Question about Acer AL1511 15" LCD Monitor
LCD Problem Hi, My name is Asghar. I have ACER LCE Model # "Acer AL512". In this Lcd the problem is that some time lcd screen goes on very hi brightness therefore i can't see any text on screen. some time show thin lines on screen such as black lines & some time working fine.
  • Anonymous Mar 24, 2008
    I have a Toshiba 46in LCD, less than a year old. It has developed a vertical thin black line on the right hand side. The only change I made to the set up was adding a Hi Dev DVD player.
    Problem Solver:
  • 4 Answers
The symptom of your LCD screen when it wanted to "die". I suggest you to send it to a workshop and get it repaired.
Posted on Jun 05, 2007
SOURCE:
How much it will cost to replace a lcd screen with the short damage
Looks like you can do it yourself by purchasing a lcd screen on ebay brand new for $66.00 You can go to Acer's website and get your exact screen model (it probably doesn't matter, but if you want to get the exact same then just the model by using your serial number to get the original specifications). Or you can take the lcd screen apart and get the model off the back of the lcd screen.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for a place to enter your serial number for specifications. You might have to start with the Warranty area to find it.
To take the lcd screen apart is fairly simple. You would start by removing the plastic or rubber bumpers that are located on the plastic strip that goes around the lcd screen. Remove them with a real small flat head screw driver or an pin and then you will see the screws that hold it in place. remove the screws, remove the plastic strip by prying it apart with a little force and it will snap out. Then start removing the screws that hold the lcd screen to the brackets on the sides. Once you remove them, tilt the lcd screen forward and the screen will fall out into your hand. Use your hand to catch it because you don't want it to fall down on the keyboard or fall out too far because there is a cable on the back of it that you don't want to damage. You can remove the cable from the back of the lcd. Sometimes it might be secured with a piece of tape, so remove the tape to remove the cable.
If the lcd does not come out once you remove the screws from the side brackets then you might have to remove screws from the 4 corners that is holding it.
Below are some links to the screens.
http://www.ebay.com/itm/ACER-ASPIRE-5738G-744G50MN-15-6-LED-LCD-Screen-left-connector-/110788395603?pt=US_Laptop_Screens_LCD_Panels&hash=item19cb80c253
May 12, 2012 | Acer Aspire Notebook
My acer aspire 5532 comes on but screen is sill black.. How do I fix it?
Hi skinner fran...
You may have a faulty LCD or LCD inverter.
There is a way to check and see if the LCD is faulty.
Turn off your Aspire, then you will plug your Aspire into a different monitor and if the picture comes on then it is your LCD faulty.
If it stays black, then it is your LCD inverter that is faulty and needs replacement.
Please take time to rate me
Aug 24, 2011 | Acer Computers & Internet
On turning on ACER Aspire 5920G laptop the laptop goes through the process of booting up, ie all relevant LEDs on power come on. The screen does not load up with usual ACER whitescreen and comes up with...
Hi. Yes, it could be a failing LCD screen but I would suggest to check the ribbon that connects the LCD screen to mainboard and make sure that it is not damage and properly connected.
Aug 20, 2010 | Acer Aspire 5920-6727 Notebook
Acer 5920g screen problems
it is probably a loose or crimped LCD cable, either on the main board or on the back of the LCD panel itself.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 25, 2009 | Acer Aspire 5920-6727 Notebook
Hi! im looking for parts for a acer aspire 5335-2238 like the two half's(bottom & top)and the back bezel of the LCD.
I would suggest looking on Ebay.
1.Computers and Networking>PC Components>For Laptops and Notebooks>Acer Aspire 5300 series
[For the LCD bezel. That's the frame that goes around the LCD screen, in the front. The cover on the back of the LCD screen, is the Top Cover. The cover where the keypad is at, and the touchpad, is the Palm Rest]
2.Computers and Networking>PC Components>For Laptops and Notebooks>Laptops and Notebooks For Repair>Acer
Perhaps see if you can find a laptop for parts, that may have all the items you listed.
Sep 04, 2009 | Computers & Internet
My acer aspire 3050 screen goes white?
the ribbon cable from the lcd to the motherboard may be loose
each time you open and close the lid,it may tug on it a bit
you would have to open the screen part to get inback of the lcd
Jan 27, 2009 | Acer TravelMate 2300 Notebook
Acer AL1916W 19" LCD Monitor color has changed to blue
Hey Buddy
My AL1916W was having same problem, its due to faulty IFB which cannot save colors after pressing reset, get it replaced from acer, if its in warranty, acer will replace ur LCD within a week.
Mar 15, 2008 | Acer AL1916W 19" LCD Monitor
Lcd monitor burnin test
leave the monitor unplugged overnight
Dec 18, 2006 | Acer AL512 15" LCD Monitor
Acer AL1511 15" LCD Monitor Logo
193 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
