Question about Coffee Makers & Espresso Machines
I need new grinder basket for BHG coffee maker 10 cup
I want to buy new grinder basket
SOURCE: coffee maker parts
need a heating element replacement for model cm 500 coffee maker. How much does it cost? Mark
email to mmtazzy @yahoo.com
Posted on Sep 23, 2008
SOURCE: where to buy Starbucks(Bodum)Barista Utopia coffee maker filters
Good luck as they dont make them anymore, you can maybe get one on EBAy for big bucks, I found one at my thrift store before christmas for $15.00 and almost died, and it is new...awesome!
Posted on Jan 03, 2010
SOURCE: Coffee grounds overflow out of basket into top of coffee pot.
Oops I think I put my solution in the wrong place.
Here's what I did.
I had this problem and tried 3 different coffee makers, used bottled water instead of water from the tap, used different coffee, and nothing solved it. UNTIL, I tried keeping my coffee in the freezer. Viola, problem solved. I was using Dunkin Donuts coffee and, it seems that sometimes it just foams up too much and causes the overflow. I don't know why freezing the grounds works, but it does and, to me, it did not diminish the flavor, at all.
Posted on Aug 29, 2010
tedatcit
  • 89 Answers
SOURCE: i get weak coffee i
clean with CLR and then water rinse....use DRIP fine grind
1 tablespoon per cup..........remember strength is the coffee and the amount of water.
Posted on Oct 24, 2010
  • 67 Answers
SOURCE: Need a k-cup holder for my platinum coffee maker
you are talking about the black funnel? then check ouit http://stores.ilikenew.com
Posted on Nov 17, 2010
Programable coffeee maker shuts off before brewining is complete
I have the same problem. I can set it up for 10 cups and it shuts off with 2-4 cups of water in it. I open the basket and reset it and then restart the coffee maker, turning the grinder off first. Very frustrating.
Sep 23, 2013 | Cuisinart Grind and Brew 10 Cup Coffee...
How to fix the leak from the bottom of my cuisinart dgb-900bc
Re: Cuisinart grind and brew model DGB900BC leaking from the bottom. Finally fixed it before buying a new one. Remove the 4 torq screws (#10 bit check auto stores) from the bottom and remove the bottom. You will see a horse shoe shaped metal coil that heats the water from the resevoir. I found that the coil had a small hole in it. Cleaned it well and applied a coat of epoxy paste to the leaking area ( I used a product called PC11 from Ace) So far, no leaks, and the coffee maker is working like new.
Aug 10, 2012 | Cuisinart Dgb-900BC Grind & Brew Thermal...
How do i clean my cuisinart grind and brew coffee maker? i can't find my instruction booklet and it needs to be cleaned. thanks!
From the manual I found online here.
CLEANING AND MAINTENANCE COMPLETELY CLEAN AND DRY ALL PARTS AFTER EVERY USE. Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Open the reservoir lid*. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use. Do not put any water in the unit once the grinder basket has been removed. Wipe the area under the grinder basket with a damp cloth. If water gets into the grinder motor, the motor may become damaged and may malfunction.
DECALCIFICATION Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker. For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of your tap water and how often you use the coffeemaker. To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by pressing the ON button. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
Sep 09, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a grind and brew and can't get the grinding basket out to wash.
Open the reservoir lid. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use.
Sep 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I have the exact same problem, the grinder basket will not come o
If you still have manual call service number, if still under warrenty they will ship you new one for shipping charge. You can try to pry it out, this sometimes works, if you get it out put some veg oil on shaft where basket slides on.
Jun 15, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
My grind and brew turns itself off in the middle of brew cycle
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir as a guide rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. As such, a 12-cup machine actually produces closer to 9 standard 8 oz cups. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. It is extremely important to clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Ensure that the coffee machine is sitting level on the counter.
May 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Need new grinder
Cuisinart has the part directly- you can order from their website or over the phone.
Mar 08, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart coffee maker grinder stuck in machine. Can't remove to wash
I fixed the problem on my coffee maker fast and cheaply! I found that the stem that the grinder sits on had a small crack vertically in the hard plastic. That caused the diameter of the stem to swell just a bit larger and the grinder to bind to the stem. My solution was to remove some of the material in the area that was binding on the stem. Since the motor for the grinder turns at a high speed, I let it do the work. A file worked very well for the job. I by-passed the safety cut-off plunger, by pressing a rod into it, hit the on button, then carefully held the file to the area to be filed. I then used medium sandpaper to smooth everything
If you try this, be sure to not take off too much material and only file in the affected area. Also we are by-passing the safety switch - so obviously use caution. I only did thiis a couple days ago but so far the ginder comes out very easily. Here are a couple picts.
Aug 30, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Hot steam dampens coffee grinds in grinder unit
These grinds are what is left after the grind process is finished. Everyones unit does this.
Mar 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Makers & Espresso Machines Logo
216 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
