Answers
  • 33 Answers
SOURCE: FORMAT MY LAPTOP
I like to use a cool utility calle System Rescue CD.
You can download it from: http://www.sysresccd.org
You want to download the 'Stable version for x86'. The filename should be: systemrescuecd-x86-1.1.5.iso
Burn the downloaded .ISO image to a CD using a utility such as Nero, then boot your computer from that CD exactly the same way you'd boot from the Windows CD.
Just hit enter at all the prompts to accept the default values. Once you get to the command line, you should see instructions for running 'GParted'. You should follow those instructions. I think you just have to type:
gparted
At the command line, but you may have to do some other step first. This will run a graphical partition utility you can use to delete your Windows Vista partition.
Posted on Feb 12, 2009
Install windows xp in compaq presario cq45
There is no drivers for Windows XP for this notebook, only Vista and Windows 7. My advice is to install Windows 7 - it works just fine.
Oct 21, 2010 | Compaq Presario Notebook
I want to install xp by removing my pre installed vista in presario cq61-132tu. and there is no option of sata in bios so plzzzzzzzzzzz help me. i want to operate only xp means i m not want to install both...
Put XP disk in CD-ROM and reboot the computer.
Click yes to install XP. It will tell you there is a system already installed on C drive. You select to install XP on C drive. It will ask if you want to format C drive, you select full format.
XP will then install
Sep 24, 2009 | Compaq Computers & Internet
Changing Vista to XP Pro on a Compaq Presario SR2180NX Desktop PC
SR2180NX has the Vista 32Bit OS from HP. The restore partition will always put Vista 32Bit back on if you use it. Windows XP can only be put on from scratch and I have done it while I still have Vista installed. One problem: there are no XP drivers under SR2180NX webpages. Do your research on the parts that are installed in the 2180 and any other HP machines that have the Windows XP operating system as the OEM OS. But First, check the Intel Site for the 945 chipset drivers (include the SouthBridge, too) under XP. Get them downloaded to a CD and burn the rest of the drivers you find for XP on the same CD. This way, you will have them ready when you are performing the down-grade to windows xp. After you are done with the XP install, you will still have access to the files & work you had done while in Vista. The Vista files are still readable. You might want to consider getting the Windows 7 Professional (not basic) available October 22, 2009. AND you will still have to get the Intel Downloads for Win7 any way, so why not make it a project and make it last for a few years. XP Support stops in 2014.
Sep 07, 2009 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
Windows xp installation problem
You might need to use the "Floppy" version of the Driver upon install (if you know what the chipsets are. Most likely it's Intel and you can slip stream the driver files into a new XP CD.
However if a partition is formated from Vista and you attempt to install XP over it without formatting it, crash is almost certain - XP and Vista have different versions of NTFS.
If you want both XP and Vista on the same machine, ALWAYS install the older one first! i.e. XP first. And create only 1 partition in XP where you intend to install on.
Then install Vista afterwards with Vista created partition.
May 23, 2009 | EliteGroup RC410L/800-M2 (V1.0)...
Want install windows on compaq presario c700
you can install xp from any xp disk as long as you have a valid xp key.if your pc was purchased with xp installed you probably have a valid cd key on a sticker youll find on the underside of your pc .if you aint got one go into any pc shop and look for a pc installed with xp(theyre all pre-installed with either xp,xp pro or vista) on laptops look on the underside and write down the number on towers look at the sides near the bottom.if shop assistant ask do you need help say no just looking and taking down some details cos thinking of purchasing,
Dec 21, 2008 | Compaq Presario C700T Notebook
Installing windows xp to compaq presario 700 pc notebook
HP Compaq Presario 700 series was originally designed for XP and Vista, therefore you can install XP on it.
After installing Windows XP, you will need to install all drivers.
You can download drivers and software for your laptop from HP here.
Oct 07, 2008 | Compaq Presario 700 470024-192 Notebook
Drivers problem
i have been problem for driver on my notebook laptop c765tu model plz solve it
Sep 09, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq C751NR need windows xp - conexant HD audio smart audio 221 driver
i just purchased a compaq presario c700 and the audio is not working. the device is conexant audio smart audio 221..any help would be greatly appreciated.
Jul 31, 2008 | Computers & Internet
Sound Driver of a Compaq Presario C700 Notebook PC
I have installed winxp on my new hp presario c700 laptop, but i have no drivers of said laptop for winxp. Will you help me find those drivers?
benjie
May 09, 2008 | Compaq Presario 700 470024-192 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
104 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
