Cylindr 3 misfire now ticking noise
SOURCE: Ticking noise in engine
It sounds like the lifters are still sticking. Change your oil/filter then after 500 miles change it again. Since motor oil has a mild detergents, a couple of changes should hopefully remove any buildup from around the lifters. Do not use "motor flush". Even though your engine is fairly new, it may remove too much buildup and flush it onto your crankshaft bearings. You may try some marvel mystery oil also and I've heard seafoam does a good job, if you can find it. Mine started ticking after using one of the super thick oil additives. I'm still trying to flush that stuff out.
SOURCE: MAP sensor / does a 2006 f150 have one? and if it
Bad MAP sensor....located on your intake manifold....one connector...1 o-ring
SOURCE: P0302 Cylinder 2 Misfire Detected in 2006 f150 STX
Looking at the Engine on a ford is different from a gm. The correct cylinder numbers are 1234 from front to back on the passenger side and 5678 front to back on the driver's side
May be mice, but I had a truck that did that from a worn speedo cable.
Regards
Apeal
SOURCE: how to solve engine lifter tick noise
Get the heads worked on or replaced it might need a valve lashment.
It can be issue with spark plugs or faulty spark plugs. Also
get the compression test done for cylinders. If any of cylinder shows low
compression then required, then that particular cylinder will cause misfire.
Also get obd codes scanned, the error code will let you know
which cylinder is misfiring or all cylinders are misfiring.
For your trouble shooting I suggest you to refer the help
oinks below. It has step by step details for many engine misfire issues.
Click the link below:-----
Ford Explorer Cylinder Misfire?
http://whoisbyme.blogspot.in/2012/06/ford-explorer-cylinder-misfire.html
Engine Misfire codes on Chevrolet Malibu?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Cylinder 6 Misfire?
http://howtobyme.blogspot.com/2011/12/cylinder-6-misfire.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Ford Explorer 5.0L: Engine Miss?
http://whoisbyme.blogspot.in/2012/06/ford-explorer-50l-engine-miss.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
Can cylinder misfire Damage the Catalytic converter?
http://schematicsdiagram.blogspot.in/2012/02/can-cylinder-misfire-damage-catalytic.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Chevrolet K1500 No spark, random misfire
http://repairhelpcenter.blogspot.com/2012/11/chevrolet-k1500-no-sparkrandom-misfire.html
2004 Ford F150: Engine Misfire and Lean Code?
http://whatisbyme.blogspot.in/2012/05/2004-ford-f150-engine-misfire-and-lean.html
1995 Toyota LS: Misfire at idle or low RPM
http://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Toyota Corolla:
Random Misfire?
http://technoanswers.blogspot.in/2012/04/toyota-corolla-random-misfire.html
2006 Ford Freestar: Misfire on Cylinder Number 2?
http://whatisbyme.blogspot.in/2012/06/2006-ford-freestar-misfire-on-cylinder.html
This will help.
Thanks.
There are few possibilities that can cause engine misfire issues.
It can be issue with spark plugs or faulty spark plugs. Also get the
compression test done for cylinders. If any of cylinder shows low compression
Cylinder 6 Misfire?
Toyota Corolla:
Random Misfire?
This will help.
Thanks.
