Question about Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
In side device manager sony cdrw/ dvd crx835e shows an explaination mark... cds, and dvds aren't able to be read from the drive
  • 52 Answers
It means that your driver for that device is not completely install. so reinstall the driver.
thanks for your question
Posted on May 16, 2009
I have a Dell Inspiron 9400 laptop with a sony cdrw/dvd cr835e. The drive reads cds without a hitch. It will not read dvds. When I put a dvd into the drive, the drive attempts to read it quite a few...
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Sep 18, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Need a driver for SONY CDRW/DVD CRX835E
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Aug 07, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
My Sony CRX830E combo drive will not read any of the DVDs I have tried to play in it. The message it gives is that a compatible decoder is not installed. Is this a software issue, or do I have to buy a...
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no _ for your specific area
Jan 02, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Cd/dvd rom LG GSA-T10N doesn't burn or read any dvd
some drives ( multi-Drives ) will read and write CDs but Only read DVDs.
Also check that the Drive supports DVD- Or DVD+ Disks.
Check that there are no yellow Marks In The Device Manager. to Do this:- My Computer/Control Panel/System/Device Manager to ensure all drivers are corectly installed.
mike @ compurepair.
Jun 11, 2009 | ASUS Computers & Internet
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
My Matshita UJDA 750 DVD/CDRW wont recognize a blank DVD discs. How ever it does read both CDs and DVDs and only burns CDs.... please help
Are you trying to burn a dvd? If so from the spec you gave in the problem description your drive will burn cds(CDRW) but will only play dvds(DVD). If it stated DVDRW then you would be able to burn DVDs as in the CDRW.
Mar 06, 2009 | Evesham Voyager 6400 Notebook
Cannot read CDs, can read DVDs
If it would have been a soft problem it wouldn't have worked at all, the driver is for the unit, not just for a function. Most likely it's a HW problem: either the laser died or the lens is dirty - try cleaning it.
Btw if your unit can't read cd's how those morons at the shop expect that you could reinstall (or repair) your Windows?
Test your unit your self: take it out, put it in another laptop (or in an external case and attach it to another pc and check there. If it's dead then replace it with a new one - preferably a dvd-writer of any mark.
Dec 03, 2008 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
CDRW/DVD CRX835E
that is b/c you only have an CDRW/DVD ROM (from your title). You need a DVD+-R to be able to write to a dvd+ - R disk.
May 15, 2008 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Sony CRX835E CD-RW/DVD-ROM (Combo) Burner Logo
291 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
