Question about Dell Precision Computers & Internet
Dell t3500 led 3 4 on solid green at boot - Precision Dell Computers & Internet
  • 231 Answers
SOURCE: d530 CMT minttower power problem
Hi, from your description it appears your power supply is ok.
Remove your RAM chips, clean everything with a soft brush or a can of compressede air [from computer store] Reinstall the RAM making sure it is seated firmly.
If this does not solve the problem, Are you using 1 or 2 RAM sticks? if 2 then remove them again and swap them around.
stick one in dimm2 and stick 2 in dimm 1.
If you only have one stick then beg or borrow another stick and try it. If all fails you may have developed a mobo problem.
Regards mistyman
Posted on Oct 15, 2007
SOURCE: Dell Dimension 8400
I have this exact problem.
The Dell Dimension 8400 will seem to randomly go into fan-jet-turbo mode on power-up and fail to boot. The problem I'm referring to is not a heat problem which an over-speed fan might otherwise suggest but a hardware problem the details I'll get to in a bit
I've done all the normal and obvious stuff that has been reported before
remove/replace memory
remove/replace AGP video card
removed all extra power loading / drives / USB etc
BIOS tweaks/resets
check supply voltages with a DMM (I even re-adjusted the hipot to get the right voltage - it was a little low)
As an engineer it is important to determine root cause. Do to this it is necessary to find a way to make the problem occur and not occur. If you're able to do this you can fix it.
Well in my case the problem it related to a mechanical stress on the heatsink. What I mean is a little force pushing the heat sink toward the fan turns off the problem (boots normally) while a little force in the directly away from the fan turns-on the problem (fan-jet-turbo-mode).
The root cause is could one of several things, it could be a damaged motherboard with a broken trace, it could be a socketing issue,
The Fix (not really - just a band-aide) was to use a tie a couple of small tie-wraps through a some small holes in the heatsink then through the fan mounting holes.
Only slight pressure is necessary - too much will likely cause permanent damage. The fan is mounted on rubber isolators so it somewhat limits the force on the heatsink
Any this mechanical issue is somewhat supported but all the information I've read - how removing/replacing the CPU can fix the problem, changing memory, removing cards - all these mechanicall stress the motherboard and likely move the heatsink some.
Intermittent problems are the worst to debug!
Ross
San Jose, Ca
Posted on Dec 07, 2008
Kustom42
  • 56 Answers
SOURCE: computer will not boot
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?journalid=6EB139500365CBA6E040AE0AB5E109D6&treeid=286725
See that link for the beginning of the Dell troubleshooting wizard for diag lights 3 & 4, it is in fact a memory subsystem error. Usually meaning the stick of memory in the first slot is bad. The wizard will walk you through this, but try removing the first stick and using the second stick in the first bay and see if it will boot. Unfortunately no recalls on RAM for this model but the good news is that your memory is cheap and if your not under your service contract you can buy a set on newegg or a similar site for about 50 bucks.
Posted on Jul 15, 2009
c-hom
  • 150 Answers
SOURCE: dell T3500 with E139765 on motherboard. LED on
Try the steps given below and it should resolve the issue;
1. Turn off the computer - unplug the power cable
2. Press and hold down the power button for 1 minute with power cable unplugged
3. Release the power button
4. Reconnect the power cable and turn on the computer
5. Dell ought to boot in Normal Mode
Lemme know the results.
Regards,
Anirban Mazumdar
Posted on Dec 04, 2010
  • 998 Answers
SOURCE: Dell T3500 Power button blinks
Blinking Amber - System fault error condition including Power Supply (only +5VSB working), V reg (Voltage Regulator) failure, missing or bad CPU etc.1 and 3 LED"s indicatesMemory configuration error.
Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged.
Posted on Jul 03, 2011
Dell Precision T3500 wont boot 1-3 lights blinking
An amber light means your computer isn't reading the hard drive or CD right, Take it to a professional to get this corrected
Dec 16, 2013 | Dell Precision Computers & Internet
Dell precision 490 led 4 remains on
try to clean the memory slot of your computer as well as the memory module then power up your PC. just do hardware maintenance by means of cleaning all any dust inside the computer. Hope it helps thanks.
Nov 02, 2011 | Dell Precision Workstation 490 - MT -...
Dell T3500 Power button blinks yellow 3-5 times and the 1 and 3 numbered lights blink as well - then they go off together and computer will not turn on
Jul 03, 2011 | Dell Precision T3500 Computer Workstation...
Dell T3500 with E139765 on motherboard. LED on motherboard is yellow & system will not boot up.
Regards,
Anirban Mazumdar
Dec 04, 2010 | Dell Precision T3500 Computer Workstation...
Dell inspiron 1501 wont trun on
There are a couple of things you should try:
Try booting with the battery out, check the power supply does it have a solid green led?
Remove both memory chips and try booting with just a single chip.
Any noises, led blinking, etc?
The more info you give me the quicker I can help.
May 25, 2010 | Dell Inspiron 1501 Notebook
My Dell 8200 Desktop just stopped working. It turns on but doesn't boot; nothing appears on the screen. I was told this is the motherboard. Does that sound right?
two things
  1. What does the power LED on the tower indicate? Solid Amber? Flashing Amber? Solid Green?
  2. On the back of the Tower are 4 diagnostic LEDs, what do they indicate? Normally they flash thru several sequences and stop ABCD all Green. If the stop in another pattern, post the pattern.
Feb 13, 2010 | Computers & Internet
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
499 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
