Question about Samsung Hw-e450 Crystal Surrou
Our Samsung 55 inch 1080 tv is connected to Samsung hw-e450 soundbar with HDMI cable. It works fine with tv programs from cable TV box. However, no sound came through the Soundbar for Netflix and we
Our Samsung 55 inch 1080 tv is connected to Samsung hw-e450 soundbar with HDMI cable. It works fine with tv programs from cable TV box. However, no sound came through the Soundbar for Netflix and we had to switch back to the TV speakers. Is there a solution? We also have a Sony Blu-ray player that is connected to the Soundbar through the auxiliary connection and that works too. Net flix is connected through the Smart TV and not through the Blu-Ray player
micromaster
  • 3614 Answers
SOURCE: when i put the blue
check the wire connection from your reciever to the tv...
Posted on Jun 13, 2008
VOTIT
  • 2071 Answers
SOURCE: we have purchased the Samsung
That's only in television signal thats catch a radio frequency signal but can't occur when playing DVD,maybe near to your place there someone using a radio com...
hope this may help;
DON'T FORGET TO RATE;
Posted on Aug 21, 2008
SOURCE: I have a Samsung UN55B7000 tv and a HT-BD3252
Make sure you turn on the surround sound located on your remote, should be second button from the bottom all the way over on the right.
Posted on Jan 06, 2010
milkburp
  • 416 Answers
SOURCE: i have a samsung tv and samsung blu ray i have my
First, HDMI is not a perfect hook-up solution. Cable box connections via HDMI are notorious for being problematic. The best thing you can do is contact Samsung and get the latest firmware for your TV.
Samsung Customer Care: 1-800-Samsung (1-800-726-7864). If this does not resolve the issue, connect the cable box using Component cables instead of the HDMI. Component cables are HD also. I hope this was of some assistance.
Posted on Apr 07, 2010
SOURCE: Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Posted on Apr 26, 2010
Soundbar connection from Phillips TV to a Samsung HD 550 soundbar
The sound bar only needs sound input from the tv so optical cable connection will work fine. HDMI cable will also work fine. Use the one that you have available.
Mar 18, 2017 | Samsung Televison & Video
When i turn the bar off it automaticly comes back on right away
Samsung HW-F450 2.1 Channel 280-Watt Soundbar
www.amazon.com/Samsung-HW-F450-Channel...Sou...
Amazon.com, Inc.5) If you use sound share to connect samsung tv to sound bar, it uses bluetooth. I dont know if ... The subwoofer is wireless though it requires power connection.
Amazon.com: Samsung HW-J550 2.1 Channel 320 Watt ...
www.amazon.com/Samsung-HW...Channel...Soundba...
Amazon.com, Inc.
Rating: 4.5 - ‎104 reviews
Sony HT-CT370 2.1 Channel 300W Sound Bar with Wireless Subwoofer, Bluetooth, ...Samsung HW-J650 4.1 Channel 320 Watt Wireless Audio Soundbar (2015 ... 2.1-channel sound system with 320 watts of total power. .... bar away from the TV, there's not gonna be a lag or cutting off of the signal. .... Right To Your Door.
Samsung HW F450 Sound bar Problems with arc connec ...
? 5:25
https://www.youtube.com/watch?v=e46odUZ71tE
Aug 4, 2013 - Uploaded by DUGLESSM
Samsung HW F450 Sound Bar hdmi hook up. ... How to connectSound Bar to TV, Blu-Ray Player, DVD ...
Question about new Samsung HW-F450 setu
Jan 05, 2016 | Samsung HW-F450 2.1-Channel Soundbar...
How Do I connect a Samsung HW-H450 sound bar to a Toshiba 46SL417U TV?
Here is soundbar manual. You may want to invest in not supplied by samsung hdmi cables.pg 15
if analog does not work for you.
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
Nov 28, 2015 | Samsung Televison & Video
How do I connect hw-h450 wireless soundbar to 40h5003af samsung tv?
Really depends on what you're switching. If you plan on using a DVD, Cable/Satellite receiver, or more than you'll want to plug all those sources into the HDMI inputs of the TV. From the TV you'll want to run an SPdiF cable to the back of the sound bar. These cables can be had for less than $6 on Amazon unless you have one already. This is the simplest and cleanest way to use the soundbar as the TV's speakers. Go to MENU on the TV and select AUDIO and then turn off the TV's speakers. This will enable the SPdiF output to the soundbar.
Feb 21, 2015 | Samsung Audio Players & Recorders
How do I hook up a Yamaha RX-V377 receiver to a Samsung HW-H450 soundbar?
Not sure why you would want to set things up this way, but you have to set the audio output in the receiver hdmi setup menu to tv. This will allow the receiver to pass audio info out of the hdmi jack. By default, this is turned off.
Jan 29, 2015 | Yamaha RX-V377 Receiver 5.1 Channels, 70...
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
Jan 05, 2015 | Samsung 2.1 Dolby Digital Wireless...
How do I connect Samsung soundbar 550 to sanyo dp55441?
Use the audio out ports on the Sanyo to get audio to the Soundbar. You can use a single digital audio cable or the legacy RCA audio cables. The Audio Out ports are marked in white on the back of the TV. If it doesn't work, turn off the TV Speakers in the TV's menu.
Jan 03, 2015 | Samsung HW-D450 Sound Bar
Cannot figure out how to connect my new sound bar to my older TV
If your TV has audio output connectors (RCA type), you can use them as a source of input to your soundbar. This should be apparent by reviewing the installation instructions that accompanied your soundbar.
Nov 30, 2013 | Mitsubishi WD-62527 62 in. LCD Projection...
What is the optimal cable type to connect the Samsung UN55B8500 to a DirecTV HD tuner? Are there specific TV settings to use for this cable type
The best cable hook up to use is the just the one HDMI cable. Just hook it up from box to TV and change the input selection on your TV to HDMI. Then on the Directv Box, change the resolution to 1080 for the best image.
Nov 09, 2009 | Samsung UN55B8000 55 in. LCD HDTV
We bought a Samsung Soundbar x810 but the Subwoofer does not seem to be working properly although the blue and red led light up. I have tried rebooting/resetting per user manual instructions but it still...
Purchased a x810 & everything tests out fine except TV signal sounds from cable box. We have the Comcast cable box connected to the 50" Samsung Plasma TV hooked up to Samsung x810 Soundbar all using HDMI cables. But we are not getting cable shows sound through Soundbar. Please advise
Nov 04, 2009 | Samsung HT-X810T Theater System
Samsung Hw-e450 Crystal Surrou Logo
54 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
