Question about JVC AV-48WP30 48" Rear Projection Television
Endless convergence problem...
Hi all, I'm having a problem with my JVC av 48wp30 tv. I'm not a tech guy so I'll try to explain this as best i can. When I plug it in and hit the power button, it repeatedly tries to self-adjust the rgb colors. The menu/channel/volume buttons are unresponsive. I see the 9 crosses on the screen for about 1/2 a second at a time, the tv pauses for about 4 or 5 seconds and then displays the crosses again. I also noticed that the red and green appear to be fine, but the blue is way too low on top. Any ideas? I heard that I could replace stk392-110's with stk392-180's, instructions on how to do this would be great!
  • Dan Pearson Jun 05, 2007
    Thanks for the fast reply Techman! I just ordered the two IC's and got the disassembly instructions for the front of the unit, I'll pull out the convergence pwb and see if it looks like I can do it.
    President:
  • 3,130 Answers
If you are not a technical guy, you should leave this for the pros, as this will involve you getting a service manual, locating the TWO convergence IC's as you never replace just the one IC as if you do, you will be back inside the set, a few months later. You will need to get some heat sink compound and apply to the back of the convergence IC's before you install them. Just know how to solder well and you should have no problems. You also may still have a problem after you replace the IC's, as sometimes when these IC's go bad, it takes out feedback or return resistors, B+ feed resistors or fuses or circuit protectors. Good Luck, Oh and use only the proper IC's in the set that the service manual calls for.
Posted on Jun 05, 2007
My jvc model # av-48wp30 tv has a blue shadow
Convergence needs repair. The AV48WP30 convergence repair kit from www.tvrepairworld.com has the parts and the CD with step by step repair instructions.
Aug 08, 2010 | JVC AV-48WP30 48" Rear Projection...
Jvc av-48wp30 blue to align convergence
Tv colors R,G,B don't alignment any colors.Tv have a convergence problems,it dead.Tv convergence board require changes 2 STK convergence ICS and some or all it resitors to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 11, 2010 | JVC AV-48WP30 48" Rear Projection...
My tv jumps with red lines while watching. JVC
It sounds like the begining of as convergence problem or cold solder on convergence board - have a tech have alook
Sep 14, 2009 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 tv(convergence)
This is a convergence board problem. Have a tech replace convergence IC's. The part no. starts with STK. If you are good in soldering and know how to test resistors, you can do it.
Jul 16, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48 in. Rear... Problem
Your convergence I.C's ( integrated circuits ) Have failed. Replace Both I.C's with Stk392-150's. The unit is equipped with 110's. These are large IC's pn the convergence board located near the front of the unit. You need soldering/desoldering experience to do this job. I would recommend seeking professional assistance.
Jun 04, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence problem
Its located in the front behind the speaker panel there s a nother small access panel the convergence board is right there on the right hand side up front.
Jun 01, 2008 | JVC AV-48WP30 48" Rear Projection...
Remote LOST - need info on what button to press...JVC AV-48WP30
There might be some features that the universal remotes aren't able to do. To perform the convergence alignment you should have the original remote.
Do you have the user manual or service manual?
The service manual will explain this process better.
Apr 10, 2008 | JVC AV-48WP30 48" Rear Projection...
Lost sound on JVC TV
http://www.amazon.com/JVC-AV-48WP30-Widescreen-HDTV-Ready-Rear-Projection/dp/B000066R7X
Cut and paste this link. Amazon's page has a link to the JVC manual. That'll tell you what you need to know
Jan 21, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence problem?
Not unless the Tv sneaking some kegerator juice while your not there??LOL It sounds like a Main b+ filter or possibly the convergence IC and is not user serviceable. With all the hi-voltage inside these sets its best for you and the set to call in a proffesional to do this type of repair. Sorry i couldnt assist you more with this repair.
Jun 12, 2006 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
