Question about JUMP START SYSTEM
Vector vec031 charger problem
I need to charge the unit and do not have the correct dc adapter. can you tell me what size or model charger i need for this unit?
  • 52 Answers
Http://www.centurytool.net/Vector_Battery_Chargers_s/2464.htm
Try this link to match up the same size unit you have.
Posted on Jan 11, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How do I charge my Motomaster Mobile Power Pack Model 11-1540-2?
It should have a small 120V to DC wall adapter charger with a DC wire / connector jack that plugs into the back of the power pack. Plug the wall adapter into 120V outlet and plug the DC connector jack into the back of the Power Pack. Leave on charge until the unit indicates it is charged fully (several Hours if it was fully discharged).
Nov 20, 2016 | Electronics - Others
I would like to charge my 930 T on 120 volt A C adapter
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Oct 18, 2015 - Read this guide on finding the right charger or power adapter. ... As part of that process, I took all my power supplies and adapters and threw them into a box. ...from a 120 V AC outlet in your home) and convert it to a specific DC output. ... Voltage is measured in volts (V) and current is measured in amps (A).
Is there a way to charge my 930 T on a wall socket AC adapter
www.fixya.com/.../t26037021-way_charge_930_t_wall_socket_ac_adap...
24 mins ago - is there a way to charge my 930 T on a wall socket AC adapter - PC Laptops ... I would like to charge my 930 T on 120 volt A C adapter. Jan 03 ...
AC versus DC charging - what is the difference? ' Plug In ...
www.pluginamerica.org > Blogs > Drivers Seat
Plug In AmericaOct 13, 2013 - It is simply a USB cable, which allows my tablet to charge from a DC USB ... When you plug in to AC power - whether you plug in to a 120V or .... 120vphone chargers and plugging in to 74 volts DC and charging their phones.
Jan 03, 2016 | Computers & Internet
I had to replace a old cable it had a short.! Got a new one nothing happen.!it not charging period.!
Please tell us the make and model number so we can help. Normally a charger does not have a replaceable cable to the laptop - only the AC cord to the power plug can be replaced. I've purchased replacement adapters and the AC power cord doesn't work correctly in the adapter unless I push it in very hard or wiggle it to make a connection. Some replacement adapter also have a plug to the laptop that is not sized like the original and also needs to be wiggled to make a connection. Please provide the information if you still are having problems.
Oct 06, 2014 | Computers & Internet
My acer aspire 7720G shut down random
Wait a minute. What?
From what I read;
1) One wire of the AC adapter (Charger) is hot to the touch.
'.....when I touch the charge one part of the wire is very hot."
2) AC adapter checks out as far as voltage is concerned.
"I tested the charger voltage and everything is ok."
3) "Sometimes when I touch the charge appear the icon...Could it be the charger broken wire?"
Does this mean, "Sometimes when I touch the AC adapter (Charger), the battery icon appears."?
Battery is CHARGING icon?
Could it be a broken wire in the power cable TO charger?
Uh, yeah.
1) AC adapter NOT plugged into the DC Power Jack, plug the power cable of the AC adapter into power.
Multimeter set to DC Voltage, and proper scale, red Positive lead to harness wire that goes to DC Power Jack's center pin;
,black Negative lead of multimeter, to wire that goes to DC Power jack's inside cylindrical metal shell;
Now gently wiggle the cable from the AC adapter, TO the DC Power Jack of the laptop.
Do you get an intermittent reading?
2) Also, how did you replace the DC Power Jack? What steps did you take?
http://www.dcpowerjacks.net/catalog/index.php?main_page=product_info&products_id=1291
Did you reuse the wire harness, and solder it to the DC Power Jack?
Have a lot of experience in desoldering/soldering?
What tools did you use?
25 Watt soldering iron?
.025 or .030 rosin core solder?
Desoldering Tool, or Desoldering Braid? (Solder Wick)
Side Cutters instead, and slightly shortened the wires of the DC Power Jack's harness?
(Then tinned the wires, and soldered the wires of the DC Power Jack harness, to DC Power Jack?)
Damp sponge, and cleaned the well tinned No.2 chisel tip, of the soldering iron, frequently? Used rosin solder flux?
Center pin wire (Positive), of harness cable TO DC Power Jack, was soldered to the center pin of the DC Power Jack?
Negative wire of cable TO DC Power Jack, was soldered to the inside shell of the DC Power Jack?
(Cylindrical shell, inside the DC Power Jack, that surrounds the center pin of the jack)
Sure there are no cold solder joints?
Not trying to 'browbeat' you, just am curious.
1) IF you are SURE you have the polarity correct, of the wires in the harness cable, that goes to the DC Power Jack;
,and you are SURE there is no broken wire, in the cable from the AC adapter (Charger) TO the DC Power Jack;
,and you are sure you made good solder joints;
I suspect the power correcting chipset on the motherboard, to be bad, or perhaps a Diode.
One example of the chipset I am referring to. This one is used in a lot of laptops. May not be used in yours, but gives you something to refer to when looking for a bad chipset, in the power stage, on your motherboard,
https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
Usually when bad the top of the chipset will be blackened, or bubbled.
A Diode is a one way valve for electricity. When they go bad it is visually obvious.
http://www.mouser.com/ProductDetail/Vishay-Semiconductors/BA479S-TAP/?qs=j6bfm3UnQnzfWUXqYnsQ9LdHLayQ%2fSwFGlGUXEDAB5w%3d
Post your findings in a Comment.
Regards,
joecoolvette
Jun 10, 2012 | Acer Aspire Computers & Internet
DV4 won't charge
Maybe it's the charger or dc jack that was broken. Just test with a known working adapter connected, see if it charges, if yes, then your charger is broken, while if not, then you have to resoldered your dc power jack.
Specs of HP DV4 AC Adapter:Output: DC18.5V 3.5A
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin inside
Dec 26, 2011 | Computers & Internet
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
So i lose my Literati charger right after my birthday! I cant find it anywhere and i found my old t mobile charger and it fits perfectly. But i cant tell if its chargeing and it wont turn on! Please help...
Stop!
There are no voltage and amperage "standards" for low voltage connectors found on devices made to run from an external "wall wart" or transformer type charger or adapter. Just because a connector "fits" does not mean the power is 1) the correct voltage 2) correct polarity 3) correct type (AC or DC) or 4) can supply the amount of power needed to operate the device.
You may have done irreversible damage to your device by literally "grabbing any old charger that fits" to power it. Obtain the correct charger - or if unable to find one; determine the characteristics needed by the device - those variables are listed in 1 through 4 above.
You may find adjustable power sources that allow 1) changing of tips to fit the device, 2) a selector to choose from a range of voltages, 3) a switch to select AC or DC output and 4) the ability to plug in the tip backwards so that the polarity reverses. The last thing needed, is to know how much current in amps or power in watts is needed by the device. The charger / adapter should be chosen on its ability to supply this power continuously - never choose a charger / adapter that provides less than any of the electrical requirements; otherwise damage to the charger or device may occur - and if left unattended, could overheat and cause a fire.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 23, 2011 | Computers & Internet
Where can I purchase a battery charger?
A new product laptop battery charger
AC input:100-240V AC 50/60HZ
DC input:12-24V
High output:16.8V 2.5A DC
Low output:12.6V 2.5A DC
charge time:3-5h
color:black
That has be dead against use front happen problem and LI ion battery trait., when charge battery must take out use, has insure up to snuff on room temperature charge , as well as can avert happen blast or combustion or life reduce problem. simultaneity can let it is accomplish normally charge and discharge process the battery , It’s activation state urge LI ion battery inside is longtime. Can prolong use life the battery.
That has be dead against use two species battery voltage parameter at laptop IT trade, the product have setup switch switchover voltage, insure apply two species different voltage laptop battery charge, any more introduced commutator model the product DC output plug, can use different variety, let use charger electricize for laptop battery is safety and set one's heart at rest. And that can prolong use life the battery, best economize expenses which needless for the peoples.
It’s charge use AC to DC, DC to DC two model charger. May use in the home or office ,and car or ship or train. Usag is best convenience .
If you have need the product, please contact us
Mobile:13751018213
skype:lincen18213
Email:lincen18213@163.com
FAX:86-755-61573100
Feb 25, 2009 | Zenith ZPA-314 Portable DVD Player
Battery Chargers
Hi , we'll need the make and model to find out for you.
Apr 08, 2008 | Office Equipment & Supplies
Adapter plug size
Wal-Mart ectronics dept. has an "Universal DC Adapter Kit" it will have various size adapter plugs and a variable setting to adjust DC Voltage. It also should have a switch to set the polarity. I used mine to power several different devices. It was well worth the money I spent as opposed to buying a actual DC Adapter. Subsequently, the kit from Wal-Mart was far cheaper than the real deal.
-marshall.
Albuquerque, NM
Aug 28, 2007 | RCA DRC620N Portable DVD Player
JUMP START SYSTEM Logo
208 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
