Question about Frigidaire GLTF2940ES Front Load Washer
Where is the drain filter located on model GLTF2940FS2
Where is drain filter located on front load washer model number GLTF2940FS2
3 Suggested Answers
  • 120 Answers
SOURCE: I have a Frigidaire Crown Front loader washer,
The problem is probably the pump being clogged with an object. Typically it is a coin.
Remove the front bottom cover to access the pump. Remove the two hoses. Make sure you have a pan to catch the water from the hoses. You will be able to remove the objects after the hoses are removed.
Posted on Jul 10, 2009
  • 32 Answers
SOURCE: how to clean drain pump frigidaire front loading
Remove the bottom access panel by removing the almost two hidden screws along the bottom. The pump is located on the right. Remove the two hoses and two screw that mount the pump to the base. Clean away. Reattach hoses and screws. TEST unit with panel off to check for leaks. The hoses can be a pain to get on right. Also beware water caught in tub and drain hose will leak out. Bring towels. Lots.
Posted on Sep 28, 2011
Where is the lint filter on Speed Queen...
You didn't say if it was top or front loading and did not include a model number. The model number is usually on a tag that is covered by the lid or door.
As far as I know most washers do not filter out lint during the wash but rely on the lint being suspended in the wash water and expelled with the dirty and rinse waters. Many do have filters in the drain that do need to be cleaned at times but the symptom is usuall a slow drain or not draining.
How to Avoid Lint on Clothes from Your Washing Machine Top Load Washer...
This is an active lint filter machine.
Filter Flo Lint Capture
At this link you can download Speed Queen Product Manuals.
Maintenance Tips
Front Load Washer Troubleshooting Lint
Oct 16, 2014 | Dryers
Code e62 on frigidaire gallery series model GLTF2940FS2
Good Morning Friend,
I understand you are receiving an E62 code on your Frigidaire Gallery washer, model# GLTF2940FS2. The E62 code means that there is a communication problem between the different control boards in your appliance. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire GLTF2940F Front Load Washer
Where is the drain filter located on the Samsung Silver VRT front load washer?
I have a similar model and there is a bottom panel which can be prized off with a flathead screwdriver or similar. Behind this panel you will find the filter.
It sounds as though you know what you are doing with these machines but hopefully you just missed this trick.
Andy
Nov 13, 2013 | Samsung WF337AA Front Load Washer
How can I best access the pump on my Samsung front load washer? I don't know how to remove the front panel
Some samsung washers have the water pump located in the back of the machine. If your model does not have a small door located in the bottom of front than remove back service panel to access the water pump.
Jun 21, 2017 | Samsung WF328AAW Front Load Washer
Amana washer model NFW7200TW drain filter
Go to www.repairclinic.com and enter NFW7200TW. You will be presented with a list of common repair parts and may be able to view a generic Amana video showing disassembly and parts identification.
May 17, 2012 | Washing Machines
How to clean drain pump frigidaire front loading washer gltf2940fs2
Sep 28, 2011 | Frigidaire ATF6000ES Front Load Washer
Hi.
If the model is WM1814CW, then the drain filter is located behind the small door located at the left hand corner at the bottom of the appliance's front side.
Regards.
Ginko
Aug 08, 2011 | LG WM1814CW Front Load Washer
Washer will not spin or take in water
Behind your washer on the upper left or right is the water inlet hose. Close the valve on the wall and disconnect from the washer. Use a bucket or something to see if water flows thru, by opening the valve. Clean the filter at the washer inlet with old tooth brush. The water flow should be good from the inlet hose; reconnect.
Check below front to locate filter, refer to manual. It may be clogged to prevent flow of water during spin. See if you can drain water from the drain hose you see when the front is opened, before you tackle the filter.
You can type Whirlpool with the model number above in the "Help me with " column to find several solutions.
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Aquarius WF745 Front Load Washer.Full of water won't drain.
The filter is located at the bottom front of washer.
Remove the kickstrip at the bottom, by levering off.
Unscrew filter anti-clockwise to remove and clean..
Be careful when removing filter, as there will be water come out.Lay the drain hose down into a bowl or similar to drain off excess water.
Please rate my solution.
Thankyou
Jan 30, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Front load washer won't drain water
If the washer no longer drains, and you have cleaned the drain pump and lines, it sounds like its time for a new drain pump. Typically, the pump impeller or motor wears out on these pumps causing the symptom(s) you describe. You can replace a pump yourself easily, by following these steps:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
A replacement can be found at searspartsdirect.com for about $70. Just type in your model number and locate item number 10 under the "Pump and Motor Parts" heading on the next page. The part number is 8181684. They do not carry the motor as a separate part. You have to purchase the entire assembly. I hope this helps you. If you require addtional assistance, please let me know.
Aug 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
