Question about Kitchen Ranges
The off button on my 5 year old Kitchenaid gas range does not work. All the other functions work but won't shut off via the off button. on the control panel. Any ideas on how to trouble shoot / re
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
You will need to replace the control panel. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 27, 2012
SOURCE: oven controls all work but off buton not working.
This is the Membrane switch which is faulty. I had mine replaced once already. These units cannot be repaired, they need to be replaced. Apprently it is very common and you should report this to your local ESA (Electrical saftey authority) this is a very dangerous problem. The ESA can have this item recalled if enough people lodge a complaint. The round Stove top knobs on these Ranges also have a tendency to switch on when bumped, very dangerous too.
Posted on Oct 19, 2009
aborcass
  • 2651 Answers
SOURCE: Maytag MGR5775QDS Gas Range Control Panel Problem
sure you can relace yourself, the part number, if you dont already have from previous repairs can be obtained fromthe sears website, or by calling manufacture direct. as far as a schematic there should be one located behind the range.
Posted on Feb 21, 2009
jumptrout51
  • 3361 Answers
SOURCE: electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Posted on Mar 12, 2009
  • 254 Answers
SOURCE: Our jenn air model js9860aab control panel buttons
no.. u must replace the touch pad assrmbly that whole unit.... i think u have a jds9860aab i believe... the part number u would need would be 74005750 it is for sale through sears at $272.00... u might need service.. u can take a look at part at repairclinic.com just type that part number in. ohhh also i believe this is a backordered part so most companies would prob take 2-3 weeks to get soo hope this helps..
Posted on Jan 28, 2010
SOURCE: KitchenAid Superba gas range/convection oven. Oven won't turn on.
From what I've read, the igniter is most often the problem and was with my KitchenAid Supra oven, Here are some details to help you do the actual repair by knowing where everything is located.
1. The oven has 2 igniters: one for the broiler (located at top inside of oven) and one the "overall" oven igniter (located underneath the heat shield on bottom of oven; remove 4 screws to get to it).
2. Do visual test to see if your broiler igniter works versus your oven igniter. It will glow orange if working. This is a good way to focus on the source of the problem (i.e., if no glow, then it may very well be the igniter).
3. Order new igniter. The site repairclinic.com shipped mine very fast.
4. To install: pull oven away from wall, unplug, and remove inside panel on back (not entire back panel but, rather, panel that is in the middle of the back). Here, you can access one of the two igniter wires. You can access the other wire by removing the storage shelf on the bottom of the oven. Snap the old ones off. Unscrew the igniter from inside the oven, Snake new wires through back.Screw new igniter in place. Put everything back in place and you are done!
Posted on Feb 16, 2010
KitchenAid KGSC308LSS Gas Kitchen Range OVEN won't heat up
Does the igniter in the oven glow white hot when it tries to start?
Dec 20, 2012 | KitchenAid KGSC308LSS Gas Kitchen Range
Fault code F1:E2 what is this fault
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks
Oct 10, 2011 | KitchenAid KGST307 Gas Kitchen Range
1. OFF button not functioning. 2. Oven doesn't reach desired temperature
Most common problem with a gas oven not reaching temp is the iginiter on the bottom is not lighting or is week .Change the iginiter and it should be good. The stop button is not working because the membrain (touch pad) has broken contact you may have to order one .Hope this helps
Sep 18, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchen aid gas range igniters won't stop
Jammed and broken ignight switch or the spark generator transformer has a short circuit
Jul 13, 2011 | KitchenAid KGSK901SSS Gas Range
When start button pushed, motor tries to start turn, won't turn, shuts off after about 5 seconds. It's a whirlpool modle LGR7646eqo gas dryer, several years old.
The most probable solution is a new motor, but you may get lucky. I would first make sure that there isn.t something that fell down the filter hole and is caught in the blower blade. Possibly the rollers are jammed and won't let the drum go, but usually when it groans and won't go it is the motor
Apr 19, 2011 | Whirlpool LGR7646E Dryer
Kitchenaid Range KGRA806PSS Control Panel Not Functioning
You're right about not using the self clean option. Your oven gets up to over 800 degrees when you use that feature. You can choose to simply keep your oven wiped out, rather than self clean it. The timer is most likely going out if the "stop" button doesn't work after cleaning. Please call or email us and we will be sure toget the right part for you. I hope this solves your problem. Ella
Sep 09, 2009 | KitchenAid KGSI901PBS Gas Kitchen Range
8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Feb 20, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven not working
Check continuity on gas valve. the middle connector is common, upper is broil and bottom is bake. Resistance between common and bake should be about the same as between common and broil. I believe you'll need to set the ohmmeter to KOhms (or x1000.
If no continuity between any of the connectors - replace gas valve (not much fun, and part is expensive).
Jan 21, 2008 | KitchenAid KGRC707 Gas Kitchen Range
Kitchen Ranges Logo
198 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
