Question about Health & Beauty
Fix braun 7015 shaver - Health & Beauty
  • 3 Answers
SOURCE: braun 7526 shaver switch
Managed to fix it - actually was a 7680. Only do this if you:
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
Posted on Jan 28, 2008
SOURCE: Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Posted on Sep 02, 2008
  • 10 Answers
SOURCE: I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
This button wears out or just fails with time, but is replaceable.
Braun 7526 Syncro Body Housing with Trimmer
$12.99, Fits Model: 7526, Type: 5493, Includes back case, front case with trimmer/switch, side grips and bottom 'plug', http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
Posted on Aug 29, 2009
VtToolMan
  • 704 Answers
SOURCE: Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Posted on Oct 23, 2009
Testimonial: "very helpful"
brector3
  • 1623 Answers
SOURCE: disassemble a braun Clean & renew razor cleaner
To open model 8985 you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
If replacement parts are required, you will find all components for this model at shaveroutlet.com
Posted on Jun 13, 2010
My Braun shaver 8585 has died. Foil, cable, box, Clean and charge unit as new. Which Braun shaver replaces Braun 8585 and can utilise good pieces?
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Aug 23, 2010 | Braun 360° Complete 8985 Electric Shaver
How to apply appliance oil on braun shaver model 6550
First, make sure that it is shaver oil. Or Braun appliance oil. Other oils may be too heavy and gum up the shaver. Apply one drop ro each side of the shaver foil periodically. If you need Braun shaver oil. it can be found at shaveroutlet.com
Dec 31, 2009 | Braun Health & Beauty
Hello, I have a Braun 8585 model and drop it is there any shop to send to fix it. please respond
Please call this number they can help you.please vote Contact information Procter & Gamble
Phone: 1-800-BRAUN-11 (1-800-272-8611)
Nov 02, 2009 | Braun Activator 8585 Electric Shaver
My braun 8585 shaver just stopped working. Does anyone know if it can be fixed? Please let me know. Thanks
There can be a number of reasons why it stopped working. But given the age of the shaver, it's probably not worth trying to fix. I'd recommend getting a newer unit. Try the 8995 360 Complete model.
Jul 11, 2009 | Braun 8585 Electric Shaver
The blades on my Braun complete 8975 are not sharp anymore.
Braun complete 8975 replacement foil and cutter blades is Braun series 3 combi 30B foil and cutter replacement pack.
Jan 30, 2009 | Braun 8975 360 Complete Men's Shaver...
You replace foil cutter, that braun complete 8975 replacement foil and cutter blades is braun series 3 combi 30B foil and cutter replacement pack.
Jan 30, 2009 | Braun 360° Complete 8985 Electric Shaver
Where can i get a cleaning stand for the braun 8985
http://cgi.ebay.com/Braun-8985-Electric-Razor-Comes-with-everything_W0QQitemZ270329232498QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item270329232498&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
Jan 16, 2009 | Braun Syncro 7526 Electric Shaver
Braun 8585 charger cleaner - not cleaning
you can try cleaning it with alchol and see if that helps it to become unplugged and able to clean your shaver again. It may also be some contacts that is on base where it contacts the shaver. If it still does not work, you will need to replace it . Look on ebay for one to replace with.
Nov 10, 2008 | Braun 8585 Electric Shaver
Braun 6520 shaver stops working after one use on batteries
dear sir, i have one like yours,your shaver need to change the battery.
Jun 10, 2007 | Braun Flex Integral 6520 Electric Shaver
Health & Beauty Logo
120 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
