Question about Dishwashers
I have a Diplomat HJA8630 integrated dishwasher the water is hot on the no heat program.
At the end of a hot wash program plates still hot 6 hours after the program has finished.
SOURCE: Dishwasher Kenmore Ultrawash
One possibility is that the screen/filter to the wash units have become totally clogged. (I had this problem because of some particularly dirty water in the dishwasher.) To access the screen requires taking out the cover at the base of the dishwasher arm assemble which can be done without removing the machine, although you'll need a special screw spline screw driver. Given this the repair takes jsut five or ten minutes. Remove the screen clean it out in the sink and replace.
Posted on Feb 10, 2008
IFIXALL
  • 868 Answers
SOURCE: hi just had new dishwasher
Rinse aid is always needed for ALL dishwashers to properly operate.
Posted on May 26, 2008
  • 1462 Answers
SOURCE: diplomat adp 8520 dishwasher no hot water
two things to check
check continuity thru heater
remove outer door panel and check for faults in wiring loom
get back to me is these are both ok
Posted on Nov 14, 2008
SOURCE: diplomat dishwasher adp 8322
i had same problem and have found that under the lower basket the connecting bar to the spray arm had become detached this can be reattached by inserting the two nozzles back into position and pushing down youll see what i mean ! however i have found i now have to do this after every wash ,am currently onto diplomat to rectify this completely , hope this is any use.
Posted on Nov 28, 2008
SOURCE: Stays in wash cycle Whirlpool Dishwasher Du1050SS
my repairman contacted whirlpool about my washing machine staying on
wash.. to his surprise.. and mine.. and his co=workers.. this is the answer,
it worked.. and we have never heard this before.
In your original istallation booklet it tells you to let the dishwasher run til its complete
the first time you use it as it may rinse twice... my original installation man told me this also.
however.. if you suffer a "blip" in your electricity.. it could put the little dishwasher "brain"
out of whack.. it can run as long as 3 to 4 hours on wash to reset itself.. if you stop it
(like others have mentioned.. and which I did also).. it doesn't complete the reset and it
will attempt to do it the next time..
answer?.. just let it go once as unnerving as this is.. it works.. They did mention that
if it went to 5 hours.. call your repairman because you need a new mechanism.
karen in Dothan
Posted on Apr 03, 2009
My dishwasher just keeps washing for hours and water does not get hot what could be the problem
If its an integrated machine it will probably be the programmer if its not heating. If its a free-standing check the cables on the element.
Feb 24, 2015 | Bosch Dishwashers
No hot water
If you have no hot water to a dishwasher. check that it is hooked up to the hot water in the first place and that the valve is on. if hooked up to the cold most units do not heat the water to the proper level.
Jan 28, 2015 | Whirlpool Gold WDT710PAY Fully Integrated...
Lamona hja8630
could be a water inlet valve. Turn off water supply....disconnect hose at dishwasher....turn water supply on slightly to ensure water supply and hose are ok. If you have water there , problem could be water inlett valve or perhaps a sticky float valve.
Oct 01, 2013 | Dishwashers
Flashing programme lights
Hi
Thanks for using FixYa. That means the control sensed that the heater in the D/W did not operate 3 times in a row. So the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. Use a meter to see if it reads open; if so orders a heater assay it will come with a new control replace it too. If heater checks good then press in sequence normal wash, heat dry, normal wash, heat dry, normal wash, heat dry three times within 6 sec and all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that D/W does not heat its own water and incoming water temp should be 120. The D/W will maintain that temp. When starting your D/W first turn on your hot water till it gets hot then start your D/W this ensures your unit fills with hot water and not cold
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 22, 2009 | Dishwashers
Smeg integrated dishwasher continually washing - won't move to drying cycle.
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
I have a Diplomat Fully integrated dishwasher model ADP 8242 when put on any program it fills and seems to be washing then stops after 5 minutes and the dispenser door has not opened. There is a lot of...
Check the small drain pump. Possibly its asking the pump do drain to allow for fresh water, but because low level is not detected it shuts down. The dispenser draw normall opens when the hot wash cycle starts.When you think its washing,briefly open door and see if eater is spraying out of the nozzels.If no water visible, check the main wash motor for sticking
Sep 24, 2009 | Dishwashers
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and
REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added
together, (e.g./ “6” = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil,
measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays
at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
testing will end shortly after water has started circulating
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
What is the amount of time for a regular wash? Time on the plus wash?
a regular wash should take about an hour and a half. plus wash would be longer only because it heats the wash temp hotter.
wash temp is generally around 140 degrees
and your rinse is around 161 degrees.
your flow through heat assembly heats the water at 2 degrees a minute. so it can take anywhere from and hour and a half to two hours for a full cycle.
try turning your sink on hot water until you feel hot water coming out then start the dishwasher so it doesnt have to heat cold water up to those temps. it should run a little shorter.
Feb 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Diplomat adp 8520 dishwasher no hot water
two things to check
Nov 14, 2008 | Dishwashers
My whirlpool ADG 7540/1 doesn't heat up properly when washing, sometimes "lukewarm", sometimes a bit warmer still but not the 65 c of the programmed wash. Any ideas?
I have a Whirpool ADG7540/1 integrated dishwasher that goes straight to rinse programme, it is 6 years old, has it come to the end of its day or is there someone out there that can help? Sheelagh Fed up (Pontypridd)
Apr 21, 2008 | Whirlpool Dishwashers
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
