Question about Gateway DX4200-09 PC Desktop
The mouse that came with it was not used until yesterday and it sometimes lights up but even when it does, it does not work the pointer.
My old mouse is Scotch-taped together and since I have the new/unused Gateway mouse, I plugged it in and started the computer. It did not light up - and when it does, it still does not move the Pointer. Help please.
    Guru:
  • 571 Answers
If the mouse pointer works with a different mouse, then the problem is with the mouse that you are using now. You will need to get a new one if that's the case.
Posted on Nov 27, 2012
RPFinney
  • 385 Answers
SOURCE: Please Help Me!
Yes your asking too much of it,
An old system cannot keep up with all the memory intensive programmes and the processor will not cycle the information fast enough for you
This is why it is slow
add more ram, bigger hard disk drive too will help
if you can
delete anything off it you can too
increase the page file size,
will help
Regards
Richard
Posted on Apr 25, 2009
ag66339
  • 127 Answers
SOURCE: I have a Gateway 831gm It was working fine until I
You power supply is broken. It can happen at the drop of a hat. Plug in your PC model in google and follow it by the words power supply. You should be able to get one for $20 or less.
Posted on Sep 22, 2009
soumya176
  • 55 Answers
SOURCE: Computer starts up to Gateway splash screen and
change the smps
Posted on Oct 16, 2009
SOURCE: My integrated video card died so I bought a
does your motherboard identify your new video card? make sure to put the new video card on the right slot. then check all the cables which is connected on your monitor going to the tower. make sure to connect the vga cable of the monitor to your new video card. try to power on computer and install the video card driver which comes with your new video card.
Posted on Apr 01, 2010
SOURCE: My gateway dx4300-03 starts up
By Cyclontech!
Hi, The solution to fix the problem is by changing your power supply. Just make sure that you replace it with a 500W or higher and not with the same 300W which does not have enough power for this system, plus it is defective. I have changed the power supply to 4 diferent gateway PCs same model dx4300. And all 4 are working perfect. And run a check disk on CMD to fix the disk errors that were created every time you unplugged it and turned it on again.
Posted on Nov 23, 2010
Testimonial: "Thanks I will try it"
Wired mouse sometimes lights up but even when it does it does not work pointer
These optical mouse do not work on a shiny surface. Try using it with a mouse pad or place the mouse on a piece of paper.
Nov 27, 2012 | Gateway USB Optical Mouse MOAKUO 7010867R...
Sony vaio laptop mouse (VN-CX1) pointer disappears, not fully but its blinking lightly which is not visible clearly, what to do? After installing Windows 7 its working properly till yesterday. Today we got...
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question/exclamation mark? ! or a red X
this means a driver will need to be updated right click select update driver
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Nov 05, 2011 | Sony VAIO VNCX1/B.CE Mouse
My Gigaware optical mouse's cursor won't move
Sounds like the laser failed. Return it for replacement.
Mar 16, 2010 | Ultra Max Gigaware Wireless Laser Mouse
Compaq notebook laptop: my mouse pointer or arrow is
If you have a manual for the notebook, check to see if you can use the function key and the similarly coloured key on the keyboard which enables/disables the touch pad. Usually you can disable the mouse pointer touch pad with this FUNCTION key + MOUSE key when pressed together. Often these keys have the same colour (usually blue). The purpose is to disable the touch pad when you are using an external USB or wireless mouse, then you press the 2 keys again together to enable the touch pad once you have removed the USB/wireless mouse.
If that doesn't work, borrow a USB mouse and attach it to your notebook to use temporarily while you diagnose the problem.
Dec 19, 2009 | Acer Aspire 5100 Notebook
Mouse pointer keeps wavering in the screen. Im not
try to look for the proper signal, try to click the button on the mouse, or try to unplug it and plug it again.hope it work.
Sep 30, 2009 | Samsung Pleomax SCM-9000 Mouse
Freezing or Jumping Mouse Pointer
This could happen if the PS/2 connector on the motherboard is defective, or if there is a failing component in the PS/2 circuitry on the motherboard.
Could also be due to loose solder points at the PS/2 connector.
This needs to be checked by a qualified technician.
Apr 12, 2009 | Foxconn 661MX Motherboard (FOX661MXMB)
Fixing optical mouse problem
try a diff mouse. try a diff usb port
Jul 31, 2017 | HP OPTICAL SCROLL MOUSE (8131)
Gateway DX4200-09 PC Desktop Logo
56 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
