Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore elite 596-76253701 not cold cooling
It blows air but it is not cold is their a way to charge the coolant? My frig is blowing air but its not cold. What would cause this?
  • aaron32076
    aaron32076 Nov 27, 2012
    the bottom freezer is the same as the top. Neither get cold.
  • aaron32076
    jblackwell: I am pretty handy but where is the timer and capacitor locaterI m guessing underneath but that does the timer look like?
It could be several reasons. since neither freezer or fridge is cooling i'd think the compressor is not coming on there could be several reasons for this.. id say first it could be the defrost timer is so equipted or a bad start/ run capacitor. these should be checked first. if you are and kind of handy it should not be a big deal.. you must kill the power in the unit befor you work o it though. if theres a defrost timer , locat it and try to turn it a little until it clicks or just turns a bit plug it back it and see if the compressor comes on if so you you need a defrost times. fairly common problem, probably 30- 40 dollars and local appliance parts store. the start capacitor will have to be checked to se it it is working with in the proper rating. if not it will not start the compressor. their cheap usually under 10 dollars at parts store. bet i can tel you from what i see here.. good luck let us know what you find please.
Posted on Nov 27, 2012
  • jblackwell Nov 27, 2012
    Aaron, look at these three videos and apply them to your refrigerator. their all basicly about the same. while in there before you do anything unplug the fridge and feel the compressor to see if its hot.. and it may be real hot... careful...start here. 1)http://www.youtube.com/watch?v=wqOzCQWoq... 2.)http://www.youtube.com/watch?v=5f7otYv7b... 3)http://www.youtube.com/watch?v=ptHk0Coad...
    in the defrost timer video note the set up of the timer. see the knob that is visable on the time? while the timer is in place, and the fridge plugged in, rotate that kob and see if the compressor starts.. if it does that is almost certainly your problem that is on a 12 hour cycle it could have gone into defrost and never restarted. if so replace the timer. avsilable ant a local appliance repair store or parts store.. let me know
SOURCE: Kenmor frig not getting cold
same problem then suddenly would not shut off, kept running. found out it was the thermo couple as well as the timer.
Posted on Aug 12, 2008
  • 66 Answers
SOURCE: refrigerator not cooling
This could be that it is out of balance. Set the temperature settings to midway. This control can easily get the fridge temp out out of balance if over adjusted. If you already have the tmp control at midway then you need to make sure there are no obstructions to the duct that carries the cold air from the freezer to the fresh food section to cool it. Check for ice buildup or any kind of blockage. Let me know what you find.
Posted on Nov 16, 2008
woodchuck789
  • 4070 Answers
SOURCE: freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Posted on Aug 27, 2009
  • 308 Answers
SOURCE: Kenmore side be side freezer works fidge not
It is either a problem with your defrost cycle, or timer, or it is the damper, for some reason froze in position. Hope this helps
Posted on Sep 12, 2009
  • 146 Answers
SOURCE: No cold air blowing into the refrigerator - temp too low
You have your own answer there - You have overfrosting and icing up behind the freezer, this will affect proper cooling - also if you have seperate freezer and refrigerator controls, it's possible the damper is not opening properly to let the cool air in. But in your case it sounds like a defrost problem. You will need to have a service person inspect your control board and defrost timer components - sometimes it's as simple as a board replacement due to a burnt resistor these things are the most common causes.
Good luck
Posted on Sep 25, 2009
Kenmore 795 continually blowing cold air into frig
If the control will not change and the lock is lit, first try unlocking it. Press and hold the lock tab for 3 seconds. If nothing happens, try unplugging the power cord for 30 seconds and reconnect it. This will reset the board.
Nov 02, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My frig is making a loud knocking noise it seems to happen all day on and off and coming from the back of frig plz help
the fan that blows cold air from the freezer to cold storeage area , is going to brake .
Feb 18, 2012 | Kenmore Refrigerators
Refrigerator is not cold
Hi Louis,
This is what has happened. Due to the door being opened for so long moisture which is naturally in the air has collected on your freezer coils. What you need to do is turn the whole thing off for at least 24 hours. Open the doors and put some towels around it to let the frost melt out.
All the air that gets cooled in your unit gets cooled by a fan that pulls air through those coils. Once the frost has melted out of them it should cool just fine.
May 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom frezzer is working but fridge is not blowing cold air
Refrigerator gets cold air from freezer compartment. Either the air flow is blocked by food items or ice, or the recirculating fan is not working.
The most common failure is that the freezer coils get all iced up becuase the defroster timer, defroster thermostat, or heater has stopped working.
When it's running, you should feel cold air blowing out of the vents that are in the fridge, otherwise, the 'air tower' (air vent) is blocked with ice.
If you manually defrost the whole thing, and it runs fine for a day or so, then it's not defrosting properly. If you manually turn the defroster timer, and you don't hear the scorching/hissing/gurgling of the defroster working, then that would confirm a fault in the defroster circuits.
Based on the following thread, it's probably a bad defrost thermostat.
http://www.applianceblog.com/mainforums/sears-kenmore/13766-kenmore-elite-22-bottom-freezer-refrigerator-fridge-not-cooling.html
Nov 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Good luck
Sep 25, 2009 | Kenmore Refrigerators
Freezer is working fine, but frig is warm,
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Kenmore Trio refrigerator (#596.76502500) is not working. The temp is 76degrees. The freezer seems to be working fine. I have switched it off at the circuit breaker and restarted it after 10 min. The...
The fan that blows cold air from the freezer to cool the refrigerator is not working. If your a little handy with tools its an easy fix. Its located in the freezer. Open your freezer door take off the steel panel at the back of the inside of the freezer. After you remove the panel you will see the fan the blows the cold air up to the Frig. A quick trip to a local appliance store for a new fan with do the trick. Put in the new fan 100% fixed even better than new because the orginal part is defective Kenmore should have recalled them. I have the same frig and its been perfect since I repaced my failed fan.
Aug 04, 2008 | Kenmore Refrigerators
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
99 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
