Question about Samsung HLN507 50" Rear Projection HDTV-Ready Television
Displaying HD1080i on HLN507w
How do I hook up a HD reciever to display 1080i on my HLN507W.
What cables, with what connectors to which inputs?
Thanks,
Chris
    Problem Solver:
  • 17 Answers
You can get a dvi/hdmi converter at target
Posted on Jul 23, 2010
Will not display 1080p from cable company. i have a hd box hooked up
Most cable HD-boxes output either 720p or 1080i, not 1080p.
Set your TV to 1080i or 720p.
Set the HD box to the same resolution.
Mar 16, 2014 | Sony KDF-50E3000 Television
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
I have the cables hooked up between my PS3 and to the DTV connectors on the back of my Mitsubishi WS65809, but the display is still in 480i. What do I have to do to get 1080i?
In the Main menu screen for the playstation, navigate to Settings, - Display settings -Video Output Settings Press X to select It will ask what type of connector on your TV, choose component/D-Terminal press x to continue it will ask to select a setting mode, you can choose automatic or custom, Choose custom, x to continue you should be given a list of resolutions, check all those that you want to work up to 1080i (1080p is only on HDMI) press X to continue, follow instructions to finish setup,
Mar 31, 2011 | Eforcity HD Component Cable for PS2...
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
How to I change tv to 1080i from 480i?
this should automatically be done by the tv. If you input to a standard def input (ie yellow plug) or are using standard def cable it will be 480. If u change to a HD input or an HD channel it should automatically switch to 1080. The input displayed on the tv that says 480i or 1080i is just a result of what is being played, not a setting to be changed.
May 11, 2010 | Vizio VX37L Television
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
Adjust the system's video output settings. Select the best output settings for the TV in use.
1. Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1
HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p
Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i
Composite / S Video *3 480i 576i
AV MULTI / SCART *4 480p / 480i 576p / 576i
*1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5. Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
6. Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
7. Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
TV Picture is green
is your RGB cables are the same output from your tv...are you connecting from where dvd cable box sattelite box, if you are connecting from a box exs output of cable box is what colour are you using? for your your output to your tv and what input are you using of your tv set.[input 1is it video input 1,] or comp? let me know...
Jan 10, 2009 | Televison & Video
KP-53HS10 Real HD
On this TV there is only one input for any HD resolution. Input # 5 is the component input i.e. red/green/blue cable. Just get the correct cable and match colors from cable box to TV this will allow the TV to display 1080i resolution ( only one this TV supports ). FYI you will also have to connect the red and white cables to the appropriate inputs to get any sound because red/green/blue connectors are just for video display not sound. Once your connected you'll be able to access video # 5 be sure to set your cable box to 1080i resolution also. I hope this helps later J.
Dec 02, 2008 | Sony KP-53HS10 TV
Ilo 42" plasma tv
Go the the settings on the cable box. look for output resolution, then change it to 1080i and 720p. now turn the box off and back on your tv will now display the input of wither 1080i or 720p depending on the hd channel your watching.
Dec 26, 2007 | Televison & Video
Samsung HLN507 50" Rear Projection HDTV-Ready Television Logo
131 people viewed this question
Jerry Greenberg
Jerry Greenberg
