SOURCE: Won't run - normal light flashes
You may try removing power to D/W for a minute and reconecting. likely cause though is keypad (console). If a light above a pad stays on the pad is likely closed all the time. Normal is probably cycle most often used. you can test the keypad by removing power to D/W and accessing the control panel. remove conncter P-1 and using an ohmeter test resistance between 13 and 4 on the connecter coming from keypad. yes without very small clips or 4 steady hands it is a little tricky. in the field we use a breakout board. if you get any reading when not pushed pad is bad. you may find a manual inside the kickplate which explains the keypad sequence. it may be control but more likely keypad, even if test is inconclusive.
When I had this problem, it turned out to be the heating element.
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
SOURCE: "Normal" light flashes
You need a new control bd. #W10084141. If the diagnostic mode will not work then the board will have to be replaced.
SOURCE: jenn air diswasher mod # JDB1100AWS
disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
