Question about Nikon D3100 Digital Camera
I have a flashing red square in the screen and the camera will not focus
Red focus squares show on pictures
Disable the "AF Point Display" in the menu.
If you need a manual, you may download a copy at Owners Manual User Guide for Canon EOS 60D Digital Camera EOS60D pdf
Sep 25, 2016 | Canon EOS 60D Digital Camera
Focusing problem
Perhaps your only option is to send it in for repairs .
Sep 07, 2015 | Cameras
My samsung es80 does not make sharp pictures anymore
Difficult to go on only does not make sharp pictures anymore.
Seeing one picture says more than 1000 words. Still I give it a try.
When you are sure you did not change the focus settings and don't switch over to macro settings, while shooting normal, I can't help. But I do advice to look in the manual on page 41 and put the camera in Auto focus. (Not one of the macro modes) then when shooting, wait till the camera has focused, while you pressed the shutter realise button half. When the camera is in focus, the square in the middle of the screen becomes green, press the button down. (without moving the camera)
Also select a high resolution (big photo size) because small photo size is easy seen as a blurred picture.
Success
Feb 17, 2014 | Cameras
My canon rebel xsi is not letting me take a picture on auto focus
It is possible you are trying to focus on somethind that is either completly white or completely black. It has trouble focusing in the dark as well. make sure your auto focus point (The red dots in your view finder is in the centre. you can move the red dot with the button on top of your camera that looks like 4 squares. simply look through your viewfinder push the shutter button down half way and the red dot should flash. if it isn't in the centre then move it with the button on top (4 squares) and try again until you get it in the centre.
Aug 16, 2010 | Canon EOS Rebel XSi Digital Camera
Out of alignment (red)shadow
Ur tv convergence are dead.U must know how to solder.U must have soldering tools,and solder to fix convergence problems.Must repalced 2 STK convergence ICS and some or all it resistors.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 15, 2010 | Sony KP-57WS500 57" Rear Projection...
Focusing problem with canon 5D and 20D
Go to the support section of the Canon website to download a copy to your computer.
Dec 16, 2009 | Canon EOS-5D Digital Camera
Hi I bought this camera Fujifilm finepix s10000 fd in order to photograph sharp and clear close up pictures the best way I can. When I press the Menu/ok button = nothing happens. It simply does not...
if your wanting to do macro photography (close up) on the dial on the back, click the left button on the circle and a little flower should pop up on the screen saying "Macro, close up shots" this is for pictures that are closer up then regular and U want them in focus. it takes a few times to get it focused a few times but when it is focused properly, the square in the middle of the screen should be red. if you want really close up, click the button another time and the flower should come up again and it should say "macro close up shots up to 2cm (0.8in). once again once its focused properly the square will be red. you will have to practice because it takes time to learn where its proper focusing points are but i'm sure you will get the hang of it.
Aug 04, 2009 | Fuji FinePix S1000FD Digital Camera
SD550 camera not focusing correctly. Green focus square sometimes shows up, sometimes not, either way, it's not clear even on the digital screen prior to taking the shot. Camera does make a slight click...
to make the green square show up just press the shutter button until half (this is called the half press) when the green square shows up then it means that the camera has focused already, if not repeat the process til green square comes out you can press the shutter button fully to take picture when you see the green square...
Jul 06, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Flashing red square area in viewfinder.
No, I don't think so, there could be differences between the Auto and the P setting. But the red flashing is where your camera is currently focusing on. It's possible that the black was indicating the focus box, but it was not latched on to something with complete focus, which then is indicated by the red flashing. Check this link to read up further on this. I may not have pinpointed it exactly, because I have a D70s, but that's what I found so far. You'll maybe have to reset everything and see if it's still there, otherwise, it's a setting. =)
Nov 20, 2007 | Nikon D40x Digital Camera
Nikon D3100 Digital Camera Logo
51 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
