Question about Garden
My Snow thrower will only go in reverse.
It was working fine. I stopped to shovel the steps while the engine was still running. I went back to continue bllowing snow ant it would only travel in reverse. What must I do to get it to go forward again? I have an Ariens ST724 7 HP snow thrower.
3 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: my ariens 824 wont go forward or reverse
I would check your traction drive disc for wear or shredding.With low or little fuel in tank you can safely grab handle bars and lift machine up on it's auger housing.Then remove shield from under machine and inspect metal disc with rubber around it.If rubber looks worn you can get a replacement traction drive disc easily from most small engine repair shop's or go online and look for your nearest Ariens dealer.
Posted on Nov 18, 2009
huffman49
  • 235 Answers
SOURCE: Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Posted on Apr 14, 2010
Change air filter on Craftsman 24 inch snow thrower - model no. 247.885957
Most snow throwers do not have air filters. Dust is usually not an issue when blowing snow. If units have air filters, they would freeze over and stop the engine.
Mar 24, 2017 | Craftsman Garden
Can I use 0w 20 Mobil 1 oil in my snow blower
It can be used, although the manufacturer recommends;
Super S 5W-30 Snow Thrower Engine Oil - Sears
www.sears.com/explorer-5w...snow-thrower...oil/p-07188298000P
Sears Rating: 4.5 - ‎5 votes
Oct 21, 2010 - Explorer 5W-30 snow thrower engine oil is a premium formulation for use in all four cycle engines when temperatures are below 32 deg. F. Explorer 5W-30 snow thrower engine oil protects the engine by lubrication, cooling, cleaning and sealing internal moving parts.
Aug 23, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Tecuseth Snow King Engine. Starts fine. When I engage snow blower engine dies.
couple of things come to mind. Safety switch. Engine not running at full speed or snow thrower is locked smooth up
Dec 17, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
I just bought a Sears snow thrower, I put in oil and gas went to start it but the pull cord will not pull up. I then tried the electric starter but it just made a grinding sound. Why won t it start?
Check the crankcase and make sure it has oil. It sounds like the engine is frozen. If its brand new, take it back to Sears and have them start it for you.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Poulan Pro snow thrower PR8P27ES Brand new and unable to pull recoil handle or turn over with electric start. is anyone aware of a safty mechenism.
no known safety- did you assemble anything? if not- return it. if you did asssemble anything- slowly go back thru in reverse and see if you have a bolt in wrong
Dec 14, 2013 | Poulan Pro 27-Inch 208cc LCT Gas Powered...
Toro shovel snow is noisy
Something may have gotten bent. Check around the moving parts for signs of damage or signs of scraping
Feb 14, 2013 | Toro 12" Electric Shovel Snow Blower
My MTD 10hp auger will not turn. I adjusted the auger cable by tightening the bolt on the handle. I disconnected the spark plug and checked the shear pins on both sides of the auger. They are both still...
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Jan 08, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Garden Logo
130 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
