Question about Gateway USB Optical Mouse MOAKUO 7010867R $5.00
Wired mouse sometimes lights up but even when it does it does not work pointer
Rebooted and the new/never used mouse that came with the Gateway computer (which I listed in a previous question) -- but the old taped together Microsoft mouse works fine! The Gateway mouse is wired - not wireless.
  • Gateway Master
  • 32,281 Answers
These optical mouse do not work on a shiny surface. Try using it with a mouse pad or place the mouse on a piece of paper.
Posted on Nov 27, 2012
  • 1 more comment
  • Marlene Fischer Nov 27, 2012
    My old mouse is optical and works - the new Gateway mouse is on the same mousepad and does not work. I tried paper - it still doesn't work. I am back to using the taped up old mouse by Microsoft.
  • Chris Hingee
    Chris Hingee Nov 27, 2012
    Then it looks like the new mouse is faulty.
    Since mouses (mice) are inexpensive, you're right - I'll buy a new mouse and hope it works. TY
3 Suggested Answers
  • 120 Answers
SOURCE: my gateway fpd1975w tft lcd monitor does not work.
Restart the PC and get into SAFE MODE. Hit and release F8 many times right after turning on PC. If it works, then go into your video setting and either change the settings or remove the video driver. Restart the PC and you'll get 800X600 screen, then reinstall the video drivers. IF it won't go above 800X600, screen internals are bad, LCD toasted. I've seen that happen with LCDs and older monitors.
Posted on Jul 24, 2009
budmrtn
  • 11361 Answers
SOURCE: My Gateway monitor light blinks blue slowly but
More likely to be problem in the power supply.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 11, 2010
Gateway PC laptop mouspad not working
Check the control panel in two places:-
1. Pointers to see if you can use the existing driver, it maybe disabled there, or the settings need to be changed.
2. If it is disabled or unusable in pointers go to device manager and check if there is a yellow balloon next to the mouse, if so you have to replace the corrupt mouse driver software. global download gateway com
Jan 28, 2014 | Gateway MT3705 Notebook
Gateway Laptop with windows 8. Mouse pointer gone and won't come back
See if the mouse pad has been accidentally turned off. This can be done via the "Function" button on your Gateway laptop. To enable your mouse clicker again on your Gateway, head on over to the "Control Menu" in Windows and double-click on the "Control Panel" icon. Click on the "Mouse" option under the "Printers and Other Hardwareicon1.png" tab. In the next menu that pops up, click on the tab listed as "Device Settings." From this menu, you should be able to locate a listing for the mouse pad on your Gateway laptop. Click on this listing. From here, you should be able to enable the mouse again. Click "OK."
  • Head over to the official Gateway site online (see Resources). The above enabling of the mouse device under "Device Settings" may not have worked. Make your way to the "Software and Drivers" area of the site.
  • Check over your Gateway manual and find your specific serial number for your machine. Enter the number into the Gateway site when prompted and check to see if any driver updates exist for your mouse on your machine. If so, click to download the update, and then double-click the file on your computericon1.png to install it. Restart your Gateway laptop to have the changes take place. Your mouse should now work.
  • Jan 26, 2013 | Gateway Ne56r34u 15.6inch Laptop Black
    The mouse that came with it was not used until yesterday and it sometimes lights up but even when it does, it does not work the pointer.
    If the mouse pointer works with a different mouse, then the problem is with the mouse that you are using now. You will need to get a new one if that's the case.
    Nov 27, 2012 | Gateway DX4200-09 PC Desktop
    Mouse does not work, batteries are ok
    LOL, just when you need it to work those wireless mouse and keyboards always fail you. I never understood the concept of why have a wireless mouse or keyboard because you have to be sitting right there at the computer to use them. Therefore why not use a dependable wired device?
    Maybe the mouse needs replacing or somewhere in the mouse properties you have the pointer locked.
    Mar 25, 2012 | Dell Computers & Internet
    I have a gear head mouse, it's a lighted optical mouse model no OM3500U and I can't figure out how to change the batteries to see if that is the problem with it. It won't work at all and it...
    There are no batteries in this mouse as it is a wired mouse. Wireless mice require batteries, not wired.Try removing the mouse from the USB port it is in and move it to another available port. It should work right away (after it detects the new device)but you may need to restart the computer after you move it to the new USB port. If that does not work, than it died.
    In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
    If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
    Jun 05, 2011 | Computers & Internet
    My Dynex wired mouse, when plugged in, works but the red "laser" light on the bottom blinks like a really fast strobe light..making my mouse pointer jump around on the screen instead of moving...
    My laser mouse flashes too and it works just fine. I'm not certain, yours may be different than mine and maybe it's not supposed to flash on and off, but try cleaning the bottom where the light shines out using a damp soft cloth. Also try using a mouse pad with it... sometimes it may help.
    If not, your mouse may be defective. Try exchanging it at the store where you bought it from.
    Apr 09, 2011 | Dynex Optical Mouse
    My mouse will light up but my cursor will not move..i went into the properties and it said that my device is working properly
    if its a wireless mouse, it sounds like it needs to be snyced, refer to your manual or the internet for extact instructions but the snyc method is usally as follows, press the sync button on the reciever then on the mouse, sometimes its vise-versa, and sometimes you have to hold the button then press the sync button on the other half
    Jan 20, 2010 | Logitech Cordless Mouse
    Pointer on laptop jumps to a different line while typing.
    This may be caused by weak batteries, or interference by some nearby appliance (the worst case is another wireless mouse, of course: happened all the time in an office with six identical workstations, even to the two that were beyond a wall. But also wireless - not cellular - phones may interfere). Also the positions of receiver and mouse may play a part. Once sure the batteries work, try placing the receiver and mouse in different positions and see if it helps.
    Otherwise, the receiver antenna could be defective.
    Nov 07, 2009 | Microsoft Wireless Notebook Optical Mouse...
    Gateway USB Optical Mouse MOAKUO 7010867R $5.00 Logo
    167 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
