Question about Garden
How to change spark plug on craftsman 1350 snowblower
2 Suggested Answers
roadtech7
  • 293 Answers
SOURCE: where is the spark plug located on my craftsman lawn tractor model 917.273360
James, it is at the front of the engine. It is next to the 4" by6" metal cover that says OHV. It is on the right hand side ( sitting on the tractor), There is a black wire the size of a pencil ( diameter ), hooked to it. It is set deep in the engines cylinder head. There is a rubber boot over the end of the spark plug. Remove the rubber boot, you will hace to grip it hard and pull it off. Then you will be able to remove it, using a deep 5/8" socket with a 4 to 6 inch extension.
Hope this helps, if you need more let me know.
Matt
Posted on Dec 02, 2011
Snowblower won't start
ck the spark clean plug , clean the carb ,make sure you are getting both and ck that air filter
Jan 03, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Craftsman snowblower will not start
Dump out the old gas and put in new.Try a spray of starting fluid into the carb. If it will not fire on the starting fluid there is somthing wrong in the ignition system. Pull out the spark plug and clean it with a wire brush. If it still won't fire the points and condensor need to be replaced.
Dec 21, 2013 | Craftsman Tecumseh Snowblower 7hp...
Craftsman snowblower will not kick over
Old gas? Did you pull out the spark plug and see if you have a spark? If the gas is old, drain the tank and line to the carburator, then put in fresh gas. Never put it up for the summer with gas in it. Run it until the engines runs out of fuel, then put it away.
If there's no spark, then you have a coil issue.
Nov 21, 2013 | Craftsman Snow Blower / Snowblower Bottom...
The lawnmaster snow blower won't fire up no spark
First make sure the spark plug is good. Then I would suggest checking the flywheel and coil for rust on it as this is a common problem. There should also be a single wire running to the coil remove it and see if you have spark. If you still have no spark the coil may need changed.
Oct 23, 2013 | Craftsman Garden Tractor Snowblower...
I need to know spark plug gap on murrays snowblower g2250030
.30 is usually a good standard if you can't find the manualHave you tried manuals on line ?
Dec 28, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need a manual for a snowblower craftsman 10/30 it doesn't start,i changed the sparkplug and it doesn't chage anything,i change the oil last year,does it need to be changed this year to
Hi
Most common problem with snowblowers is clogged carb. Remove spark plug and put a tea spoon full of gas in the plug hole and try to start. If it starts for a sec that is your problem. To get a manual go to searspartsdirect.com you will need the model number to find the correct manual. Model number should start with 917.XXXXXXX.
Sam
Dec 11, 2009 | Craftsman Garden
Snowblower: fire from muffler
Try changing the spark plug. You may be having some misfiring going on here. Is your fuel to oil mixture right?
Jan 28, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
189 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
