Question about Canon PowerShot G3 Digital Camera
Powershot g3 when i plugin to charge the battery there us no sign and no yellow light and the battery doesn't get charged help me
  • Anonymous Feb 17, 2008
    Same problem here
    Genius:
  • 1,690 Answers
The battery is probably worn out, or the charger failed. More often it is the battery that is no longer able to charge and needs to be replaced.
The only way to absolutely know which is defective is to try the charger and a new battery, unless you have a DVM and a load tester to be able to test the charger.
Jerry G.
Posted on Apr 13, 2008
SOURCE:
Battery light stays on after changing battery,alternater & plugin.
Is the system charging? You should have 14.2 14.6 volts at the battery. The charge light is controlled by the alternator internally. If the charging system is working, you could have a bad diode inside the alternator keeping the light on or a short/grounded circuit to the battery light
Apr 11, 2015 | 2003 Ford Windstar
Canon PowerShot SX110 IS Digital Camera charge fully battery after one pics show low battery sign
This is probably a battery issue and not a camera issue. Batteries with low output or low power can be due to them sitting and not being used for long periods of time. This can affect their ability to get a full charge as their "memory" is reduced regardless of what the charge light indicator displays. Even taking a battery that has been sitting for a long period and charging it to full charge, might only have limited power. Some of these can be returned to almost full capacity, but it takes multiple, repeated, alternating, charges and power deletions to rebuild the memory. In many cases, however, the battery just needs to be replaced.
Feb 10, 2013 | Canon PowerShot SX110 IS Digital Camera
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Sep 27, 2011 | Sony PlayStation Portable (PSP) Console
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
Will boot up on charge but when in the process of starting up will turn off again
If you can take the battery out of the computer. plugin the power adapter to the computer and the wall start the computer using only the power adapter for your source of power.
If everything starts up normally you will need to replace the battery.
Dec 11, 2010 | Apple iBook G3 Clamshell (M2453B) Mac...
What battery do I need
The battery for the PowerShot G3 is the Canon BP-511A.
Mar 26, 2010 | Canon Accessory Kit (ACCS) Battery Case...
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
Canon PowerShot G3 Digital Camera Logo
79 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
