Question about Panasonic CQ-C8100U CD Player
I have a panasonic CQ-C8100U that has no 16 pin plug car side
The receiver has the 16 pin plug in it but the car side is missing. I need to know the wire diagram - color code of this plug thank you Rhyan
saailer
  • 1868 Answers
SOURCE: Have a wiring harness for a CQ-C8100U panasonic CD
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
Posted on Feb 18, 2010
Panasonic car head unit CQ-VW120W, my aftermarket adaptor is missing 3 wires so I'm looking for pinout info. I know what all the colors are. I just need to know which pin numbers do what.
All parts and service manuals can be obtained by calling the Panasonic National Parts Center directly at 1-800-332-5368 9am-8pm EST during weekdays.
Sep 21, 2013 | Computers & Internet
I have a Panasonic CQ-C8100U Stereo. Was working fine then the auxiliary jacks stopped working. I Can power down then it sometimes works then doesn't once the volume is turned up past 13. Any...
hi robert. if your aux jack is mounted on the front of the face then i assume you have a problem within the face, maybe a cracked pc board, a switch which has lost its "click" feel, or even dirty gold face contact pins. also make sure that none of the 8 speaker lines is touching/shorting to the ground level. lastly have all your speakers checked independantly. cheers.
May 02, 2013 | Car Audio & Video
POWERLESS /
Make sure you hooked up power ground and accessory. If you are connecting it just to make that it powers up, ut the yellow and red together and connect them to power at the battery. Connect the black to ground. Make sure the battery has power as well.
Aug 25, 2012 | Panasonic CQ-C8100U CD Player
Stereo face plate does not turn on
Hi. Locate the connector on the rear side of the plate and clean it with soft towel (and a drop of acohol), so the contacts are shiny. Try the same on the unit. There is also usually an reset pinhole on the face of the unit when the face plate is not on it. Try to locate an press with something thin.
Dec 21, 2010 | Panasonic CQ-C8100U CD Player
Have a wiring harness for a CQ-C8100U panasonic CD Player/Head Unit, need a wiring diagram to hook it up to a 2002 Ford Explorer Sport 2 Door
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
Feb 18, 2010 | Panasonic CQ-C8100U CD Player
How to unlock my panasonic CQ-DFX301U
You won't be able to unlock it without the code.
Jun 16, 2009 | Panasonic CQ-DFX301U CD Player
Scooter stereo
Hi again,
My apologies, missed the connection. Now I remember, must be really getting old.
Back to your concern, which fuse pls? the 15 amps for the Panasonic or the amp"s fuse.
Incidentally, even if the speaker wires were wired incorrectly, that would not cause the fuse to blow. The only way the fuse would blow is if the unit was connected with the polarity reversed, even just once. Internally, most units have a reverse protection diode and/or regulator that would short circuit itself. Thereafter even if it were wired correctly to the battery, the fuse will always blow.
Looking forward to hearing from you.
Aug 05, 2008 | Panasonic CQ-C8100U CD Player
Power connector diagram
you need to buy actual harness. you will fry the unit if you don't, trust me
May 21, 2008 | Panasonic CQ-VD7500U Car DVD Player
Panasonic cdplayer Model CQ-C5310U
Yes the hook is the round port on the top right side of the back of the unit right above the main hook ins for power, ground, and speakers.
May 21, 2008 | Panasonic CQ-C5310U CD Player
Navigation unit for the CQ VD7500U
I BUY THE MODULE TV TUNER OF INTERFACE OF A PANASONIC CQ-VD7500U IF YOU HAVE IT IN SALE WARN ME I AM INTERESTED MY MAIL IT(HE,SHE) IS COMPRA24@hotmail.com SALU2
COMPRO EL MODULO TV TUNER DE INTERFASE DE UN PANASONIC CQ-VD7500U SI LO TIENES EN VENTA AVISAME ESTOY INTERESADO MI CORREO ES COMPRA24@hotmail.com SALU2
Apr 03, 2008 | Panasonic CQ-VD7500U 7 Wide LCD/DVD/SD/TV...
Panasonic CQ-C8100U CD Player Logo
120 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
