Question about KitchenAid Refrigerators
Sealing flap on model kfco22evblo won't close
Top hing has serrated from door. How to repair
22yooper
  • 828 Answers
SOURCE: self closing door hinges
This is not a refrigerator problem BUT, you must insert a tool like a drift punch into one of the holes on the top of the hinge and rotate it away from the door position then reposition the holding pin to prevent it from recoiling.
Posted on Jun 28, 2008
buddymcl777
  • 67 Answers
SOURCE: freezer door not sealing
replace the seals and / or have the hinge adjusted
Posted on May 01, 2009
aasc
  • 1606 Answers
SOURCE: GE ice dispenser door hangs down
You should replace the dispensor solenoid and plunger due to rust . Very common problem with G.E.
Posted on Jul 11, 2009
aasc
  • 1606 Answers
SOURCE: ice dispenser door flap will not close.
Remove the top freezer hinge hover on top of the freezer door . Unplug the receptical there ( this will remove power to the door only ) .
Using a small screwdriver at the "crease" on the bottom of the dispensor control board inside the dispensor , twist slightly to disengage the 2 clips ( 1 on each side ) holding the dispensor board . Unplug the 3 connectors from the board . 4 screws ( 1 on each corner ) hold the dispensor housing shield . Remove these 4 small screws . After removing , at the top right , you will see a solenoid and plunger . These are probably rusted , holding the flap open . The part number for the solenoid and plunger is WR62X10055 . 3 screws hold this part on . When reinstalling the dispensor housing , It slides back on 2 "grooves" so make sure it is back in place , or the board will not snap back on properly at the bottom .
Posted on Sep 02, 2009
  • 415 Answers
SOURCE: How to adjust door hinges on fridge
on the door thats sagging on top of the of the door is a cap some have a screw holding it....if not use a screwdriver at the back of the cover and pop it up then you have small bolts some have 2 but most have 3 just loosen up but no need to remove then pull towards the hinge to see it move again move to the to where level you can place something in the gap between the door or have someone hold the door in place then reverse order to complete
Posted on Sep 06, 2009
Testimonial: "Thank you. I just fixed the problem singlehandedly with yor helpful instructions!"
Good day! The center flap (vertical hinged flap) no longer rotates back in when closing the left door. Result: the flap remains "out" when closing the door thus banging up against the right door.
Their is a factory issue on some models call the factory to see if your unit is a defective unit. Other wise the door flap has to be replaced. Not cheap..
Oct 30, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
How do I realign the fridge door with a top mount freezer
The top to bottom alignment is done by moving the hinges up/down. On many models there may also be plastic spacers on the hinge pins you can use to adjust the height.The closing of the door so it shuts properly and is flush on all 4 sides is done by adjusting the screws that hold the door gasket in place. If you've never done it before it can be a real pain to get it right. Make small adjustments to the screws and if need be grab the door at the center top and center bottom and give it a small tug in opposite directions to get it straight, if you have to. To test if its closing properly, look at the edge of the gasket all around it should be the same distance from the body of the fridge, use a mirror to see the bottom. To test if its sealing properly use a dollar bill. Close the bill in between the gasket and the door in areas all around the door, When you pull on the bill you should feel resistance, if the bill is not held in or pulls out easily the gasket is not sealing properly at that location, you need to adjust the screws to get it aligned better.
Feb 26, 2015 | Refrigerators
Oven door not sealing correctly on our A106G Delonghi oven. It is sitting out slightly at the top
One of the door hinges may have come off track at the base of the door. Need to release the clamp on both hinges and get the door out for inspection.
New hinge can be got from
Delonghi Male Oven Door Hinge
Sep 03, 2014 | Ovens
Ge monogram 48 built in refrigerator
If the seal to the top freezer is not sealing properly, this could be a matter of door adjustment. This a common refrigerator/freezer problem. The correction consists of loosening the door hinges and adjusting the seal for eveneness then retightening the hinges
Jun 27, 2013 | Refrigerators
I have a frigidaire stand up freezer model #lffh21f7hw, and the door isn't vacumn sealing the door, why?
If you have too much weight in the door or someone pulled down in the door, it gets twisted. Try lifting up on the bottom outside corner of the door to straighten it up. You might have to loosen the top hinge to reseat it.
Jan 17, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The interior lights wont turn off. they melted the old light bracket so i replaced it and the lights still wont go out
It sounds like you have a switch that isn't closing when the door shuts. I'm not overly familiar with the LG's, but looking at the Sears Parts Direct site, it looks like the door switches are in the hinge covers on top of the unit. There should be two of them, one for each door. But, only one has to not be working to keep the light on. The first thing I would check is to make sure the hinge cover isn't loose or out of position. The switch should close when the door closes. If the hinge cover moves, then the switch won't close. If everything is tight and aligned, then one of the switches is bad. That can be checked with a volt meter that does continuity checks. Unplug the unit before checking because those wires should be hot at all times. If you don't have a meter and want to do trial and error, just buy one switch since they both are the same. Here is the parts diagram showing the switch locations and part numbers:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LFX25960ST/3204/0161000/K0810255/00001
The switch is 402A on the diagram, located on top of the box. If you click on the parts diagram, you can enlarge it to get a closer look.
The switch part number is 6600JB3007E
Hope this helps
Aug 11, 2011 | LG LFX25960ST Stainless Steel French Door...
One of the hinges on the door seal has come off and the door will not close properly. Model #KFCS22EVMS This model has the sealing mechanism on the left door where a small panel slides into the body...
Open the little metal screw on the larger hinge that is between the top and bottom hinges. This will allow to pull the seal all the way out. There is wiring behind that middle hinge so watch not to damage it. Then , you can realign the 3 hinges in their place and replace the screw in its position. It takes a little bit of patience to realign the 3 hinges but it's very doable.
Dec 23, 2009 | KitchenAid KFCS22EVMS Stainless Steel ...
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
