Question about Sennheiser ew 300 IEM G3 In-Ear Wireless Monitor System
Ew 300 IEM G3
• I was using a new ew 300 IEM G3 in an outside Gig with 3 other 200 IEM G2 units. The G3 system was receiving interference that sounded like pink noise with a very loud finish. The interference lasted about 5 sec and then the system returned to normal. The interference was only present on or near the stage 10+ meters from the stage all was OK The system was within 2 meters of a Speaker stack of Mackie subs and an array
  • Peter Colls Nov 29, 2012
    Some other notes: The loud pink noise sound lasted for about 5 secs and finished with a loud pop. the G3 then returned to normal reception for about 30 sec then the pink noise started again. this cycle continued while the G3 was on stage. Remove the G3 to the sound tent and it was perfect. All levels were correct.
4 Suggested Answers
  • 5603 Answers
SOURCE: Some Headphones have an inherent
Hiss is a problem of statistical noise in electronic devices due to the laws of physics plus circuit design.
One thing to do is to improve the signal to noise ratio (SNR) by properly setting gains. It is POSSIBLE that the IEM's you are using are too low impedance for the receivers resulting in you having to use excessive gain at the receiver. Your receiver gain control should not have to be above 60% of the way up. If you are above that, the ear buds are probably lower impedance than the receiver is designed for... and remember the manufacturer will LIE on the capability of the thing they are trying to sell.
The receiver is speced at 32 ohm drive... IF your ear buds are less than that impedance, they are NOT suitable. Conversely if they are too high, thaat will ALSO cause you to turn up the receiver gain too much and result in poor SNR.
You want to make sure the transmitter is being driven at line level so receivers get adequate input audio so gain doesn't have to be run too high.
Posted on Jan 04, 2011
Ironfist109
  • 3018 Answers
SOURCE: the ew 3000 iem (brand
To get your transmitter out of mute press the standby button and hold it briefly until "RF Mute Off" appears. Your display should change from red to orange and the transition icon will also be displayed again. This indicates your transmitter is transmitting.
Regards, Tony
Posted on Mar 24, 2011
  • 5603 Answers
SOURCE: I feel that the 'normal'
No, that will not help. The his is a function of the receiver NOT receiving a signal from the transmitter as they apparently do NOT have a "squelch" circuit to mute the receiver noise when no signal is being received. The noise level when no signal is received is pretty high and apparently the volume control is not enough to reduce the hiss.
To solve this, LEAVE the transmitter ON and make yourself a switch at the receiver. DO this using one of those little in line lamp switches that fit on zip cord. Make one on a short length of zip cor with mating connectors to fit the received jack and the headphone plug. Don't worry about unshielded wire as the impedance is very low. Then you use this switch to mute the headphones when you want to. There are other switch types you can use, I am just suggesting what might be readily available to you.
Sennheiser SHOULD have include a mute switch on their unit as turning the power off on the receiver would be a pain. They could have used a volume control with switch to kill the audio line out... simple solution... oversight on their part.
Posted on Mar 25, 2011
We have a problem with the lead that plugs into the receiver, and it has a shrowd over it that screws it in tight. the other end has a 90 degree angle with a mini plug into our camera, can we buyt that...
The lead is probably special. Your choice is probably to go to Sennheiser parts or make your own. The connectors are available. It sounds like the one plug is a 1/8 inch with locking ring... Those are hard to find. Contact Sennheiser to find their part number. 1-877-736-6434 ext. 1
Sep 05, 2011 | Sennheiser EK 300 IEM G3 Portable Personal...
The audio drops out. intermittently. seems to be related to the movement of the speakers head, but not conclusive. i tested the mike by plugging into a computer. it did drop out a couple times, but again ....
Wireless audio devices are subject to interference. You are a SECONDARY user of the frequency band and hence must put up with being interfered with AND should you cause interference to a licensed service, you must cease using the system. You should try other channels on the unit to see if you can find a clear channel that will not drop out. At UHF frequencies, reflections and change of positions and surroundings can cause dropouts of a system like this. Plugging into a computer is SURE to cause problems as they emit nterference at a multitude of frequencies in operation. Best to NOT have a computer operating in the area of the receiver for this system. In the back of the manual of all of these devices and computers is a note for FCC complaince regarding interference... few read it... but you should as it is the official, legal, position about RF interference between services.
Aug 14, 2011 | Sennheiser SK 100 G3 Mic Wireless UHF
Hi, I have a new Peavey Escort 3000 PA, more than happy with it, however in the last few sessions, including a gig today, the sound cuts out completely and the green LED on the unit just flickers. I...
It sounds like the power supply is overheating, or an interconnect is becoming loose due to excess heat. This might be due to a faulty heat sensor, but counter-intuitively could also be due to a low voltage supply, that is, drawing more power than the circuit can handle so the voltage drops. Please check that the outlet(s) you are plugging in to are rated to supply enough power.
Aug 29, 2017 | Peavey Escort 3000 300 Watt Portable PA...
I'm having problems with my new Shure SLX Wirelss system. Actually their RF is very dissapointing. Confirmed that frequencies are correct for my country and did try themin open areas or on unit by unit...
What range are you trying to use this over and what environment? They claim 300 feet but this can be reduced by absorption. Are you using mics or instruments? What are you observing as problems?
May 12, 2011 | Shure Distribution Shure Slx Wireless...
I feel that the 'normal' background hiss is a problem that I would like to minimize with the sennheiser IEM 300. I'm currently using the IE 4 ear phones. Would a different/better earset with maybe a...
Mar 25, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
The ew 3000 iem (brand new) is stuck on mute. Tried everything to no avail. Ideas????? Please Help!!!???!!!!
Regards, Tony
Mar 24, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
How do I un mute the pack
It looks like the mute function is only available from the menu... not very user friendly at all... I guess they figure the performer doesn't need to mute easily or quickly... Volume control I suspect is all that is readily availab;le at the pack to quickly mute.
Mar 13, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
Disturtion in one left channel and bad quality in right channel
Make sure you are NOT overloading (clipping) due to excess signal into the transmitter end of this unit. Reduce the gain INTO the fixed unit and see if the sound improves.
Feb 23, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
Some Headphones have an inherent hiss noise when they are connected to my wireless sennheiser EK 300 IEM G3 receiver. It seems to be a problem particularly with high-end IEMs which are highly sensitive...
Jan 04, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
Having bad feedback on amp when i use my senniser ew 100 system and loose volume
You can try to decrease the output from the EW-100 receiver on the back.
regards,
Gerard
Aug 16, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Sennheiser ew 300 IEM G3 In-Ear Wireless Monitor System Logo
Top Sennheiser Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Sennheiser Music Expert? Answer questions, earn points and help others
