Question about Health & Beauty
Where can i find replacement blades for my hct420 conair trimmer
SOURCE: lost charger for conair GMT182
Call Conair, 800-326-6247. I lost charger for GMT183 and they replaced it for $5 + $.50 S&H.
Posted on Nov 20, 2008
SOURCE: HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
digram on how to replace my blade in my hair trimmer conair hc3180v
Posted on Jul 27, 2009
SOURCE: conair beard trimmer: took screw out and can't
After removing the screw you must place your thumb on the battery cover (just below the screw where the 5 raised lines are) and slide the cover downward. The battery in this unit is soldered in. You may have to take it to a repair center to get the battery changed. The battery is a D-Sc type 1600mAh 1.2V. Good luck finding one. I thought the battery in my trimmer was bad after it sat idle for about 8 years. Turns out a little light sewing machine oil on the cutter head made it spring back to life.
Posted on Jan 15, 2010
SOURCE: how to change blade on this trimmer?
Just push the top out with your thumb. It pops right out and you can clip on the other 2 special trimmer.
Posted on May 02, 2010
SOURCE: I purchased the conair trimmer model GMT175W I
Just twist and pull backward on the tip where the seam is. It does kind of feel like you're going to break it, but it won't--it is made to snap off like this.
Posted on Jul 12, 2010
I have a Conair Hair Trimmer Model #HC111W and need to find replacement blades. The blade I need the most is the ACA-1 but if I need to purchace a whole set that would be fine. Can you help?
Here is the link to their online store where you can find parts and also new sets.
http://www.conair-store.com/category.asp?NAV=PERSGROOM&HDR=GROOMING&trk_src_ss=CONPAYPCWEBMACSS'PPC'ADW'conair%20hair%20trimmer
Thanks
Jun 15, 2011 | Conair HC100RCS Hair Trimmer
I have a Conair GMT189CGB 13 piece styling trimmer how do I change the nose/ear trimmer? I have no idea how it snaps in? what a terrible design!
You do not need to unscrew anything. Instead, simply take the beard trimmer (with the beard shaving blade still screwed on) in your hand, with the power button and "CONAIR" logo facing you. Then, put your thumb under the shaving blade and apply force to pop it off. So, the shaving blade, and the top part of the unit that it's screwed into will simply pop off. Then, you simply align the nose/ear hair attachment, and snap it in to the beard trimmer unit.
Jan 16, 2011 | Conair GMT 170 CS Beard Trimmer
The trimmer is not cutting the way it should, the bottom blade seems out of place and I cannot put it back in place
Conair trimmers are only good for about a year and they are hard to put back once you have messed with them. does your blade pop off or does it have two phillips screws holding it in? If you take the blade off completely you should see two arms that are in there, you have to place the blades back on correctly and hold them together while putting the screws back in. be very careful not to tighten the screws too much. Oil your blades with 3-1 oil and then turn them on. adjust the trimmer and see if everything is level, if it is try cutting withem and see what happens. If the motor sounds good but the blades are pulling your hair rather then cutting it then you need to replace your trimmers because your blades are daul.
Oct 05, 2010 | Conair HC100RCS Hair Trimmer
Need replacement blades for hair trimmer
Hi. Order them from Conair: customer service representatives will be happy to help you. Please call 1-800-326-6247 for a Conair appliance.
Mar 23, 2010 | Conair HC117 Hair Trimmer
Feb 01, 2009 | Conair HCT-426 Hair Trimmer
HOW AM I SUPPOSED TO "OIL" OR LUBRICATE A CONAIR HC115BPCS HAIR TRIMMER?
There should be 2 phillips head screws on the underside of the cutting blades.loosen them enough to where the 2 cutting blades are able to move freely then take some 3-in-1 oil and apply some in between the blades and tighten the bladesback down.Turn the cutters on for about 30 seconds and they should be good to go.Rate me FIXYA! if this helps! GOOD LUCK.
Nov 18, 2007 | Conair HC115BPCS Hair Trimmer
Health & Beauty Logo
259 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
