Question about Whirlpool Refrigerators
Electra fridge/freezer EFFC 83 R manual
Orange warning light has come on. Any suggestions?
SOURCE: What do you about the Fridge Freezer getting warm?
I HAVE HAD THIS PROBLEM ALSO,THE FRIDGE PIPEWORK HAS A GAS LEAK.
Posted on Jan 04, 2008
MATRIX_MMX
  • 209 Answers
SOURCE: zanussi fridge freezer
dear plapy
This to me sounds as if either your gas is not circulating through the refrigeration system, or you have a problem with thermostat. If you have recently physically moved the fridge and then powered the appliance up on the mains without letting the gas settle, then you could have damaged the fridge. And there is not really a lot you can do about this, unless you want to call out a refrigeration engineer to re-gas your fridge and assess the circulation of the pumped cold air flow.
Other problems aside of gas and thermostat could be associated with the pump (if your model has one fitted), and with this in mind, i have a good mind to have a look at the SIOS (spares, Information, Ordering, System) disc for zanussi vendored models and then get back to you once i have a further solution for you. However, I will need your make and model of zanussi fridge, so if you have this to hand it will be most appreciated. In the sad event that you dont have the paperwork/ manual for the fridge, then you can find the manufacturers model details on the rear of the fridge. however, when you move the fridge, you will need to let it stand again before powering up the unit after repair, and this should be done for a period of no less than 24 hrs, and no less than 28hrs if your appliance is a fridge freezer combi.
So once again, when i recieve further information regarding your make and model of refrigerator, then i will be able to fully investigate this matter for you, and try to come up with your most appropriate solution..
In the mean time, i bid you take care, and hope to hear from you soon
Yours sincerely
oz
Posted on Apr 11, 2008
SOURCE: Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Posted on Jul 08, 2010
toolkits
  • 1099 Answers
SOURCE: Currently have a Kenmore 26 Porcelain plus. Fridge
This is common. Unplug it or turn off the circuit breaker for a full 5 minutes. Then plug-in and follow instructions. Things will be good
Posted on Jul 30, 2010
imufo2
  • 3773 Answers
SOURCE: Fridge freezer has suddenly stopped working temp
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 26, 2011
Ff187e
Why kept your Vegetables in Freezer? Keep them in the Refrigerator Compartment. If the problem persists, refer to User Manual. Then contact Customer Care / Authorized Service Center or Dealer.
Apr 24, 2014 | Refrigerators
Fridge and freezer stopped working but fridge light still on should the orange switch by the light be on or off don't know if that is the defrost button
Sounds like a motherboard or defrost control board. Can you tell me the model number found inside the fresh food compartment or around fresh food section door frame, Without the model number it is hard to guess what the switch is that you are asking about, Thanks Sea Breeze
Dec 08, 2012 | Refrigerators
Apr 19, 2010 | Refrigerators
RANGEMASTER FRIDGE /FREEZER WATER FILTER WARNING LIGHT
Hi i have a rangemaster s x s fridge freezer and the ice maker has stopped and now the whole fridge freezer has stopped. its 2 years old and out of warrenty can anyone help please with a suggestions as to whats wrong.
Sep 18, 2009 | GE PDS22LBN Bottom Freezer French Door...
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Dec 03, 2007 | Bosch Classixx KGV28323 Bottom Freezer...
Hotpoint combination 8591
Look like your refrigerator ran out of freon.
Nov 26, 2007 | Freezers
CPCA240FFK orange (super) light keeps flashing
If you have the owners manual it should say what that means but I'll see if I can find an operation manual or tech manual online and get back to you.
Dec 27, 2006 | Candy CPCA240FFK Bottom Freezer...
Refrigerators Logo
69 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
