Will not install
It will not run ran disk got error message pw2008.exe has stopped working. what next?
    President:
  • 8,637 Answers
This may not be the answer but how much FREE space do you have on your hard drive. It's possible that the disk doesn't have enough room to allow the program to install. it is a fairly large program.
Worth checking. Hope this helps. Bud
Posted on Jan 22, 2009
System configuration data updated ERROR,--Need a solution I have a fairly new Gateway M-1625 laptop running windows vista 32 bit, sp1. I turned it on and beeped twice (beep, beep) and gave me an...
Got a backup?
If not, download a Linux Live CD. Boot your machine with it, save all your data to an external drive and then do a complete disk format and re-install. That will be quicker in the long run.
Not sure about that PC, but on Dell, for example, you hit CTRL-F10 (I think) at power-on and it gives you the option of reinstalling the OS from the recovery partition (wiping any unbacked-up data in the process).,,Gateway is probably similar.
The Boot/BCD issue means your 'Boot Configuration Data' is hosed.
Jun 07, 2011 | Computers & Internet
I tried to install Singer PSW2.00a on Windows 7 and I get the following messages: {c121466d-3abd-445a9eeb-13479378a9ae}/Install.exe could not be installed access is denied and error in...
Run the install.exe on the disk as administrator, even when it automatically does that, you still have to do that. If that doesn't work, contact Singer.
Apr 13, 2011 | Singer Professional Sew Ware Options 2.0...
The error message says fatal system error.
Hi. The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
Booting the computer to its Last known good configuration will resolved the issue. Please see procedure below:
Turn of the computer
Keep on tapping F8 key the moment you press the power button
You should be getting a advanced boot screen
Select Last known good configuration from the selections then hit enter
Computer should be booting up by now to windows
All the best!
Jul 24, 2010 | Acer TravelMate 2480-2968 Notebook
Locked Laptop
This is from a factory repair and maintenance manual for Acer Aspire Laptops. It may work for you.
Forgotten Hard Disk Password
When the user keys in the wrong password three times, an error message appears. The user must now reset
the password.
1. Make a note of the error code that is displayed with the error message.
2. Run unlock6.exe from the DOS prompt in the following format:
unlock6 XXXXX 00
(XXXXX = HDD password error code, 00 = CRC base - default is 00)
3. Select Upper case ACSII Code from the screen that appears. The HDD master password is displayed.
Make a note of this password.
4. Reset your system. When the Enter Primary Master HDD User Password prompt appears, enter the
password you made a note of in step 3.
Resetting a BIOS Password
The user can reset a BIOS password using the clnpwd.exe utiility.
1. Copy clnpwd.exe to a DOS boot up disk (or flash drive).
2. Boot your system in DOS mode.
3. Execute clnpwd.exe from the boot up disk (or flash drive).
4. Press 1 or 2 to reset the required password as shown on screen.
5. A confirmation message appears when the process is successful.
May 24, 2010 | Acer Aspire 5315-2713 Notebook
I'm having problems connecting. I ran the initial CD setup and everything seemed to run fine but when I try to access the 10.0.0.253 I receive an error message. The camera is set to wired and is...
"I receive an error message" (sic) What is it exactly, what happens? Also Install everything as Administrator, ALSO set the setup/install program's .exe in, Compatibility Mode for XP SP2. and Run the actual program's .exe as Administrator, too. Ensure all network settings are correct too.
Feb 22, 2010 | Panasonic BL-C131 Network Camera
My mic is not working even other sound device is working i need mic software for presario c700
Here's the step-by-step how you may solve this;
To install audio / modem drivers, first download and install Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio (sp32646):
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
Conexant CX20549-12 Audio Driver for Microsoft Windows XP (sp36090.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
This will create a swsetup folder in C drive ("C:\sp36090")
Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\sp36090 folder and select the .inf file (CpV30D5a) and click open and Continue with the onscreen instructions.
Conexant CX20548 Modem Driver for Microsoft Windows XP (sp36089.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36089.exe
Download and install Conexant modem driver (sp36089). This will give error message and also will create a folder C:\swsetup\sp36089 which contains extracted driver files.
The same method which is used for installing audio driver needs to be followed for modem.
Hope this help.
Jan 27, 2010 | Compaq Presario 700 470024-192 Notebook
Problem with compaq presario c797vu audiobus
Sep 26, 2009 | Compaq Presario C700T Notebook
Microphone & Headphone of compaq presario C783TU are not working
ALL THE DRIVERS U'LL EVER NEED FOR COMPAQ PRESARIO C700
(VGA) Driver:
http://downloadmirror.intel.com/13300/a08/win2k_xp1429.exe
Chipset Driver:
http://downloadmirror.intel.com/13499/a08/infinst_autol.exe
Wireless LAN Driver:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34152.exe
ALPS Touchpad Pointing Device Driver:
ftp://ftp.hp.com/pub/softpaq/sp31001-31500/sp31075.exe
5 in 1 card reader driver:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33604.exe
HP Quick Launch Buttons
ftp://ftp.hp.com/pub/softlib/software8/COL18360/ch-47422-1/sp33258.exe
LAN Driver
ftp://ftp.hp.com/pub/softpaq/sp30501-31000/sp30580.exe
Aug 29, 2009 | Compaq Presario 700 470024-192 Notebook
I need free audio driver for Compaq presario F500 us Noetbook
First you need to install Microsoft UAA driver:
then
Audio driver:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34386.exe
3. Select "Install from a list or specific location".
4. Click Next. Then select "Don't search, I will choose the driver to install".
7. Click Browse C:\swsetup\sp34386 folder and select the .inf (wisxxxx) file and click open and Continue with the onscreen instructions.
then
Modem driver (because audio depends on modem):
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33839.exe
This will give error message and also will create a folder C:\swsetup\sp33839 which contains extracted driver files.
**The same method which is used for installing the Audio needs to be followed.
Mar 11, 2009 | HP Pavilion dv6000z Notebook
When i turn on my computer a bow comes up saying MMload dve.exe has stopped working how do i fix this problemm what is this
Hi
If your computer works fine even though dbe.exe is stopped then you can prevent that message coming up by going to start>>>run then typing 'msconfig.' Go to the startup tab then uncheck the box next to the process with the problem. This will prevent it running so you will not get the error message.
I think you may have made a typing error when you made this question - if you could tell me the exact message I may be able to assist you a bit more specifically. Or perhaps you typed it perfectly and it's just a very rare process!
Hope this helps
Philip
Jul 15, 2008 | Computers & Internet
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
