Question about Hotpoint Washing Machines
Hotpoint wd440 stopped mid cycle door lock light flashing
Yozzer6821
  • 116 Answers
SOURCE: Door lock light flashing
More likely the PCB needs replacing - common fault, you could try a new door switch first cost £5 new PCB £65+ but is easy to replace.
Posted on Nov 09, 2008
SOURCE: Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Posted on Apr 27, 2009
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Posted on May 17, 2009
beltronic205
  • 1461 Answers
SOURCE: The door locked light keeps flashing on my
Sounds like needs new door interlock swith Cost around 15 pounds.....Simple to fit
Posted on Sep 28, 2009
reddyanantha
  • 205 Answers
SOURCE: hotpoint aquarius wd440. Flashing lights
hello mam please check the timer switch.
Posted on Oct 04, 2009
What does a steady flashing wash light mean?
pump all the water out and stop the wash cycle your on
open the door
then disconnect the mains supply for 10-15 mins
then turn it back on and hope the software fixes itself
otherwise there is an issue its detecting
like the door interlock is being detected as bad.,..
if the motor isnt running perhaps the motor brushes need replaced and this is the cause of the flashing wash light
and motor not running
i would check out the brushes have atleat 3/4 " on them
if not replace them
Dec 20, 2014 | Hotpoint WD440 Aquarius Washer/Dryer Combo
Hotpoint aqualtis washing machine model AQXXL 129 PM my doors not locking stopping in a cycle ,and water not draining , and lights flashing
find a dealer and get a manual for the washer it will have a trouble shooting section will tell exactly what is wrong
May 17, 2014 | Washing Machines
My hotpoint aqualtis will only select the drain cycle or the slow spin cycle. There's no blockage as ive removed all pipes at the back and cleaned them.
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
see the diagram attached.
Sep 30, 2012 | Washing Machines
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
That should fix it
Jul 26, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
174 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
