Question about HP Pavilion dv9000z Notebook
HP pavilion is "chirping" how do i get it to stop?
The mute button flashes from orange to blue and back again, then both colors. It chirps when it does this. I seem to need to update vist or hp itself inorder to get it to stop then i am also crossing my fingers. any ideas.
    Genius:
  • HP Master
  • 1,102 Answers
Are you running vista now
Posted on Jan 19, 2009
I have an HP Pavilion dv7. Suddenly I have no volume. The mute light on the keyboard is orange and won't change to blue when I tap it. The mute volume icon at the bottom of the screen indicates that it...
Candy,
First thing is first, Thank You for visiting our site!
The problem you having is a HARDWARE issue with that push button interface in that HP.
what you can TRY
1. Take the batteries out of it
2. Unplug it totally from power
3. Pu the battery back in then power it on
4. Then push that button
If those steps do not work the laptop will need a new interface touch board. What is happening is its not recognizing your trying to turn the mute off.
The mute is off in the operating system DOES not construe for a fact that the issue is resolved if the button is still orange.
You will need a new touch board if the reset does not work.
You might want to contact support.hp.com to have them send out a tech or have it repaired by a authorized HP repair center in your area.
I hope you found this information Helpful!
Regards,
Rulds2008
Mar 22, 2011 | HP Pavilion dv9000z Notebook
How is the chirping sound turned off?
1. Open Hood (ground blue hood pin wire if no hood pin switch is installed)
2. Turn Key to the ON position
3. Press program / valet button 5 times, after a few seconds the unit will flash the lights 5 times.
4. Push the valet/program button 18 times. You must get a light flash after each button press.
5. Press the LOCK button to turn chirp confirmation off.
6. Turn Ignition OFF, Close hood (or unground blue hood pin wire) and check for changed features.
Dec 28, 2010 | CrimeStopper SP400
I have an HP Pavilion Entertainment PC and my computer has recently started beeping several times in a row off and on throughout the time I have it on. Occasionally the mute button will flash going back...
i believe that's memory issue,, either the memory modules are recessed improperly or modules may be bad . if you can give me the model and S/N of the computer i can figure out the beeping precisely
Oct 31, 2010 | HP Computers & Internet
I have an intermittent chirping sound coming from my hp pavillion laptop. What's causing this?
there are only two kinds of moving parts in a computer that may cause a chirping noise:
- the hard disk: you better make a backup of critical data on your hard drive
- the fan: less critical since the data on your disk is not affected in case of a break-down, but annoying nonetheless. attention: a broken fan may cause the CPU to overheat. in general the pc turns itself off in case of overheating, but if it doesn't, the CPU may be damaged severely.
Sep 27, 2010 | HP Pavilion dv4000 Notebook
Volume button mutes and unmutes randomly....causes a chirping sound
the black flat cable which is connecting front pannel to mother board will be faulty try replacing that
aris
Mar 11, 2010 | HP Pavilion dv4000 Notebook
I have a HP Pavilion dv7-1232nr, the mute button and the wireless button on the top touch pad has quit working along with the volume slider. Any suggestions?
My mute button on my hp pavilion dv7-1262us stopped working after I updated my IDT High-Definition Audio CODEC through Microsoft update. The volume worked but the button stayed orange. I went to Device Manager- Sound,video and game controllers then IDT Audio CODEC. Click the Driver tab then click the Roll Back Driver button. This rolled the driver back to an older version but it fixed the problem. This is a Vista machine. Hope this helps.
Mar 06, 2010 | HP Pavilion DV7-1232nr Notebook
I put in a new battery and the alarm remote does not work
Couple of times when you replace the remote battery, you might have them not working/ responding but just follow the procedure below.
Stand close to the car, hold down the open and close knobs for about 10 seconds. Press them at the same time for 3 seconds; then press the open button as the car opens.
The above procedure is applicable to a lot of car brands. It does not matter how many knobs you might have on the remote fob.
I have carried this procedure out on a lot of brands ranging from Honda, Toyota, Rover, Ford, etc. and it works perfectly well.
Good luck and Rate this.
Cheers
Dec 30, 2009 | 2001 Jaguar XJ8
I bought a new Keyless remote for a 2007 Forester from a Subaru Dealer to replace an original one that went bad after 2 years. I have followed the directions in the owner's manual to program it, but can't...
IMPREZA: 2005, 2006, 2007 and
FORESTER: 2005, 2006, 2007, 2008
Check for Immobilizer key on Forester XT models only.
information is always subject to change and correction imp05keylessremote1.jpg
new remote for 2005 Imprezas.
This is not the same remote as the 05 Legacy/Outback remote which also has truck/gate release on the front and a red panic button on the back.
Lock: press Lock button for 2 seconds or so to lock car, and arm optional security system. The car with chirp once and turn signals flash for locked, 5 short chirps and signal flashes if any door is not fully closed. The dome light goes on for 15 seconds and ignition key ring (if present) will light for 30 seconds when unlocked.
Unlock: press unlock one time for driver's door, press again within 5 seconds to unlock all doors inkling rear gate (wagon). The system does not open the trunk.
Panic mode: press and hold lock button for approx. 3-4 seconds to activate Panic mode. I panic model the horn honks and turn signals flash until either the lock or unlock button is pushed again.
Finder mode: Press lock button 3 times within 5 seconds to activate Vehicle Finder mode. The horn will honk once and the turn signals will flash 3 times
Distance: works within approx. 30 feet depending on battery strength, nearby concrete walls and etc.
Audible Chirp On-Off: the system will chirp when locked or unlocked. To turn OFF the chirps, unlock the door and then push both lock and unlock buttons at the exact same time for 2+ seconds. There will be 2 chirps indicating the the audible is off. To turn the chirp back on, repeat the process and the system will chirp one time when it is back on.
Battery: as the battery ages it will only work as you get closer to the car. When a battery is replaced, the transmitter must be re-synchronized with the Keyless control unit. To synchronize, press the lock or unlock button 6 times.
Programming: 4 codes may be programmed.
Sit in driver's seat and unlock all doors. Open and close the driver's door
Turn the ignition key from LOCK to ON position 10 times within 15 seconds. Be sure to stop at both lock and on. The horn will HONK once to indicate transmitter programming mode is activated. Leave key in LOCK position and don't remove it from ignition.
You now have 45 seconds to complete the programming as below.
Open and close driver's door again.
Push either lock or unlock button on the remote you want to program. The horn will honk 2 times when successful.
To continue and program other remotes at the same time: open and close the driver's door and push lock or unlock on the remote. The driver's door must be opened and closed between each remote you want to program.
Done programming? remove the key from the ignition and the horn will honk 3 times.
DELETE old codes? Reprogram 4 times, it will overwrite old codes.
Alarm Security System: optional on all models. When locked there is one chirp (can be turned off, see above), the turn signals will flash and the red 'security' light will start to flash once every 2 seconds except for STi which flashes twice every 2 seconds.
There will be 5 chirps if a door, hood, and trunk or gate is not fully closed
You can also arm the system by using the power lock button on the driver or passenger door as you get out of the car and then closing the door behind you.
Disarm the system: push unlock for 2 seconds
Lost remote, alarm activated? When you can't use a remote to turn off the system: open the door with a key or try to start the car and the horn will start to honk. Turn the key on-off 3 times within 5 seconds and the alarm will go off and you can start the car. It's simple!
VALET mode: To set valet mode or just to disable the security alarm system: 1. unlock all doors 2. physically open the driver's door 3. hold the UNLOCK button on remote for 2+ seconds. The red 'security' light will then flash 2 times a second until the car is turned on.
System has been Tripped (except for STi): if you unlock the door with the remote and it chirps the signal light flash 4 times, the system has been triggered;
Identification mode: To find out what happened and why the system was triggered:
Open and drivers door, leave it open. Turn ignition key from LOCK to ON 2 times and then leave in LOCK position.
Tripped code: 1 security light flash: a door has been opened, 3 flashes when the impact sensor was triggered, 4 flashes when the ignition was messed with or battery disconnected
Nov 19, 2009 | 2007 Subaru Forester 2.5X L.L. Bean...
No sound
did you try the volume up control or the icon for sound control in the control panel to unmute your system
Jun 01, 2008 | HP Pavilion dv2000t Notebook
HP Pavilion dv9000z Notebook Logo
202 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
