Question about RCA RT2250 System
I have a RCA RT2250 and I have a green light on a circuit board
The green light comes on when first turned on than goes off after a few mins. When light is on I get static out of the sub and DSP modes but after the lights off I get sound out of front L-R and sub. Also power button does not work most of the time but goes on by tuner button.when turning on from demo mode the system shuts down after a few mins, but turn demo off and push tuner it will stay on.No sound comes through rear or center chans though. Im wondering if it could be the chip by the light that says CRYSTAL CS4226-KQ and how can I test it and what is needed. I am also not sure how you find part #s.I would apreciate any info any one would have about this problem or the system,if it is worth fixing etc... Tanks for your time.
  • 336 Answers
Check the solder connections on the seven voltage regulators found in the center of the receiver on the heat sink from front to back (not the amp board) they are on the main board. The green light on the DSP board (back right side) is an error light. You can reset the receiver by pushing power then stadium then night then dsp off then club after unplugging the receiver and plugging it back in.
Hope this helps,
Posted on Jan 11, 2009
Rca hdtv 52inch will play fine then picture goes black but still has sound.. after a few mins.picture will come back on , and will play fine could last all day or may go out again in a few mins.
My tv is relatively new, but the bad thing is that I had an old; big screen tube type rca model; home theatre, that was heavier than a car, and it went out, due to the cracking and popping sound, off sometimes, and back on.
What is strange is the new tv now, the hdtv, light weight, about five years old, is doing the same thing. Actually, now, the power will not even come on. The lcd green light in the front goes on and off.
Take no offense, but I thought I would not have these problems anymore. What do you suggest?
Feb 16, 2010 | RCA HD52W59 HDTV Projection Television
When i unplug my rca rt2250 home theater system. the green light comes on on the right side. then goes off. everything works good after that speakers sound good. but once in a while that green light comes...
this is the amp IC and while unplugging and plugging it in again helps reset the IC for a little while , it will eventually completely quit and will need replaced
make sure that none of the speaker wires(bare wires) are touching or look like they might be where they are connected at
also if turning up the volume makes it cut out or sound bad then this will also indicate a bad amp IC
Mar 12, 2009 | RCA RT2250 System
RCA D52W20 52 in. Rear projection hdtv problems
Check 3 capacitors on Power supply/deflection board cp150 2200uf 16v if it is bad replace 2 other caps in same circuit cp111 cp114 220uf 35v
Dec 01, 2008 | RCA D52W19 52" Rear Projection Television
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
A repair question for the RCA M50WH74S
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Aug 18, 2008 | RCA HD52W56 52" Rear Projection HDTV
TV will not power up
Opened up the back and vacuumed out all the caked on dust that was everywhere. I used an insulated brush to help remove the dust. Dust can kill heat dissipation. Open up the front and check for fluid under the CRT circuit boards. The one on the right (as you face your TV) is the blue one. For some reason, the diaphram for the glycerin in the blue optic is on the back side and leans down. It tends to leak and spill on to the circuit board below. Some symptoms I noticed: blue shadow, blinking blues, complete blue outage, unable to complete the autoconvergence, and arcing/sparking (from another post). I had to pull out the blue CRT, silconed the rubber gasket, refilled the fluid and repaired some solder joints where the fluid caused a short. Works like a champ now. Tell tale sign is the pool of fluid when you access the front chassis. Pull off the speaker grill and shine a flashlight on the inside underneath the CRT circuit boards and look for the fluid. Glycerin doesn't dry.
Dec 10, 2007 | RCA D52W19 52" Rear Projection Television
Rca Rt2250
just want to know how I can hook up my 8 ohm speakers to this receiver
Nov 13, 2007 | RCA RT2250 System
RCA RT2250 System Logo
370 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
