Canon printer not functioning
Have a canonBJC1000 sp printer which was fuctioning well now i find it is not able to print says "document failed to print" have intel 2 core duo with dg 31 pr motherboard and other accessories. window xp is used printer functioning well no problem with printer have a setup disk and tried no of times to reinstall pl help
  • arniyer Jan 11, 2009
    Thanks for the quick response. unfortunately, it has not worked and i am still having the problem.a message came that a status monitor file is missing and restart the pc and try reinstalling the driver. even this has not helped me. the response i get is "this document failed to print" any further suggestions?
  • Thomas F. Schneider May 11, 2010
    Uninstall printer first?
    START-CONTROL PANEL-PRINTERS ANDFAXS-DELETE PRINTER.
    President:
  • 2,692 Answers
      I believe that the status monitor may be within windows.   I would try to do a restore to the earliest date possible.Then try to reinstall the printer.  If that does not work;      I would put the windows disk in, run it like a new install but it will stop, telling you that;   " it found windows already on the computer and do a want it to repair it?" Say yes. You will not loose any data from (my pictures) or ( my doucuments) then for sure it shoudl reinstall. If that did not work. Download a new software/driver and load the printer using that download instead of the  install disk. Here is the link for the setup software and driver,if you will need it.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=329&modelid=7952
Posted on Jan 11, 2009
    Sergeant:
  • 183 Answers
Sir,
Restart your PC and Printer once and even it does not work then
your need to reinstall driver for that printer.
please post back if anything changes.
thank you,
Posted on Jan 10, 2009
Why can't I print to my Ricoh Aficio SP C430DN from my Macbook Air?
You probably have a conflict between the paper size the machine knows is loaded and the document size being specified for printing on. Your Airbook is probably trying to send a document on a paper size the printer doesn't have. Net result is a document stored in the print queue that stops anything else being printed. Go full system reboot and clear out any and all waiting documents before trying again.
Sep 08, 2014 | Ricoh Aficio SP C430dn Laser Printer
How do i repair my canon MX456 from printing blurry/double images and text
Your printer may be printing fuzzy, blurry, or other faint text because of dirty print heads. All modern printers have a mode that can be run to check and clean the printer's print heads, as well as other internal equipment used in the printing process. If you use your printer often or have had it for more than one year, we recommend running the printer's cleaning function. Consult your printer's documentation for details on how to run the cleaning function, as it differs for each printer brand and model.
Ciko
Canon Pixma MX456 Driver Download
May 14, 2014 | Canon PIXMA MX452 Wireless Office All In...
Hullo, i have a canon ir3300 that am trying to print with but it has failed how do i do it
Did you try to print test page from driver properties on PC? Did it came out OK? If yes then you have problems with document that you are trying to print.
Also it can be that you have wrong paper size set in cassete or in printer drivers.
Please be specific, how does print fails?
Jul 12, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Alarm flashes...nothing works
when i did print job.. now nothing is functioning.. the alarm keeps flashing and displays 'check printer ' 5100, i have unplugged many times
Apr 16, 2009 | Canon MX300 Office All-In-One Printer
Gestetner 3218 Aficio 180 Fuctional Problem SC 543
Enter SP mode - Clear button (yellow key), 1 0 7 and hold and press stop button (orange key).
Enter SP5-810 (SC code reset) and select “1”.
Then hold down the “Photo mode” key and the enter key(hash) at the same time for at least 3 seconds (it is not necessary to turn the main switch off andon). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to repair the machine.
Possible causes are the fusing thermistor in the fuser unit, or the power supply unit defective.
Good luck and please rate me, thanks.
Oct 27, 2008 | Ricoh Aficio 250 Copier
Problem with printing document footer text on RICOH SP C811DN
Check the paper size settings and orientation of the driver from the Control Panel, and that match to the paper size in the printer's trays.
May 28, 2008 | Ricoh Aficio SP C811DN-DL Printer
"this document fail to print"
I can fix the problem now! I change the program so, it can be printed now.  Thanks again
Feb 11, 2008 | Canon Pixma MP450 All-In-One InkJet...
53 people viewed this question
k24674
jasbo
jasbo
