Question about Whirlpool Dryers
AWZ 7913 Still working but drum not turning - Whirlpool Dryers
3 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Not Heating to dry clothes
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Posted on Oct 27, 2009
heatman101
  • 43501 Answers
SOURCE: AWZ 7913 Still working but
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Aug 14, 2011
Whirlpool dryer AWZ 8578, power is going into the
2 things stops your drum from turning ist thing to check is belt broken you take the top off and look into and you will be able to see if iis broken if that is ok then you will have to check the compasitor it on the side it like a big fuse
Oct 13, 2014 | Dryers
Hi, I am not able to open the door of my Whirlpool washer dryer AWZ 5140 E after it finishes the cycle. It shows up E13 with ticking noise. There is no water left at this stage and I am able to open the...
E13 is a dispenser error the appliance diagnostic believes the appliance is full of water so won't release the lock first thing to try is the drain filter bottom right hand corner at the front unscrew it clean and refit just be prepared it's likely u will get some water out it when u remove it.
Dec 08, 2013 | Washing Machines
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
Cannot remove rubber door/drum seal on whirlpool 1000 awz 410
I also need to replace the door seal on my Whirlpool AWZ 410 washer. Does anybody have detailed instructions of how to do this for this particular machine model (not generic instructions) & know if it is necessary to remove the front panel on this machine in order to remove the existing seal please?
Feb 23, 2013 | Washing Machines
AWZ 7913 Still working but making a very loud noise, what can I do?
heatman101
Aug 01, 2011 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Not Heating to dry clothes Whirlpool Model AWZ 7913
Good Luck,
Hope this helps
Oct 27, 2009 | Whirlpool Dryers
A FELT STRIP CAME OUT OF MY DRYER. CAN I STILL USE
you need to reinstall it because that is what the drum glides on and in time you will hear metal on metal grinding
Sep 28, 2009 | Whirlpool LEW0050P Dryer
Whirlpool awz 7303 - drum spins intermittently
sounds like the belt is going bad or something is jamming the drum up like a bad roller.
Jun 28, 2008 | Whirlpool Dryers
Dryers Logo
20 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
