Question about Admiral 12001414 Refrigerator Dual Water Inlet Valve Kit Solenoid
Admiral freezer ice dispenser not working - Admiral 12001414 Refrigerator Dual Water Inlet Valve Kit Solenoid
SOURCE: Admiral Fridge Freezer
i have solved the problem with lights onthe drinks dispenser itis in sabbath mode torelease it push and hold the lock andauto light buttons at the same time for 3 or 4 seconds it worked for me hope it solves your problem
alan stoker.
Posted on Jun 29, 2008
We had thought this was a free service...??? Yes, we fixed it ourselves, after trial and error. We pulled out the ice bin and there is an arm that is moves back and forth beside it. It had frozen up. That is the ice crusher. Thaw it out and it is fixed. By the way, the above posting was not by us--ours stated that our ice crusher did not crush ice anymore. Instead, cubes came out...
Posted on Jul 13, 2008
gtaplytmpt
  • 90 Answers
SOURCE: Ice maker won't make ice after replacing water filter -plugged
I've had the discolored water before when replacing the filter. It normally means that there was gunk in the water line.
Do you still hear the ice maker trying to draw water in?
If not, the water pump might be burnt out.
If so, see below.
The water lines that feed the dispencer and the ice maker split after a certain point.
It's possible that the line that feeds the ice maker might be clogged. You should be able to get to it by removing a few screws and pulling off the back panel of the fridge. Then you can check them out and remove the clog.
Comment on the post if more helps is needed.
Posted on Jan 19, 2009
  • 219 Answers
SOURCE: admiral designer series ice maker
replace your watervalve
Posted on Mar 19, 2009
abhishek33
  • 1239 Answers
SOURCE: Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Posted on Jul 01, 2009
Admiral gc2227cdfb side by side freezer, when I push the button to dispense ice the flap on the door doesn't open and the ice just clogs in the door behind the flap. Any ideas guys?
Defrost the door. I believe that your flapper is froze shut. If you live in a high humidity area in the summer this will happen.
Jun 27, 2016 | Admiral Refrigerators
My Admiral LSD2615HEZ freezer is icing up? The freezer temperature setting is set between 4 & 5 and the water dispenser and ice maker are working properly. What might be the cause and what are the...
Check the water pan underneath, dump if necessary. Clean up any dust, etc. Reset to normal temp and do not open door for 24 hrs. If this doe not work check compressor / condensor
Aug 13, 2013 | Admiral 26 cu. ft. Side-By-Side...
Admiral Maytag side by side model LSD2615HEW not getting cold. Fan runs. Clicks from the back every few minutes or so.
Its issue with compressor or the problem with defrost timer.It clicking to set the defrost cycle,but not actually working.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Admiral 26 cu. ft. Side-By-Side...
Hi My ice making compartment has stipped working, but I still have cold water from the dispenser???
Check shut off arm not blocked or hold by huge storage of ice cubs in bucket. If it's clear all ice cubes.
Check water pressure is o.k. Check solenoid is working well. Check temp setting is 5 degree or less.
Check freezer heater is working well.If one failure out of the above, will not make ice in icemaker. Thanks.
Jan 31, 2011 | Admiral 26 cu. ft. Side-By-Side...
hi,,
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water Dispenser on freezer door does NOT work
change filter check tap see if water is shut off may be is the water valve
Apr 03, 2009 | Admiral 26 cu. ft. Side-By-Side...
Jul 12, 2008 | Admiral 26 cu. ft. Side-By-Side...
alan stoker.
May 15, 2008 | Admiral 26 cu. ft. Side-By-Side...
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 12001414 Refrigerator Dual Water Inlet Valve Kit Solenoid Logo
18 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
