Question about Garden
Need a chain bar adjuster for jcb cs38 - Garden
  • 22 Answers
SOURCE: Makita 5012B chain cannot be tightened
some chainsaws have different knotches where the bar locks onto the saw. loosen the nuts and see if you can move the bar.
Posted on Dec 13, 2008
dontbother10
  • 2220 Answers
SOURCE: need parts breakdown for CS38. no fire at plugs
Clarification Request
Posted by dontbother10 on Sep 18, 2009
We need the make, model number, and serial number from the manufacturer?s tag to help you further. We also need to know if it is gas or electric and American or European.
Clarification request not answered. This question cannot be answered as asked.
Posted on Sep 23, 2009
dontbother10
  • 2220 Answers
SOURCE: i need the part number for the chain adjuster for
You were a little short with the model number, I think this is what you are after. The IPL for a SCS 38-35 H follows:
http://weborder.husqvarna.com/order_static/doc/MIPL/MIPL2005/MIPL2005_VP0502007.pdf
Page 6;
item 39 is the screw
item 37 is the bar adjustmeny nut
item 38 is I think an e-ring
If I missed on the model please expand some and reply below. I will get back to you. Good Luck. HTH
Lou
Posted on Feb 24, 2010
  • 4088 Answers
SOURCE: need to locate chain & bar oiler adjustment
Look to the lower left side of the bar (as you hold the saw normally)--there should be a screw head in the engine case there. Check the adjustment by holding the bar tip at speed near a piece of cardboard for a couple of moments--it should throw off a thin line of oil. Hope this helps!
Posted on May 02, 2010
  • 4088 Answers
SOURCE: how do i adjust talon cs38 chainsaw chain please
Loosen the bar retain fasteners to finger tight, then turn the chain adjustment screw to bring the loose chain just up to the bottom of the lower bar and have slight tension. Tighten the bar fasteners and check to see if the chain can be turned by hand fairly easily, but not droop from the bar. Make sure it is being oiled properly by running the bar tip at speed for several moments near some cardboard--it should throw off a thin line of oil. Hope this helps!
Posted on Sep 14, 2010
JCB chainsaw chain is too tight
Probably the adjustment lock nut is not being used.
Feb 18, 2018 | Garden
What size chain do I need for a McCullough MacCat CS38?
Chains have three requirements...pitch, guage and number of links. The pitch is the distance on center between chain links, the guage will be one of three, .043, .050 or .063. To get the number of links, you have to count each link and spacer. If you are missing the chain, you may have to take the saw to a service center and have them tell you.
Sep 27, 2014 | McCulloch Garden
Spear & Jackson chainsaw CS38 cuts out after
There are a couple possibilities. Your Carb adjustment is off or your fuel system is clogged up. On the Carb. there is an L and R you want to richen up the R side adjusting it a quarter turn counter clock wise. If this doesn't solve the problem check your fuel lines and filter. If there is a small tear in the line all the dirt and dust will go into the Carb and stick to the screen inside the carb body. Hope its the first one. Good luck!
Jan 22, 2013 | Garden
How do i adjust talon cs38 chainsaw chain please
Sep 12, 2010 | Garden
I need the part number for the chain adjuster for a mcculloch chainsaw model number cs38
Page 6;
Lou
Feb 24, 2010 | McCulloch Garden
I have an 18 inch bar and the chain has to be tightened every few minutes. I tighten the nuts against the bar as tight as I can but the bar must still be moving to loosing the chain. Do I need to add lock...
There is an adjusting pawl with a screw that does the tightening. The nuts only clamp the bar once the chain is tightened. The adjusting screw is in the plane of the bar. The pawl may have disengaged the bar or may have broken.
Jan 01, 2010 | Poulan PP4218AV 18" Chain Saw
How do you adjust the chain tension on a husqvarna 350 chainsaw ?
I don't own a 360, but most saws you have to loosen the two nuts that hold the bar on, and adjust the adjusting screw that points toward the front of the saw while holding up on the tip of the bar. Tighten until the chain is snug, but still loose enough to be able to spin the chain on the bar.
Dec 27, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain keeps coming off and when is on wont cut
If you are having difficulty fitting the drive links into the bar groove, the chain binds or rides up when rotated there may be burrs on the drive links. These often form if the chain comes off while at speed. use a file on the drive link flats to remove them.
Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They do not need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Nov 25, 2009 | Garden
Remington 12 inch electric saw, chain came off, cannot find manual to put it back on. I am 73 and need to put the chain back on to cut up the pallets for heat. I need to put it on the right way. A...
c2d7ab8.gif Chain adjustment
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
Lou
Oct 08, 2009 | Remington Electric Chain Saw
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
