Question about Hitachi 51GWX20B 51" Rear Projection Television
Hitachi 51gwx20b service code
I replaced the Convergence IC chips, and also checked all the resistors to see if they were in tolerance. One was bad, so i replaced it.
The convergence is so much better, but is still off by about 2 mm. especially the blue! I wanted to go into the service menu so i can refocus the tubes, because the geometry screen is the best signal i know of to do that to. i might also want to just corect the geometry and reprogram the magic focus.
Does anyone have the service code to the hitachi 51gwx20b?
Thank you!
  • 5 more comments
  • Joesipaq Jan 10, 2009
    The CHASSIS# is DP23G
    And ladywinn, i will go try that now. Thanks. I'll let you know if it is successful.
    ok! so after focusing, the convregency is still off by a couple mm, and it is really bugging me, is setting the geometry possible, with the remote? and do you know what the commands are like the save, after i am done?
    Yes, I checked all the obvious 1W and up resistors, the resistor that had gone bad was RK46 2.7 Ohm I believe, it was burnt. I think it was a 3 W and Stupidly ordered 1W oops, but I tied 2 in series, then 2 more in series, then stuck the strings in parallel, essentially making a 4W 2.7 Ohm resistor, and it measured out just that.
    I would love to know more on how to set the up down... etc.
    Might I ask where you get your service manuals? I am always looking for good places to know of :)
    :) It seems that i am always posting the second right after you do asking for something you said you would already do :) sorry about that, you really are on top of your game!!
    So seeing that i replaced RK46 with a 2.7 made me go back and check... I kept the resistor, and looked at it agan, the first color band is defiantly red, then the two center ones are burnt brown, then the gold. So I am sure that it is a 2xx .5% and what you gave me was 1.8 :/
    Thank you for going through all of this! And I look forward to your aid on the magic focus!
  • Joesipaq Jan 16, 2009
    Have you had any luck with finding the instruction for the convergency via the remote??
  • Josh Crager
    Josh Crager May 11, 2010
    I need you to look on the back of the TV and give me the CHASSIS #, then I may be able to help you.
  • Josh Crager
    I needyou to look on the back of the TV and give me the CHASSIS #, then I may be able to help you.
  • Hitachi Master
  • 5,138 Answers
There is not a Service code to Enter into convergence on this set , on convergence board there is a switch on the very front of board WITH set on press and hold 3secs you should see convergence Pattern Appear after you release button. From the Front of TV remove Bottom cover then you will be able to see whole chassis,and the Little Blue contact switch.on same board you replaced ICs.
Posted on Jan 10, 2009
  • 4 more comments
  • ladywinn
    ladywinn Jan 10, 2009
    I have service manual at my shop for how to adjust up and down ect.. Also did you CK all Low ohm resistors there is I think 7 or 8 resistors.RK42 Rk46 RK50. Let me get back to you on all of them.
  • ladywinn
    Yes you can do adjustments with remote I just need manual at shop so i can inform you on how to do it.
  • ladywinn
    OK Heres the Resistors you maybe having problem because of theses,RK42 3.3ohm RK46 1.8 RK50 2.7 RK54 1.5 RK58 3.9 RK62 2.2 .
  • ladywinn
    As soon as i can i will post you anymore information that i have for setting Magic focus.
  • ladywinn
    Yes ,you can join RepairWorld i would print website but for some reason its not working right www. repairworld. com ok write address together. its 29.00 for 3 months I love it there.
  • ladywinn
    Right now i cant afford to renew my subs right now, but when i do i will be under trinitytvrepair.
How do you fix the color to a model 43fdx11b hitachi
Hello!you mean: colors out of convergence? nothing you can do about that, unless you replace 2 convergence amplifiers I.C. chips, plus all those burned 1 watt low ohms resistors with exact values, which only could be obtained via service manual or schematics. After resistor is burned, there is no way to read color code properly, due to partial evaporation of pigments. this is a "pro" job. If you try or tried, already to converge those "stubborn" crosses, there is more to do, even after you removed and replaced two 20 pin I.C. chips, soldered dead into sweep module, plus located and replaced resistors with precise values, you need to get your settings back to normal, by going into "factory service mode' or, at least into "convergence alignment" menu and fight with those crosses!Don't forget the white "****"! Otherwise, you will be re-servicing your set all over after 30 days of usage.good luck,Alex.
Feb 01, 2012 | Hitachi Televison & Video
Double image, red is 2 inches off main image. convergance ic amp?
Yes, your Convergence ICs have failed. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Feb 20, 2011 | Hitachi 43UWX10B 43" Rear Projection...
Mitsubishi WT-42413 Red Convergence will not move left right
U check all the resistors with the Ohm Meter?All the resistors u check it in tolerance?Resolders all the resistors,so it make good resistance for the ICS?U do all these steps,u still have problems,Ur ICS some how it shorted it dead,again.
Apr 02, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Hitachi Ultravision 51GWX20B, Bowtie shaped blue pic, R+G fine
Your TV has a convergence problem. You can get the parts, instructions, and repair support from www.TvRepairKits.com
Jul 06, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi 43UWX10B 43" Power Light flashes Continuously
I doubt if its the fuse. We just helped a customer with a very similiar problem. Its more likely that the convergence IC have failed and shorted out. When this happens one of the symproms is that the TV will shut down and chirp. Goto www.TvRepairKits.com and click the contact us button. They can provide you with more instructions on how to test if this is the problem.
Ed
Jun 16, 2009 | Hitachi 43UWX10B 43" Rear Projection...
When doing Magic Focus on Hitachi 51SWX20B I get Error 3, and the Process Stops. I have a Hitachi 60SDX88BA that also has a blue semi circle at the top of the screen. I have run magic focus and it stops...
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 02, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Red and Green have separated in double image and there is a dip at the top. Please Help.
You have a defective CONVERGENCE IC. Most TV use 2 identical STK IC & both has to be replaced at the same time. If you are not a technician I don't recommend doing it yourself. There is a lot of desoldering to remove the chips with 16 or more pins- and soldering the new ones.
Good luck! Astrotech
May 28, 2009 | Hitachi 51GWX20B 51" Rear Projection...
43UWX10B problem with green
if you have a 2 IC convergence chassis they dont control the green , However if you have the 3 IC chassis the green is controlleed by the third IC these are usually STK4275 or simallar single amp ICs. Which type chassis does your hitachi have? Its possibly related to the digital convergence board if all resistor near the ICs are good. Do you have the service manual? I can post a link where you can get the full service manual if you need one
Mar 29, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Double Color images and Convergence will not adjustment will not line up
The convergence IC`s board location are IK 04 & IK 05. Looking from the back of the TV they are mounted to a large finned aluminum heat sink on the right side of the chassis. The origional part (stk 392-110) can be substituted with an equivalent but higher powered IC (stk 392-180) , that is 180 watt instead of 110 watt chip. Do not use generic IC`s! Purchase origonal Sanyo chips only for best results. Replacement of the chips alone may not cure your problem if there are dammaged resistors caused by the origonal chips. Check the standing resistors on the opposite side of the heat sinks for proper value. RK42(2.2), RK46(1.5), RK58(3.3), RK52(1.8), RK50(2.2), RK54(1.5). All of these low ohm resistors are rated at 1 watt. If you encounter a bad resistor you must replace with the same exact value. Close is not good enough. This should fix your set. Do not buy a policy you have a good TV. Be sure to use a liberal dose of heat sink compound when insatlling the new chips, and clean off the old crusty stuff.
Nov 16, 2007 | Hitachi 43FDX01B TV
Hitachi 51GWX20B 51" Rear Projection Television Logo
212 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
