Question about Acer Computers & Internet
Acer Laptop - virus
I got a virus, and it won't let me do anything on my laptop. The Hard drive keeps reading. I've only had the laptop for 9 days, backups were not done. I have McAfee installed on it but when I run it, it stops responding along with any other program I run (iexplorer, antispyware, etc...). The Laptop is running on Windows Vista (unfortunately). Any direction/assistance would be greatly appreciated. Model: Aspire 5735Z
Before my Laptop became completely useless, I had found the following viruses: Vundo.exe (trojan), trojan.virtue.mondie...
Try to boot in safe mode. if it does not work :
try 2 get a norton antivirus on DVD/CD. 2008 or 2009 edition.
and auto start setup will detect the virus and remove it.
if it still not solves ur problem insert ur vista installation disk and autorun Vista setup will start. Format ur drive when setup asks you.
Posted on Jan 10, 2009
Acer Aspire 5002WLMi Laptop won't recognize full 320 Gigabytes of new PATA hard drive. It's always been running a 80 Gigabyte 4200 RPM but that drive is old...a 2005 HD. New WD320 only reads 137...
The BIOS in the ACER determines the maximum size of the hard drive it can support.
Check the laptop's specification to see the max size you can install in this model laptop.
It appears that the max size your laptop can support is 140 Gb (unformatted). 137Gb formatted.
I suggest you install a hard drive up to 140 Gb capacity in your laptop and place the 320 Gb hard drive in an USB hard drive adapter case and when you attach this hard drive to the USB port in your ACER laptop then you will be able to get the full 320 Gb capacity after you delete the partition and create a 320 Gb partition and format the hard drive.
Nov 02, 2011 | Acer Aspire 5002WLMi Notebook
Good Day! i have a aspire 6930. I've had it for a
The average life of a laptop is 5 years. Your model was made in 2008. Replace it.
Mar 01, 2017 | Acer Aspire 6930-6455 Notebook
My computer has a virus . I 've been around
Please try to install the Kaspersky internet security 2012 by downloading trail version.
Better to install this in SAFE MODE with NETWORKING . By pressing F8, you can get the options like safe mode, etc...
Otherwise, please remove the harddisk and attach to another pc or laptop externally and SCAN this hard disk completely with Kaspersky internet security 2012. Before you attach this virus hardisk to another system., please install the good system with Kaspersky internet security 2012..
Hope this helps to you..
Jun 29, 2011 | Acer Computers & Internet
I'm getting a screen that says "A disk read error
this problem caused by error connection at hard disk, your hard disk can not read by your computer
to fix this problem you need to open your laptop then disconnect your hard disk from laptop, and connect again
and turn on your laptop
the problem like this usually found at computer with sata hard disk connection
i hope this helpful
Apr 04, 2011 | Acer Computers & Internet
My acer laptop will not turn on.. a black screen keeps popping up saying "read error" and will not do anything else. WHY?
It's possible that your (hard disk drive) HDD is damaged. Can you pull it out and test it on another system? Also, does the laptop has it's stock RAM or did you add more? If you did, I suggest you remove the new RAM and leave it with the stock one. of can't pull your HDD out, contact your acer center for them to check out your hard disk. its much better if your laptop is under warranty. all technical problems and damages are fixed for free.
Nov 08, 2010 | Acer Aspire 5315 Notebook
I have an acer aspire 3680. I started up my computer and it said replace hard drive, immenident failure possible. It gave me the option to run startup repair but as is going thru the process, its keep...
Sounds like a virus. Remove the drive from the laptop and connect it to another computer using a USB cable. These cables can be purchased for around $20 from tigerdirect.com or compusa.com. After it is connected, scan the drive for viruses using your desktop antivirus program. If you do not have an antivirus program, I recommend that you download Microsoft Security Essentials for free from Microsoft's download site. http://www.microsoft.com/Security_Essentials/
Nov 17, 2009 | Acer Aspire 3680 Laptop
My laptop will not connect to windows, just keeps rebooting
If the laptop keeps on rebooting, the only problem is the hard drive (HD). You need to reformat the hard drive and reinstall the Windows. The reason why this is happening is because Windows is corrupted due to some reason (most likely due to virus).
Have a great day!
Oct 12, 2009 | Acer TravelMate 2300 Notebook
My acer 3680 laptop wo't read a 4 gig hc sd card
Good day sir/maam, you may need a driver for your SD card reader for vista. pop in the cd that came with your notebook to the cd drive. make sure its for Vista.
If still does not work, plug in a non HC sd, like a 1 gig SD card. if it works, then the card reader only supports non hc SD. ( I know it usually supports HC cards ) check also for viruses. there are viruses that can dissable sd card readers. just make sure your laptop is virus free.
Oct 05, 2009 | Acer Aspire 3680 Laptop
Very slow and problems with dvd burner
hi..the solution is u need to re-format your system and Hard Drive and re-install a new OS..i think your system is a lot of Bugs/error came from virus or worms...but b4 format back-up your files using like,USB flash drive or external Hard Disk/Drive..Good Luck mam/sir...God Day and God Bless..^_^
May 11, 2009 | Acer Aspire 3680 Laptop
Computers & Internet Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
