Question about Belling Ovens
How to replace oven control on356 belling
How do i get to the back of oven control switch on cooker
How to replace a selector switch
Posted on Nov 29, 2012
SOURCE: Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Posted on Aug 01, 2008
barkencoa
  • 3463 Answers
SOURCE: Cant find the model number on a Belling Format cooker
Hi.
Try looking inside the oven, or at the bottom front
Posted on Nov 28, 2008
barkencoa
  • 3463 Answers
SOURCE: cooker problem
If it has a timer, make sure it is set to manual or it will not heat, another possibility is a faulty thermostat, you need to find out if you are getting power to the element, if you are then element should work unless you have got a faulty one.
Plz rate this solution.
Posted on Dec 15, 2008
  • 3 Answers
SOURCE: electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Posted on Jan 15, 2009
SOURCE: how do you reset the clock when you switch on a
belling single oven. how do you reset the clock
Posted on Mar 19, 2010
I have just baught a second hand belling double oven cooker, we have switched it on and the timer is constantly buzzing! And the top oven and grill don't work! Any ideas on wot could b wrong?
The timer has been set and the cooking time is finished. That is why it is buzzing and the oven is in a turned off state. You need to acknowledge the cooking time finished, and set the oven back to Manual operation from Automatic. In the old days you pressed one of the buttons by the clock that was used to set. I used to have a Belling Double Oven in the UK, but I can't remember about the timer.
Google
make model manual
Google
Dec 19, 2016 | Belling Ovens
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Apr 13, 2014 | Belling XOU482 Electric Double Oven
Belling xou178 ss not heating up? fan blowing cold air, digital display working. is it the element and how do i fix it?
Yes most likely it is the element if the fan is still working.
First switch off the power to the cooker. You have to remove the back panel fom the back of the cooker which will give you access to the heating element, disconnect the wires and undo the retaining screws.
Remove the old element and fit the new, reconnect and it should be fixed.
Dec 30, 2009 | Belling Ovens
My Belling E641 keeps tripping out. Now the trip
You evidently have an earth fault on the cooker i.e one of the heating elements has failed and the trip switch is operating to prevent you getting a shock.
Most likely it is one of the radiant rings that is at fault but it could also be an oven element.
There is no easy way to tell without checking with a multi-meter for earth continuity between each element and the cooker frame, you can do this with the power off and the meter set to resistance or continuity test.
There should be no reading between healthy elements and earth but a faulty element will normally show a reading when the probe touches the cooker frame.
Belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Dec 22, 2009 | Ovens
Belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Oct 17, 2008 | Belling XOU252 Electric Single Oven
Noisy fan
it has to be replaced the bearings are shot on it I'm afraid well knowen problem in are trade.
Apr 12, 2008 | Belling XOU492 Electric Double Oven
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Ovens Logo
80 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
