Question about Canon ImageRunner 3025 | IR3025 |
Canon ir3025 error code e000024-0001 - Canon ImageRunner 3025 | IR3025 |
    Top Expert:
  • Canon Master
  • 1,144 Answers
E000024-001 is a problem with the developing assembly it's usually either a faulty toner sensor sometimes just toner stuck to it just needs a clean or replacing or the the cable ties to the toner sensor are to tight near the dev assembly just cut them off.
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR3025
SOLVED Canon IR and IRC Printer Errors E000024 and E000025
See also page 2-107 (figure 640) here:
http://www.arbikas.com/view/locator/ir3045_3035_3025-pc.pdf
Posted on May 26, 2015
2 Suggested Answers
muleskinner2
  • 270 Answers
SOURCE: Code E000019-0000 for Canon ir3025
This is a standard code for waste toner full. The display should have indicated the need for some time. If not taken care of within a certain amount of copies the copier will throw out this code. You will have to remove the front cover panel and behind it is the waste toner bottle. Empty it and replace the cover, power down the copier and power back on and all should be well. I'm surprised that the drum hadn't needed to be replaced before the waste toner was needed to be emptied. There is a small screw behind the door for replacing the toner and an acess to a screw on the small shlf to the left. Remove these two screws and the cover will slide to the left and can be removed.
Posted on Jun 16, 2011
WHAT IS CANON ERROR CODE E000202-0002
Hi
My normal first step is to turn off any machine that exhibits a problem, and any other machinery to which it is connected eg a computer network etc. Leave it for about 10 minutes ad then restart it. This is sometimes sufficient to clear errors and reset the machine to an operating condition.
If this doesn't work I look elsewhere and in your case found a description of your error here:
Error Codes Canon iR3025 Code E202 0002
Also on this site you can change the make, model, and error code on your machine by using the drop down menus near the top of the page and you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Mar 08, 2015 | Canon ImageRunner 3025 Black and White...
I get lines on paper when printing on canon ir3025
I had somewhat the same issue with my Canon i9900. In fact it took THREE tries before I got it working correctly. On the first printer the ink carrier would never move. Canon sent a new printer right away. It worked about a week, then everything went red. I called and also talked with the service rep. Like you, they insisted I load the goofy Easy Print software instead of printing from Photoshop. Trouble is, Easy Print only works with Jpegs. Well, anyway, I did it, and of course it made no difference. So the rep felt it was a bad print head, (which is replaceable on the i9900. They sent me out TWO new heads, I replaced it, and it did fix the problem. I have used the printer for a few years now, but just once in a while I will get some lines, or more like smudges. A cleaning cycle usually takes care of it. I still have another new head if it ever gets too bad. I don't know if the print head is replaceable on your model or not, but it might be a place to start. Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
Mar 12, 2014 | Canon ImageRunner 3025 | IR3025 |
E000100-0001
press*#additional functions#. machine will display the following screen
service mode level 1 . from their choose copier. Go to adjust - clear- jam history-ok. Then err history - ok. Turn the machine off and on again. Your machine should wor fine.
Jan 31, 2013 | Canon IR3025 COPIER FOR 220 VOLTS ONLY
Download Canon ir3025 manual for free
Manuals for the Canon imageRunner 3025 can be downloaded in PDF from the Canon website.
Drivers and software can also be found on the same site by clicking Drivers & Software.
Feb 02, 2012 | Canon Office Equipment & Supplies
How can I correct error Code E602-0001 on my Canon copier?
You can try to reflash the hard drive or replace the hard drive
Sep 27, 2010 | Canon imageRUNNER C3200 Copier
Error 000020-000 in photocopier iR3025/3028
These is error code related to toner station trouble. It could be toner sensor fault, broken parts in toner hopper,...
the book says:
E020 The path between the sub hopper and the developing assembly is clogged with toner.
0000 The developing assembly toner sensor detects the
absence of toner, while the sub hopper toner
sensor detects the presence of toner. With the
developing clutch turned on, the hopper
feedscrew motor is rotated for 1 sec intermittently
194 times; still, the developing assembly toner
sensor does not detect the presence of toner.
Replace the developing assembly toner sensor.
Replace the sub hopper toner sensor. Replace the DC
control PCB
Aug 12, 2010 | Canon iR 2016i Black and White Copier
IR3025 can not print, Status NG
Try to enter service mode: * 2 8 *
COPIER
FUNCTION
CLEAR
ALL
OK
TURN OFF AND ON
NOTICE: WHEN YOU CLEAR ALL THAT MEANS THAT YOU WILL HAVE TO INSERT ALL SETTINGS THAT YOU MADE, LIKE IP, GATEWAY, EMAIL FOR SCANN...
May 06, 2010 | Canon ImageRunner 3025 Black and White...
IR3025
Make sure your Gateway address is correct
Dec 09, 2008 | Ricoh Aficio 3025 All-In-One Laser Printer
Canon ImageRunner 3025 | IR3025 | Logo
2,464 people viewed this question
old marine
old marine
