Question about Clarion VRX785BT Car DVD Player
Old phone would pair with Clarion VRX785BT's bluetooth
My Clarion head unit has built in bluetooth. I had the Samsung A737 and it automatically paired with my car everytime I turned my car on. Now I got the Samsung Propel, and the dvd player will not keep my phone paired. Any ideas why it's doing this?
WHEN TALKING ON BLUETOOTH ON VRX785BT VOICES ARE BREAKING UP AND SOUND LIKE UNDER WATER.
Posted on Jun 12, 2010
    Problem Solver:
  • 8 Answers
You auto connect is turning off on the screen. try keeping ur phone permantley visable.
Posted on Apr 24, 2009
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
How many users will it allow, Clarion M502 bluetooth connection?
You can register up to five Bluetooth enabled cell-phones with the Clarion marine head unit (only one paired phone can be used at a time).
Jul 31, 2014 | Clarion M502
Cz302 'pair full' problem. My Clarion CZ302 car
I had exactly the same problem. No clue at the beginning. Then I find out the quite trivial solution. The radio had been pairing with the maximum number of devices (three I think) and so it doesn't accept any other device. First you need to "un-pair" an old device and then pair the new one. In order to unpair devices you need to go in the settings, then in the "delete pairing" and remove the device you want to unpair. The manual of the radio explains how to go in the settings.
In conclusion, no particular trick is required: after unpairing the old device(s), the pairing with the new one is immediate.
Sep 08, 2013 | Clarion Car Audio & Video
How to pair phone to samsung bluetooth headset wep301? I do not have my user guide.
Bluetooth Headset
Pairing Instructions
1. When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone's guide. Typically, the
steps involve going to a 'Setting', 'Connection',
or 'Bluetooth' menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
Jun 01, 2011 | Samsung SGH-U600 Cellular Phone
How do you get bluetooth to work?
In the bluetooth menu turn the function on, next turn on discoverable mode. Press and hold the power button on the bluetooth until the light turns on steady, usually 10 seconds or longer. Next on your phone select "search for a new device". It should find the bluetooth. It will ask for a PIN number enter 0000 (four zeros) then select pair. It should automatically connect every time after this. Be sure to turn the discoverable mode off so other devices cannot access your phone. Good luck to you
Oct 17, 2009 | Samsung SGH-a737 Cellular Phone
Can't pair bluetooth with Samsung sgh-a737
the default pass key for all bluetooh phones and devices is 1234 or 0000 try out both till the device connects
Jul 28, 2009 | GE Bluetooth In-ear Headset Wireless...
How can i pair my samsung bluetooth headset to
turn off the head set then press and hold the on button until the blue light stays solid blue.
search for device on your new phone and add device code is 0000
Mar 19, 2009 | Samsung WEP500 Wireless Headset
No bluetooth connection
Hi
Please check the Bluetooth settings! make sure you paired the device to other device
Thanks!
Dec 30, 2008 | Samsung SGH-a737 Cellular Phone
Blue Tooth Pairing
I think that you are usiing an uncompatable headset or your doing it wrong.
How to pair your Bluetooth Head Set:
  1. Turn your Bluetooth on, on your phone.
  2. Turn your Head-set on.
  3. On your phone, in the bluetooth menu; go to "Look for Devices".
  4. Your phone should automatically detect the headset and allow you to connect.
Try http://carphonewarehouse.com to see if your bluetooth head set is compatable.
Jan 02, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Clarion VRX785BT Car DVD Player Logo
392 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
