Onida xaria 22 lcd tv power indicator toggle red and blue
On power on tv, power indicator toggle red and blue and tv remains off. after repetedly pressing power button on remote no response from tv. please help.
SOURCE: new Sceptre 37" LCD TV does not turn on
I just got a 42" komodo by Sceptre, same problem, except "SCEPTRE" showed on the screen. I was sent a USB key program to insert in the service slot in the back and it reflashes the bios. This is old news for you but maybe new for someone?
Posted on Mar 29, 2007
  • 191 Answers
SOURCE: Tv doesnot power on
two options _bad backlight inverter or the main board ;eed to be change.
Posted on Nov 02, 2008
SOURCE: Element LCD tv model: FLX-3210
I just checked and my tv was purchased with a credit card that gave a double warranty. I have to fill out some things but it should be fixed eventually...
Posted on Feb 13, 2009
SOURCE: Power on problem for My Syntax Olevia LCD TV 23"
I have a 24" Olevia LCD TV. Same symptoms (Stdby LED is on, press power and it flashes off, then back on). The USB cable to the Service Port also worked. But being of sound technical mind, I figured this means that the PC is supplying the +5v to the circuit. What I did was disassebled the TV, carefully disconnected all the cables, and opened it up to reveal the circuitry. I looked over the circuit and noticed the 1000uf/16v capacitor at position CS21 was failed and bulging. I removed the cap, tested it and verified that it was indeed failed. I went to a local Radio Shack and picked up a 1000uf/35v electrolytic, after all, the value is what mainly matters as long as it's not lower voltage than the original. I replaced the new CS21 capacitor back in the circuit (it is polarity sensitive, so pay attention to what the original mounting position is). I reassembled the TV and Viola! Works! No need for the USB cable to the Service Port!
I hope this helps someone!
-Matt
Posted on May 18, 2009
  • 9 Answers
SOURCE: INSIGNIA LCD won't turn on
replace 2 condensers in the power supply with greater voltage ones.original are 1000uf 35volt...use 1000uf 65volt...99cents each
power circuit is made to fail with typical tv industry tactics...the warranty is reflected by the life of their condensors (capacitors) average life is 2000 hours..
easy...huh
if your a smoker...you must clean the button cover as they get stuck on with your stupid tobacco residue. 75% of all LCD tv's that smokers own fail this way...
\tough huh?
TRY TO STOP SMOKING...
Polaroid TV screen will not always come on.
Are you talking monitor rather than tv? I have an LG 22 inch monitor and the on off button is on the bottom, If I don't hit it right or just tap it, it won't turn off but flashes. Where do you have it plugged in? Is it with some other electronics, or right to the wall outlet? I'm really at a loss as to what your problem really is. Are you using the remote? One quick fix might be the battery's in the remote. If they don't have enough power, short or no signal will be sent to tv or not being able to decipher it.
Feb 05, 2015 | Polaroid 4011-TLXB LCD TV
Saound OK no light on Onida Xaria 22 LCD
Check and rectify fault at its back-light inverter board. Contact any service technician. This is not a user repairable fault. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 29, 2014 | Televison & Video
ONIDA 22"LCD
There could have been a power supply failure.
Jan 10, 2014 | Televison & Video
I having problem on onida xaria lcd tv that tv is on standby mode but wouldn't turn on
Change the battles of your remote and then check if not then its need to be service
Dec 16, 2013 | Televison & Video
LG55LH40 LCD TV wont come on
The set will need to be properly diagnosed. It could be a defective main board or power supply.
Sep 01, 2012 | Televison & Video
I wish to know the input voltage given to Onida 32 Xaria board
Only the correct replacement board should be installed--another even if similar looking will not work.
May 27, 2012 | Televison & Video
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Hello
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
Feb 04, 2012 | Televison & Video
Element tv.. model # ELCHS261 stopped working
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
Jul 10, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Aug 31, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
